comparing strings is not working
I'm running out reasons why this doesn't work:
char data;
String result;
if(newcommand==true)
Serial.println(cmdline);
newcommand =false;
if(cmdline=="start")
myMotorA->setSpeed(10);
Serial.println("go");
if(cmdline =="stop")
Serial.println("end");
myMotorA->setSpeed(0);
cmdline = "";
A serial event grabs newcommand, and returns it. It prints the right output, but none the other conditions work. I've run out of ideas.
You’ll get a lot more help if you post the whole code, and please use code tags, so it appears in a box
like this
Also worth noting that you never declare ‘newcommand’ in the snippet above.
line-ending setting in the serial monitor?
TheMemberFormerlyKnownAsAWOL:
What data type is cmdline, String, char array, etc?
#include <Wire.h>
#include <String.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotorA = AFMS.getMotor(1);
Adafruit_DCMotor *myMotorB = AFMS.getMotor(2);
Adafruit_DCMotor *myMotorC = AFMS.getMotor(3);
Adafruit_DCMotor *myMotorD = AFMS.getMotor(4);
String cmdline = "";
bool newcommand = false;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  //cmdline.reserve(200);
  //Serial.println("9");
  //Serial.println("Motor test!");
  AFMS.begin();
  /*myMotorB->setSpeed(0);
  myMotorC->setSpeed(0);
  myMotorC->setSpeed(0);*/
void serialEvent()
  String newline;
  newcommand=false;
  char inchar;
  while(Serial.available())
    inchar = Serial.read();
    if(inchar=='\n')
      newcommand=true;
    }else
      newline+=inchar;
  char data;
  String result;
    newcommand =false;
  cmdline = "";
an Adafriut Motor Shield v2.3 on a Arduino Mega. The Motor Shield component works fine. The Serial Interrupt receives the message fine. Serial.println(cmdline); shows the right message.
None of the conditions are triggered.
And the line-ending is . . ?
I can't see where cmdline is getting set to anything but "".
...which makes this assertion
all the more remarkable
Are you simply printing the 'whole' string, but not seeing it.
Serial.print(F("<"));  // a prefix to show the 'real' start of the string
Serial.print(cmdLine);  // the command string - warts and all
Serial.println(F(">"));  // a suffix to show the 'real' end of the string
Will bracket the cmdLine - which could (undesirably) appear like...
<command
  • or ideally -
This will show 'what' you're comparing.
You are failing to copy newline to cmdline at the relevant point I think. This is either when you
see a newline in serialEvent, or when you recognize that newcommand has become true.
i found that now it returns nothing
i'm probably not capturing the data right. thanks for the help anyway
    if(inchar=='\n')
      newcommand=true;
      cmdline=newline;
    }else
      newline+=inchar;
This:
  String newline;
is defined only within the function serialEvent(). Try making it global.
But you should not be using Strings anyway.
that did it. :slight_smile:
