I am working on Load Cell. I want to compare initial value of load Cell with the new Values after removing the weight from the sensor.
Code:
The HX711 does one thing well: read load cells. The breakout board is compatible with any wheat-stone bridge
based load cell which should allow a user to measure everything from a few grams to tens of tons.
Arduino pin 2 -> HX711 CLK
3 -> DAT
5V -> VCC
GND -> GND
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine.
#include "HX711.h"
#define calibration_factor -7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
// If I will an amount of weight the load cell will give a new value.
// I want to calculate difference between initial value and the new value
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
Hello ashhadibrar
Post your current sketch, well formated, with comments and in so called code tags "</>" and a schematic, not a Fritzy diagram, to see how we can help.
Дайте миру шанс
3 -> DAT
5V -> VCC
GND -> GND
#include "HX711.h"
// If I will remove amount of weight the load cell will give a new value.
Hello ashhadibrar
My proposal is to get the inital vale during the run of the setup() function.
The difference between this inital value and new value should be calculated inside the loop() function for all new values.
Дайте миру шанс!
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation for your ask).
do this functionality for you? If you start up the scale with your initial value on the scale, it will read that as zero, and then all future readings will be relative to that initial weight.
