comparison against char c = inclient.read() messes things up?
I am trying to get characters from a webpage into a 2D char array. If I do just that it works, but I want to filter out certain characters from getting into the array.
I have tried:
(if c != ‘h’)
array[index]= c;
But the comparison seems to mess things up.
This worked when my sketch was based on building Strings, but I am trying to conserve memory, and the same technique seems to mess things up, although I don’t understand why.
In the code below I have the comparison commented out on line 47.
Any help is much appreciated.
#include <Bridge.h>
#include <YunClient.h>
#include "Client.h"
String baseUrl = "www.brainjar.com";
static const int num = 10;
static const int len = 70;
char temps[num][len];
YunClient client;
  Bridge.begin();
  while(!Serial);
  call(client);
void call(Client& inclient){
 int a = 0; int x = 0;
  if (inclient.connect(baseUrl.c_str(), 80)){
    inclient.print(F("GET "));
    inclient.print(F("/java/host/test.html"));
    inclient.println();
  }else {
    Serial.println("connection failed");
    while(inclient.available()) {
    char c = inclient.read();
    if(x > len-2)
    temps[a][x] = '\0';
    x = 0;
    if(a < num){
     a++;
      else{ Serial.println("\nlimit reached"); break; }
      //if(c != 'h') ////////////////////////////////<<<why doesn't this work?
      temps[a][x] = c;
      if(x < len)
      x++;
      temps[a][x] = '\0';
      for(int i = 0; i < num; i++)
      Serial.println(temps[i]);
What ends up happening? It looks like you might be missing curly braces around that if block.
That's not the right syntax... Try
if( c != 'h'){
  array[index]= c;
I tried it with and without curly braces but it makes no difference.
( I thought you could put a single line directly under an if statement without braces in c++?)
With the comparison in there (which is just supposed to remove ‘h’) it outputs:
<!DOCTYPE w3.org/TR/x HTML File <meta l;c file.
With it commented out it outputs:
Test HTML File
This is a very simple HTML file.
oraz: ( I thought you could put a single line directly under an if statement without braces in c++?)
You can, but you cannot do: (if c != 'h'), that doesn't make sens.
And I think I have a ahhhhhh. You don't put it into the array but you DO increment the counter don't you? So you end up with a empty entry which terminates the print ;) So only increment the index when you do put something into the array.
Because of the missing braces after testing the character, x will be incremented for each character read not for each character put in the array, which I assume is the intention.
Yes!! You got it septillion (first at least) :) I'm glad you spotted it. And that it is easy to fix! Working now..
