Compare array to set of numbers
Hi all,
I'm trying to read DS2520 and compare 4 first digits to what i'm setting
and if the numbers is equal get indication on led
I'm always getting that numbers is not equal, althought i know from DS reading that the numbers is coorect
can anyone help please?
#include <OneWire.h>
OneWire ds(6);
int led = 13;
  Serial.begin (9600);
  pinMode(led, OUTPUT);
  byte i;
  boolean present;
  byte data[32];
  byte leemem[3] = {
    0xF0 , 0x00 , 0x00   };
  byte ccrc;
  byte ccrc_calc;
  byte check[4] = {0,0,2,5};
  byte dat[32];
  present = ds.reset();
  ds.skip();
  if (present == TRUE){
    Serial.println("DS250x device present");
    ds.write(leemem[0],1);
    ds.write(leemem[1],1);
    ds.write(leemem[2],1);
    ccrc = ds.read();
    ccrc_calc = OneWire::crc8(leemem, 3);
    if ( ccrc_calc != ccrc) {
      Serial.println("Invalid command CRC!");
      Serial.print("Calculated CRC:");
      Serial.println(ccrc_calc,HEX);
      Serial.print("DS250x readback CRC:");
      Serial.println(ccrc,HEX);
      return;
    if(data[0] == check[0] && data[1] == check[1] && data[2] == check[2] && data[3] == check[3]){
      Serial.println("Check is good");
      digitalWrite(led, HIGH);
      delay(10000);
      digitalWrite(led, LOW);
      Serial.println("Check is bad");
    Serial.println("Data is: ");
    for ( i = 0; i < 32; i++) {
      data[i] = ds.read();
      Serial.print(data[i]);
      Serial.print(" ");
    delay(5000);
  else {
    Serial.println("Nothing connected");
    delay(3000);
What numbers?
Show your serial output.
Yes, PaulS is right.
Why don't you show the monitor result from this piece of code:
      Serial.print(" ");
      Serial.println("check good");
      delay(10000);
And why don't you do the if in 4 different if's to see where is the error?
If you do something like:
    if(data[0] == check[0]) {
       Serial.println("check 0 good");
        if (data[1] == check[1]) {
            Serial.println("check 1 good");
            if (data[2] == check[2]) {
               Serial.println("check 2 good");
               if (data[3] == check[3]) {
                  delay(10000);
EDIT: Other thing. If you see what you want to see in the serial monitor, is because your chech[] array is not well defined. It must be defined like:
  byte check[4] = {'0','0','2','5'};
Here is the Serial output
Nothing connected
Check is bad
Data is:
0 0 2 5 4 7 8 6 0 2 0 8 1 0 1 5 2 255 255 255 255 255 255 255 255 255 255 255 255 255 255 248
Yeap! You must define the check like I said.
luisilva,
I have tried to define like you said
here is the updated code:
OneWire ds(6);
int led = 13;
  byte i;
  boolean present;
  byte data[32];
  byte leemem[3] = {
  byte ccrc;
  byte ccrc_calc;
  byte dat[32];
  ds.skip();
    ccrc = ds.read();
      return;
      delay(10000);
      Serial.print(" ");
    delay(5000);
  else {
    delay(3000);
and still this is what i'm getting in the terminal:
Nothing connected
Check is bad
Data is:
Why are you comparing the data BEFORE collecting it?
Where is the data array being set with the data from the device?
The only place I can see that data[] is initialised is when you print the data in the debug message. Before that it is undefined.
      Serial.print(" ");
:smiley: Is my only answer.
ok, while waiting for answer found that i'm reading before the data was read :astonished:
can anyone help with the code?
ribhoo:
Read the data BEFORE you compare the values.
OK. Try this:
OneWire ds(6);
int led = 13;
  byte i;
  boolean present;
  byte data[32];
  byte leemem[3] = {
    0xF0 , 0x00 , 0x00
  byte ccrc;
  byte ccrc_calc;
  byte check[4] = {'0', '0', '2', '5'};
  byte dat[32];
  ds.skip();
  if (present == TRUE) {
    ds.write(leemem[0], 1);
    ds.write(leemem[1], 1);
    ds.write(leemem[2], 1);
    ccrc = ds.read();
      Serial.println(ccrc_calc, HEX);
      Serial.println(ccrc, HEX);
      return;
      Serial.print(" ");
    if (data[0] == check[0] && data[1] == check[1] && data[2] == check[2] && data[3] == check[3]) {
      delay(10000);
    else {
    delay(5000);
  else {
    delay(3000);
And find the differences.
Ok, solved it
here is the code:
OneWire ds(6);
int led = 13;
  byte i;
  boolean present;
  byte data[32];
  byte leemem[3] = {
  byte ccrc;
  byte ccrc_calc;
  int check[4] = {0,0,2,5};
  ds.skip();
    ccrc = ds.read();
      return;
     Serial.println(" ");
      Serial.print(" ");
     if(data[0] == check[0] && data[1] == check[1] && data[2] == check[2] && data[3] == check[3]) {
      delay(10000);
      Serial.print("Check is bad");
    delay(5000);
  else {
    delay(3000);
This is the first code? Because it seams to me that it will not work again.
luisilva:
Looks like it will work to me; the data is being read at the proper point now (before it's compared).
Arrch:
luisilva:
:astonished:
This is the result from the "serial monitor":
Data is:
Is that some joke Arrch?
luisilva:
Why would it be?
0 == 0
0 == 0
2 == 2
5 == 5
The math checks out.
EDIT: OK. After went back and check the code, maybe I'm wrong (or certainly). I don't know why I thought I read
      Serial.write(data[i]);
instead of:
