I am working on a project that I was hoping to get some advice on. I am trying to read a hex string and compare the values from a radar detector. I have found all of the commands and I just need a way to compare the below packet.
The radar detector gives the following packet for a laser alert
F5 06 a9 00 00 38 5F 20
I have been able to find the following
F5 (start of every packet)
06 - packet length
A9 - Command type
00 - Frequency 1 (will populate for radar alerts)
00 - Frequency 2 (will populate for radar alerts)
38 - Band type (Laser alert in this case)
5F - Direction/strength of the signal received
20 - Dont know but does change
Basically, I want a way to story the received packet into an array starting at the F5 based on the length of the 06 byte. From there, I will compare the band type/direction and feed the data into my LCD Gauge cluster through CANBUS (Which I already have a way to do)
Does anyone have any suggestion on how I can start capturing the data at F5 based on the length of the 06? I tried to do some digging for the past couple of days but couldn't come up with anything. Any starting point would be much appreciated.
you can read complete packets and process the ones your interested in
you can read one byte at a time until you receive the "start" byte, F5. then read the length byte and continue to read that many bytes into a receive buffer. once the complete packet received process it.
that processing depends on the "command type" of the packet. undesired packets are simply discarded. of course the data from a desired packet is accessible from the receive buffer.
My question is (always) if the data that you show is binary data or a hexadecimal text representation of the binary data.
How? Using some code? If so, can you show it. Or do you have the user manual / datasheet? If so, please provide a link.
That might be a CRC or checksum; probably the latter. In both cases the user manual / datasheet will tell you how to calculate so you can verify that the packet is not corrupted.
The below function looks for a start marker and next starts filling up an array of bytes; it's intended for binary receive. Note that the start marker is not stored.
// state machine states
enum BUFFERSTATE
WAITSTART,
WAITLENGTH,
INPROGRESS,
COMPLETE,
read a packet from radar
Returns:
>0 length of received data
0 no complete packet yet
-1 timeout while receiving
-2 checksum / crc error (not implemented)
int readPacket()
// where to store the next byte in the radarBuffer
static byte index;
// indicate that we have received the start byte
static BUFFERSTATE rcvState = WAITSTART;
// time that last byte was received
static uint32_t lastTime;
// return value
int rv = 0;
// timeout
if (millis() - lastTime >= timeout)
lastTime = millis();
if (rcvState != WAITSTART)
// reset receive state
// reset index
index = 0;
// indicate timeout to caller
return ERR_TO;
return 0;
//if (Serial1.available() == 0)
if (Serial.available() == 0)
// nothing to do, indicate to caller that no complete packet was received
return 0;
// read the received byte
//radarBuffer[index] = Serial1.read();
radarBuffer[index] = Serial.read();
Serial.println(radarBuffer[index], HEX);
// update time that last byte was received
// state machine
switch (rcvState)
case WAITSTART:
if (radarBuffer[index] == startByte)
Serial.println("started");
rcvState = WAITLENGTH;
case WAITLENGTH:
Serial.print("length field = "); Serial.println(radarBuffer[index], HEX);
index++;
rcvState = INPROGRESS;
case INPROGRESS:
index++;
if (index == radarBuffer[0])
rcvState = COMPLETE;
case COMPLETE:
Serial.println("complete");
// verify checksum
if (verifyCS() == false)
// set the return value
rv = ERR_CS;
rv = index + 1;
// cleanup for next packet
index = 0;
//indicate length / status to caller
return rv;
verify checksum / crc
Returns:
false on mismatch, else true
bool verifyCS()
return true;
The function makes use of a finite state machine to keep track wjat is being expected (start marker, length, actual data). It also implements a timout in case a packet is 'interrupted'. verifyCS() is a place holder and currently just returns true to indicate that the packet is not corrupt. Some debug information is printed in the function; you can remove the serial print statements.
