Comparing 2 Serial.Println
Hi Guys,
I'm really new to arduino and recently started some coding. I was wondering is there any way i can compare 2 Serial.Println?
Im working with a mq-7 Sensor and want to compare 2 values the mq-7 sensor gives back to me.
the end goal is: if 4 values after each other are the same then do something.
Thanks for the help!
ArduinoBot2000
Store the results that you get from your sensor in an array; don't print the results directly.
Next you can compare the array elements for the same value and act on that.
you got a link to a post on this forum explaining that some more?
Have you looked at any of the programming examples in the IDE?
One thing that will be of help is the Serial input basics post. That tells you how to read data from the serial input, and store it in a string.
After that you can check whether they're equal by doing a simple string comparison:
(edit: code correction)
if (strcmp(string1, string2) == 0) {
  // Equal!
ArduinoBot2000:
How about posting your current code so we can see what you're doing and tailor our advise.
//if (strcmp(string1, string2) == -1) {
  // Equal!
You're right... thanks for the correction, I was mixing up things again :slight_smile:
