Hi everyone , I need a help , am using RFID for a door and I want the code does not open the door if the last read (of the same card) is less than 10 mins, I have more than one card and tag.
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
byte accessUID[4] = {0x79, 0x79, 0xDA, 0xB3}; //card ID
byte accessUID2[4] = {0x07, 0x97, 0x9E, 0x60}; //card ID
int motor=2;
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Read personal data on a MIFARE PICC:")); //shows in serial that it is ready to read
pinMode(motor,OUTPUT);
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
//some variables we need
byte block;
byte len;
MFRC522::StatusCode status;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.println(F("Card Detected:"));
if (mfrc522.uid.uidByte[0] == accessUID[0] && mfrc522.uid.uidByte[1] == accessUID[1] && mfrc522.uid.uidByte[2] == accessUID[2] && mfrc522.uid.uidByte[3] == accessUID[3]){
if (mfrc522.uid.uidByte[0] == accessUID2[0] && mfrc522.uid.uidByte[1] == accessUID2[1] && mfrc522.uid.uidByte[2] == accessUID2[2] && mfrc522.uid.uidByte[3] == accessUID2[3]){
Serial.println(F("\nEnd Reading\n"));
delay(300); //change value if you want to read cards faster
delay(10);
