Hey All,
This is the loop from the IRremote demo from the examples folder
if (irrecv.decode(&results)) {
// print() & println() can't handle printing long longs. (uint64_t)
serialPrintUint64(results.value, HEX);
Serial.println("");
irrecv.resume(); // Receive the next value
Compilation error: ISO C++ forbids comparison between pointer and integer [-fpermissive]
How can I make this comparison?
Thanks
Rich
Here's the whole sketch
* IRremoteESP8266: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* This is very simple teaching code to show you how to use the library.
* If you are trying to decode your Infra-Red remote(s) for later replay,
* use the IRrecvDumpV2.ino (or later) example code instead of this.
* An IR detector/demodulator must be connected to the input kRecvPin.
* Copyright 2009 Ken Shirriff, http://arcfn.com
* Example circuit diagram:
* https://github.com/crankyoldgit/IRremoteESP8266/wiki#ir-receiving
* Changes:
* Version 0.2 June, 2017
* Changed GPIO pin to the same as other examples.
* Used our own method for printing a uint64_t.
* Changed the baud rate to 115200.
* Version 0.1 Sept, 2015
* Based on Ken Shirriff's IrsendDemo Version 0.1 July, 2009
#include <Arduino.h>
#include <IRremoteESP8266.h>
#include <IRrecv.h>
#include <IRutils.h>
// An IR detector/demodulator is connected to GPIO pin 14(D5 on a NodeMCU
// board).
// Note: GPIO 16 won't work on the ESP8266 as it does not have interrupts.
// Note: GPIO 14 won't work on the ESP32-C3 as it causes the board to reboot.
#ifdef ARDUINO_ESP32C3_DEV
const uint16_t kRecvPin = 4; // 14 on a ESP32-C3 causes a boot loop.
#else // ARDUINO_ESP32C3_DEV
#endif // ARDUINO_ESP32C3_DEV
IRrecv irrecv(kRecvPin);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
while (!Serial) // Wait for the serial connection to be establised.
delay(50);
Serial.print("IRrecvDemo is now running and waiting for IR message on Pin ");
Serial.println(kRecvPin);
if((results.value, HEX) == "FD08F7"){
Serial.println("HI");
Serial.println("");
delay(100);
Here is the whole sketch. It compiles and loads but does not respond when the code matches.
#include <IRrecv.h>
// board).
unsigned long myValue = results.value;
delay(50);
if (myValue == 0xFD08F7) {
Serial.println("");
delay(100);
#include <IRrecv.h>
// board).
delay(50);
Serial.println("");
delay(100);
