If that's not possible, how could I accomplish the same thing. I won't tell why yet, but I want a switch structure to be able to do something depending on what combination of some buttons are pressed.
class Secret
int *pArray;
int iCount;
public:
Secret(){pArray=NULL;iCount=0;};
void Set(int *Array, int MemberCount){pArray=Array;iCount=MemberCount;};
bool operator == (Secret &Other){ for(int i=0;i<iCount;i++){ if(Other.pArray[i]!=pArray[i]) return false;} return true;};
int Code[5] = {0,1,2,3,4};
int Pressed[5] = {0,0,0,0};
Secret s;
Secret current;
// join the class to the memory in the array.
s.Set(Code,5);
current.Set(Code,5);
// somehow alter current to set parts of it like:
// Pressed[1] = 'c';
// executes the class' == operator.
if(current==s)
// matches!
}code]
You can also do it with templates:
[WARNING: UNTESTED CODE]
[code]template <class T,int N> class MyArray
T datablock [N];
public:
MyArray()
void setmember (int x, T value) {
datablock[x]=value;
return 0;
T getmember (int x) {
return datablock[x];
bool operator == (const MyArray<T,N> &other) const { for(int i=0;i<N;i++){ if(other.datablock[i]!=datablock[i]) return false;} return true;};
MyArray<int, 5> secret;
MyArray<int, 5> current;
// current.setMember(0, 'c');
// do a compare.
if(current==secret)
// matches!
But, I haven't put this on the device or throught the compiler yet.
If you want to see if buttons are in particular states you can store the states as bits in an integer and then compare that integer to one or more values.
You can use the Arduino bit functions to set and get the bit values, here is some pseudocode:
for switch index from 0 to n-1, bitWrite( stateVariable, index, digitalRead(switchPins[index]);
stateVariable will hold a bitmask of the switches and you can compare this to the values you care about.
Could both of you explain more thouroughly? I'm not very advanced at c or c++. And I don't really understand too well what either of you are saying. :-?
Well I've just tested a rather monstrous function that I wrote to do this on g++ (though it only uses standard C libraries you'll need to specifically #include <stdarg.h>):
Disclaimer: This code seems horrible to me and should probably never be used.
This will come up with a warning: "second parameter of 'va_start' not last named argument" due to not declaring the number of arguments in the parameters of arraysEqual() meaning that if you call it with a lower number of arguments than are in the array you pass all sorts of ugly things could happen. One easy fix for this is to declare length before calling the function and have it as a parameter, but I was mostly interested in making a function for an arbitrary length array.
The va_ functions use stdarg (documented here) and macros to allow an unlimited number of arguments in a function.
I would suggest that you try and implement something like c++ std::vector with templates similar to the second example Spinlock gave.
I suspect that the OP is not up for implementing template classes.
Here is a sketch that shows how to use the Arduino bit functions to check the states of switches. The showFlags function is only used to print values to the serial port to show what is going on, it would not be needed in the actual application.
// this code assumes that pull-down resistors are used - invert the state if using pull-ups.
int pins[] = {2,3,5,7,8,9}; // array holding the pins connected to switches
int number_of_pins = sizeof(pins)/ sizeof(pins[0]); // determines how many pins in the above array
int switchStates = 0; // this will hold a bitmask of switch states
// save the switch states as bits in the variable switchStates
for(int i=0; i < number_of_pins; i++)
// set bits in switchState to represent the state of the switches
int state = digitalRead( pins[i]);
bitWrite(switchStates, i, state);
switch (switchStates)
// test for some combinations of switches we care about
case B000001: Serial.println("the first switch (pin 2) is pressed"); break;
case B000101: Serial.println("switches on pins 2 and 5 are pressed"); break;
case B111111: Serial.println("all switches are pressed"); break;
showFlags();
// reports flags that are set to see how the switchStates variable is used
void showFlags()
Serial.println(switchStates, BIN);
for(int sw = 0; sw < number_of_pins; sw++)
Serial.print("Switch ");
Serial.print(sw);
if( bitRead(switchStates, sw) == true)
Serial.println(" is pressed ");
Serial.println(" is not pressed");
I think I'll be using mem's idea. His idea seems simple and effective for what I want to use it for. Just to be certain, that can be used if there are more than 8 buttons, right? The switchesstate can he more than 8 bits, right?
Just a tip: If you use the Bnn..nn notation for binary numbers, [i]binary.h[/i] only handles 8 bit numbers. The compiler handles standard "0b" notation though, so instead use e.g. 0b0000000000000101 for larger variables (ints, longs).