You can adjust the size of the radarBuffer variable. 256 was based on the fact that the maximum length seems to be 255 (fits in a single byte); the length field plus 255 bytes equals 256. In loop(), you can use it as below
int len = readPacket();
if (len > 0)
Serial.print("len = "); Serial.println(len);
for (uint8_t cnt = 0; cnt < len; cnt++)
if (radarBuffer[cnt] < 0x10)
Serial.print("0");
Serial.print(radarBuffer[cnt], HEX);
Serial.print(" ");
else if (len == ERR_TO)
Serial.println("timeout while receiving");
else if (len == ERR_CS)
Serial.println("checksum / crc error");
Note:
the code uses Serial; modify to your needs (e.g. Serial1 as shown).
I am using an escort max 360 I have connected to an old Bluetooth module. I am sniffing the data going between the two and I plan to use the Arduino in place of the Bluetooth module once I figure out which commands keep the detector satisfied and allow the communications to continue without the Bluetooth module
It most likely is just binary data but I have been reading it as hex packets. I used an oscilloscope to find that the data coming from the detector is an inverted ttl signal at 57.6k baud. The signals going to the detector from the bluetooth module are a standard (non inverted) ttl signal (both at 5V). I found it odd that they would invert one signal and not the other but im sure they had a reason.
Once I found out which packet created the alert and what each byte does, I paired the bluetooth module to the app and injected different hex values into the bluetooth module until I came up with all of the scenarios that I could find. Same deal with controlling it. I went through the app and sniffed each signal for the different commands
Commands to control the detector
Brightness Sensitivity ScreenColor
F503830200 DARK F503830105 Highway F503831600 Amber
F503830201 MIN F503830100 Auto F503831601 Red
F503830202 MED F503830100 Auto No X F503831602 Green
F503830203 MAX F503831603 Blue
F503830204 AUTO
USER MODE
Speed/Voltage NOVICE F5 03 83 1A 00
F503831700 Voltage ADVANCED F5 03 83 1A 01
F503831701 Speed
F5029E01 mute
Display
F503830400 Full Word
F50383040A Scanning Bar
Meter Mode
F503830600 Standard
F503830604 Standard FR1
F503830605 Standard FR2
F503830606 Spec FR1
F503830607 Spec FR2
F503830608 Expert FR
F503830603 Simple
Auto Mute
F503830700 Off
F503830702 Low
F503830703 Medium
F503830704 High
Radar Info ( Excel doesn't copy over too well but you get the idea)
start bit Length function (alert) FREQUENCY1 FREQUENCY2 BAND Direction/strength ???
F5 06 A9 09 3C 29 3E 00
õ
Baud Rate 57600
BAND Dir/Strength DIRECTION STRENGTH
00 X BAND 00 NONE 1 BAR
01 X BAND 01 NONE 1 BAR
02 X BAND 02 NONE 1 BAR
03 X BAND 03 NONE 1 BAR
04 KU BAND 04 NONE 1 BAR
05 KU BAND 05 NONE 1 BAR
06 KU BAND 06 NONE 1 BAR
07 KU BAND 07 NONE 2 BAR
08 K BAND 08 NONE 2 BAR
09 K BAND 09 NONE 2 BAR
0A K BAND 0A NONE 2 BAR
0B K BAND 0B NONE 2 BAR
0C 0C NONE 2 BAR
0D 0D NONE 3 BAR
0E 0E NONE 3 BAR
0F 0F NONE 3 BAR
10 KA BAND 10 NONE 3 BAR
11 KA BAND 11 NONE 3 BAR
12 KA BAND 12 NONE 3 BAR
13 KA BAND 13 NONE 4 BAR
14 POP 14 NONE 4 BAR
15 POP 15 NONE 4 BAR
16 POP 16 NONE 4 BAR
17 POP 17 NONE 4 BAR
18 LASER 18 NONE 4 BAR
19 LASER 19 NONE 5 BAR
1A LASER 1A NONE 5 BAR
1B LASER 1B NONE 5 BAR
1C STRELKA 1C NONE 5 BAR
1D STRELKA 1D NONE 5 BAR
1E STRELKA 1E NONE 5 BAR
1F STRELKA 1F NONE 5 BAR
20 X BAND 20 FRONT 1 BAR
21 X BAND 21 FRONT 1 BAR
22 X BAND 22 FRONT 1 BAR
23 X BAND 23 FRONT 1 BAR
24 KU BAND 24 FRONT 1 BAR
25 KU BAND 25 FRONT 1 BAR
26 KU BAND 26 FRONT 1 BAR
27 KU BAND 27 FRONT 2 BAR
28 K BAND 28 FRONT 2 BAR
29 K BAND 29 FRONT 2 BAR
2A K BAND 2A FRONT 2 BAR
2B K BAND 2B FRONT 2 BAR
2C 2C FRONT 2 BAR
2D 2D FRONT 3 BAR
2E 2E FRONT 3 BAR
2F 2F FRONT 3 BAR
30 KA BAND 30 FRONT 3 BAR
31 KA BAND 31 FRONT 3 BAR
32 KA BAND 32 FRONT 3 BAR
33 KA BAND 33 FRONT 4 BAR
34 POP 34 FRONT 4 BAR
35 POP 35 FRONT 4 BAR
36 POP 36 FRONT 4 BAR
37 POP 37 FRONT 4 BAR
38 LASER 38 FRONT 4 BAR
39 LASER 39 FRONT 5 BAR
3A LASER 3A FRONT 5 BAR
3B LASER 3B FRONT 5 BAR
3C STRELKA 3C FRONT 5 BAR
3D STRELKA 3D FRONT 5 BAR
3E STRELKA 3E FRONT 5 BAR
3F STRELKA 3F FRONT 5 BAR
40 MULTI RADAR CD 40 REAR 1 BAR
41 MULTI RADAR CD 41 REAR 1 BAR
42 MULTI RADAR CD 42 REAR 1 BAR
43 MULTI RADAR CD 43 REAR 1 BAR
44 MULTI RADAR CT 44 REAR 1 BAR
45 MULTI RADAR CT 45 REAR 1 BAR
46 MULTI RADAR CT 46 REAR 1 BAR
47 MULTI RADAR CT 47 REAR 2 BAR
48 GASTO 48 REAR 2 BAR
49 GASTO 49 REAR 2 BAR
4A GASTO 4A REAR 2 BAR
4B GASTO 4B REAR 2 BAR
4C VG2 4C REAR 2 BAR
4D VG2 4D REAR 3 BAR
4E VG2 4E REAR 3 BAR
4F VG2 4F REAR 3 BAR
50 ROBOT 50 REAR 3 BAR
51 ROBOT 51 REAR 3 BAR
52 ROBOT 52 REAR 3 BAR
53 ROBOT 53 REAR 4 BAR
54 54 REAR 4 BAR
55 55 REAR 4 BAR
56 56 REAR 4 BAR
57 57 REAR 4 BAR
58 58 REAR 4 BAR
59 59 REAR 5 BAR
5A 5A REAR 5 BAR
5B 5B REAR 5 BAR
