Compare the diffrences
What's the difference between putting " } " in different place?
This is my code.
int num=0 ;
int led=13;
int flash=100;
  pinMode(led,OUTPUT);
  //digitalWrite(led,LOW);
  if(Serial.available()>0)
     num=Serial.read();
     num=num-'0' ;
     if(num>=0 && num<=9)
        if(num==0)
          flash=1000;
          flash=num*100;
  }                                            // 1.
     digitalWrite(led,HIGH);
     delay(flash);
     delay(flash);
  }                                            // 2.
If you put it at 1, then the if( Serial.available() ) statement ends there.
If you put it at 2, then the if( Serial.available() ) statement ends there.
The effective difference, is that the four lines of code which cause the flashing, will execute once every time through loop( ) with 1,
but with 2, they will only execute if ( Serial.available() ) is true.
