I have this problem where i am trying to compare the result of charAt with integers named pOne, pTwo, pThree, pFour and i get a result of incorrect password every time. Even know when i change pOne, pTwo, pThree, pFour with 49, 50 ,51 ,52 it works with the numbers in place but not the integers. Here is my code
String num;
int times;
int ren;
int state;
int attempts;
int rep;
int pOne;
int pTwo;
int pThree;
int pFour;
void setup(){
int state = 0;
int ren = 0;
int rep = 0;
int times = 0;
num = "0";
int pOne = 49;
int pTwo = 50;
int pThree = 51;
int pFour = 52;
int attempts = 0;
Serial.println("enter your password");
void loop(){
int in = analogRead(A0);
if(in > 3){
if(in < 10){
num = num + "1";
times = times + 1;
if(in > 510){
if(in < 514){
num = num + "2";
times = times + 1;
if(in > 999){
if(in < 1004){
num = num + "3";
times = times + 1;
if(in > 1020){
if(in < 1024){
num = num + "4";
times = times + 1;
while(analogRead(A0) > 0){
delay(10);
while(times >= 4){
if(num.charAt(1) == pOne){
if(num.charAt(2) == pTwo){
if(num.charAt(3) == pThree){
if(num.charAt(4) == pFour){
num = "0";
state = 1;
times = 0;
attempts = 0;
Serial.println("unlocked");
else{
Serial.println("incorrect password");
attempts = attempts + 1;
num = "0";
times = 0;
else{
num = "0";
times = 0;
else{
num = "0";
times = 0;
else{
num = "0";
times = 0;
if(attempts >= 4){
Serial.println("the device is locked out");
attempts = 0;
delay(300000);
Serial.println("the device is ready");
if(state == 1){
Serial.println("do you want to make a new password?");
Serial.println("if so press 1");
Serial.println("to exit and lock the device hit 3");
ren = 1;
while(ren == 1){
int goo = analogRead(A0);
if(goo > 999){
if(goo < 1004){
state = 0;
ren = 0;
if(goo > 3){
if(goo < 10){
Serial.println("the device has entered password reprogramming");
rep = 1;
ren = 0;
while(rep == 1){
Serial.println("enter your first digit");
while(analogRead(A0) < 4){
int pVar = analogRead(A0);
if(pVar > 3){
if(pVar < 10){
pOne = 49;
if(pVar > 510){
if(pVar < 514){
pOne = 50;
if(pVar > 999){
if(pVar < 1004){
pOne = 51;
if(pVar > 1020){
if(pVar < 1024){
pOne = 52;
Serial.println("enter your second digit");
if(pVar > 3){
if(pVar < 10){
pTwo = 49;
if(pVar > 510){
if(pVar < 514){
pTwo = 50;
if(pVar > 999){
if(pVar < 1004){
pTwo = 51;
if(pVar > 1020){
if(pVar < 1024){
pTwo= 52;
Serial.println("enter your third digit");
if(pVar > 3){
if(pVar < 10){
pThree = 49;
if(pVar > 510){
if(pVar < 514){
pThree = 50;
if(pVar > 999){
if(pVar < 1004){
pThree = 51;
if(pVar > 1020){
if(pVar < 1024){
pThree = 52;
Serial.println("enter your last digit");
if(pVar > 3){
if(pVar < 10){
pFour = 49;
if(pVar > 510){
if(pVar < 514){
pFour = 50;
if(pVar > 999){
if(pVar < 1004){
pFour = 51;
if(pVar > 1020){
if(pVar < 1024){
pFour = 52;
Serial.println("the reprogramming is done");
rep = 0;
delay(10);
