Comparing 3 values.
Guys, let's say i want to compare 3 values, from measurements, X, Y and Z. And I want to get the largest value of the 3 variables. How do I approach this problem with the arduino to do an action when the greatest value is read?
Thanks in advance for your replies. :D
The simplest way would be:
max(max(X,Y),Z);
Or directly coded as:
  if (a > b)
    return c > a ? c : a ;
    return c > b ? c : b ;
Generally for an array of values you have two options:
Either scan for the greatest member in the array with a for loop.
Or maintain the array in sorted order, then the largest and smallest are at the ends - this is particularly suitable if the data changes occasionally and you want to get at max / min values all the time - you use bubble-sort or similar to resort the array as new values arrive.
Also your question implies you want to trigger an action when a new value larger than any previous value is read - this is a different question really, since you just need to remember one value, namely the largest so far, in order to do this.
if (new_value > largest_value)
  largest_value = new_value ;
  trigger_action () ;
thanks for your replies!
im a bit confused. the "max" command worked, but how could i return the variable with the largest value? for example:
x = 1; y = 3; z = 4;
since z is the greatest reading, then it would do a certain action.
You can't directly, you would need to do something like this: if ((Z > X) && (Z>Y)) { // Do Z stuff }
Perhaps it would be better to provide us with more information on WHAT you're trying to, rather than HOW you're trying to do it. Some context will help quite a bit.
Not sure what you want to happen if two or more of your variables are equal to the largest value.
int largestValue = max(max(X,Y),Z);
if(X==largestValue){ //do X stuff }
if(Y==largestValue){ //do Y stuff }
if(Z==largestValue){ //do Z stuff }
Gin319: thanks for your replies!
Should have posted last night - I thought it strange to want the max value of 3 axes but not know which one.
There's a host of ways of doing it, but psuedo code can look like this:
if (x_is_biggest(x, y, z)) {
    // do something for x
else if (y_is_biggest(x, y, z)) {
    // do something for  y
else if (z_is_biggest(x, y, z)) {
    // do something for z
keeping in mind you will need to test edge cases for scenarios like x == y == z and combinations thereof.
your *_is_biggest functions will look like
bool (x_is_biggest(int x, int y, int z)) {
    return ((x > y) && (x > z));
if your x,y, z are truly axes, you can also possibly see negative values that are "biggest" in terms of primary direction, so use abs() function to return everything to a common scale for comparison.
Thanks for the input guys! :)
aarondc: bool (x_is_biggest(int x, int y, int z)) {     return ((x > y) && (x > z)); }
Too many parantheses! Certainly you need to loose the cast to bool and change to a function definition (boolean is the preferred type for Arduino code I think):
boolean x_is_biggest (int x, int y, int z) {
    return x > y && x > z ;
return doesn't take parentheses like if and while do, lots of people think it does, also && and || bind lower than comparisons.
I called it psuedo code, not compilable code.
aarondc: I called it psuedo code, not compilable code.
It does compile, that's the problem, but isn't a function definition!
And it is also, as I stated, pseudo code. The fact that it compiles at all is simply dumb luck.
OP: if you try out my suggestion and it doesn't work, feel free to post back and I am sure we will be able to sort it out.
bool however produces smaller and thus faster code.
As boolean is typedef by Arduino.h to a unsigned char (uint8_t) the compiler can miss warning you about placing non true/false or 1/0 values.
