Compare two informations
I want to compare two informations, so when the correct value is read it is sent to serial monitor.
Instead I get only hex values from the first if statement.
What am I doing wrong?
int FF10EF;
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
  if ((results.value, HEX) == (FF10EF)) {
    Serial.println("levo");
You have defined a variable called FF10EF, but not assigned a value to it.
I think you probably wanted to use a literal hexadecimal value, not a variable.
Literal hexadecimal values are prefixed with 0x and you most certainly don't want to define a literal as an integer variable.
Also, what is (results.value, HEX) supposed to achieve? HEX is only meaningful in the context of a print statement. Remember - hexadecimal is only a human readable representation of a number - internally it's a collection of 1's and 0's.
  if (results.value == 0xFF10EF) {
You mix up the value of a variable and its human readable representation. Serial.print() gives a human readable format (most of the time :wink:
Read the code below, try to understand the difference and then give it a try.
unsigned long rightValue = 0xFF10EF;
  if ( results.value == rightValue )
    // irrecv.resume(); // BUG
update: removed/commented bug from code
HEX because I convert result to hex format for shorter readable output. "FF10EF" is hex value converted from result value.
I want to compare, if the converted result value in hex is the same as the hex I want (FF10EF).
majenko:
Thanks majenko. Never used 0x before.
Problem not solved completely. Now when I get exact hex, the program loops the whole if statement, so only "levo" is printed out on serial. No other functions work.
I think you need to restructure your "if" statements.
Something more like:
    if ( results.value == 0xFF10EF )
That way you only do one resume instead of two, and you only check the value once you know there is a real value there.
I solved the problem like this
results.value = 0
Thanks anyway.