5C 5C REAR 5 BAR
5D 5D REAR 5 BAR
5E 5E REAR 5 BAR
5F 5F REAR 5 BAR
60 MULTI RADAR CD 60 SIDE 1 BAR
61 MULTI RADAR CD 61 SIDE 1 BAR
62 MULTI RADAR CD 62 SIDE 1 BAR
63 MULTI RADAR CD 63 SIDE 1 BAR
64 MULTI RADAR CT 64 SIDE 1 BAR
65 MULTI RADAR CT 65 SIDE 1 BAR
66 MULTI RADAR CT 66 SIDE 1 BAR
67 MULTI RADAR CT 67 SIDE 2 BAR
68 GASTO 68 SIDE 2 BAR
69 GASTO 69 SIDE 2 BAR
6A GASTO 6A SIDE 2 BAR
6B GASTO 6B SIDE 2 BAR
6C VG2 6C SIDE 2 BAR
6D VG2 6D SIDE 3 BAR
6E VG2 6E SIDE 3 BAR
6F VG2 6F SIDE 3 BAR
70 ROBOT 70 SIDE 3 BAR
71 ROBOT 71 SIDE 3 BAR
72 ROBOT 72 SIDE 3 BAR
73 ROBOT 73 SIDE 4 BAR
74 74 SIDE 4 BAR
75 75 SIDE 4 BAR
76 76 SIDE 4 BAR
77 77 SIDE 4 BAR
78 78 SIDE 4 BAR
79 79 SIDE 5 BAR
7A 7A SIDE 5 BAR
7B 7B SIDE 5 BAR
7C 7C SIDE 5 BAR
7D 7D SIDE 5 BAR
7E 7E SIDE 5 BAR
7F 7F SIDE 5 BAR
80 X BAND 80
81 X BAND 81
82 X BAND 82
83 X BAND 83
84 KU BAND 84
85 KU BAND 85
86 KU BAND 86
87 KU BAND 87
88 K BAND 88
89 K BAND 89
8A K BAND 8A
8B K BAND 8B
8C 8C
8D 8D
8E 8E
8F 8F
90 KA BAND 90
91 KA BAND 91
92 KA BAND 92
93 KA BAND 93
94 POP 94
95 POP 95
96 POP 96
97 POP 97
98 LASER 98
99 LASER 99
9A LASER 9A
9B LASER 9B
9C STRELKA 9C
9D STRELKA 9D
9E STRELKA 9E
9F STRELKA 9F
A0 X BAND A0
A1 X BAND A1
A2 X BAND A2
A3 X BAND A3
A4 KU BAND A4
A5 KU BAND A5
A6 KU BAND A6
A7 KU BAND A7
A8 K BAND A8
A9 K BAND A9
AA K BAND AA
AB K BAND AB
AC AC
AD AD
AE AE
AF AF
B0 KA BAND B0
B1 KA BAND B1
B2 KA BAND B2
B3 KA BAND B3
B4 POP B4
B5 POP B5
B6 POP B6
B7 POP B7
B8 LASER B8
B9 LASER B9
BA LASER BA
BB LASER BB
BC STRELKA BC
BD STRELKA BD
BE STRELKA BE
BF STRELKA BF
C0 MULTI RADAR CD C0
C1 MULTI RADAR CD C1
C2 MULTI RADAR CD C2
C3 MULTI RADAR CD C3
C4 MULTI RADAR CT C4
C5 MULTI RADAR CT C5
C6 MULTI RADAR CT C6
C7 MULTI RADAR CT C7
C8 GASTO C8
C9 GASTO C9
CA GASTO CA
CB GASTO CB
CC VG2 CC
CD VG2 CD
CE VG2 CE
CF VG2 CF
D0 ROBOT D0
D1 ROBOT D1
D2 ROBOT D2
D3 ROBOT D3
D4 D4
D5 D5
D6 D6
D7 D7
D8 D8
D9 D9
DA DA
DB DB
DC DC
DD DD
DE DE
DF DF
E0 MULTI RADAR CD E0
E1 MULTI RADAR CD E1
E2 MULTI RADAR CD E2
E3 MULTI RADAR CD E3
E4 MULTI RADAR CT E4
E5 MULTI RADAR CT E5
E6 MULTI RADAR CT E6
E7 MULTI RADAR CT E7
E8 GASTO E8
E9 GASTO E9
EA GASTO EA
EB GASTO EB
EC VG2 EC
ED VG2 ED
EE VG2 EE
EF VG2 EF
F0 ROBOT F0
F1 ROBOT F1
F2 ROBOT F2
F3 ROBOT F3
F4 F4
F5 F5
F6 F6
F7 F7
F8 F8
F9 F9
FA FA
FB FB
FC FC
FD FD
FE FE
FF FF
I used realterm software in hex display mode to display all of this data
