Thank you for all the information!
I've started to write some code by using this pages and your suggestions, I am sure the code looks really weird but maybe this is a start?
The codes is taken from this pages:
http://arduino.cc/en/Reference/If
My code:
int rx1 = 5; // input pin for RX1
int rx2 = 6; // input pin for RX2
int rx3 = 7; // input pin for RX3
int rx4 = 8; // input pin for RX4
int rx5 = 9; // input pin for RX5
int rx6 = 10; // input pin for RX6
int rx7 = 11; // input pin for RX7
int rx8 = 12; // input pin for RX8
int tx = 13; // output pin for TX
unsigned long duration1;
unsigned long duration2;
unsigned long duration3;
unsigned long duration4;
unsigned long duration5;
unsigned long duration6;
unsigned long duration7;
unsigned long duration8;
// Variables will change:
int duration1Counter = 0; // counter for the number of pulses
int duration2Counter = 0; // counter for the number of pulses
int duration3Counter = 0; // counter for the number of pulses
int duration4Counter = 0; // counter for the number of pulses
int duration5Counter = 0; // counter for the number of pulses
int duration6Counter = 0; // counter for the number of pulses
int duration7Counter = 0; // counter for the number of pulses
int duration8Counter = 0; // counter for the number of pulses
int duration1State = 0; // current state of the input
int duration2State = 0; // current state of the input
int duration3State = 0; // current state of the input
int duration4State = 0; // current state of the input
int duration5State = 0; // current state of the input
int duration6State = 0; // current state of the input
int duration7State = 0; // current state of the input
int duration8State = 0; // current state of the input
int lastDuration1State = 0; // previous state of the input
int lastDuration2State = 0; // previous state of the input
int lastDuration3State = 0; // previous state of the input
int lastDuration4State = 0; // previous state of the input
int lastDuration5State = 0; // previous state of the input
int lastDuration6State = 0; // previous state of the input
int lastDuration7State = 0; // previous state of the input
int lastDuration8State = 0; // previous state of the input
pinMode(rx1, INPUT); // initialize the digital pin as a input
pinMode(rx2, INPUT); // initialize the digital pin as a input
pinMode(rx3, INPUT); // initialize the digital pin as a input
pinMode(rx4, INPUT); // initialize the digital pin as a input
pinMode(rx5, INPUT); // initialize the digital pin as a input
pinMode(rx6, INPUT); // initialize the digital pin as a input
pinMode(rx7, INPUT); // initialize the digital pin as a input
pinMode(rx8, INPUT); // initialize the digital pin as a input
duration1 = pulseIn(rx1, HIGH);
duration2 = pulseIn(rx2, HIGH);
duration3 = pulseIn(rx3, HIGH);
duration4 = pulseIn(rx4, HIGH);
duration5 = pulseIn(rx5, HIGH);
duration6 = pulseIn(rx6, HIGH);
duration7 = pulseIn(rx7, HIGH);
duration8 = pulseIn(rx8, HIGH);
// if input is detected, turn on output
if (rxState >= 1)
digitalWrite(tx, HIGH);
digitalWrite(tx, LOW);
Am I on the right track?
Best regards,
Swoshie
