Comparison operations (Range)
Hi There1
I am setting up a distance monitor using a HCSR04 sensor with Arduino Uno and I want to be able to turn on led's at different distance ranges,
eg distance >100 (turns on 1 led)
distance <100>70
(I can't seem to be able to select a range of between 70 and 100 (turns off the above but lights another when in the range)
distance >49<70 which turns off previous led's and turns on another.
the problem seems to be in the expression eg <49>70 where I want the operation to be TRUE when the distance is anyweare in between 49 and 70.
Thank you in antisipation
Doug
//Ultrasonic sensor HC-SR04 Dougs
//Pins connected to Sensor
const int trigPin = 2;
const int echoPin = 3;
//Led Pins
const int ledRed = 7;
const int ledYellow = 8;
const int ledGreen = 9;
const int sbyRed = 5;
const int sbyGreen = 6;
//Define Variables
long duration;
long distance;
int range = 600; //Range in centimeters
  //initialise serial communication
  //initialise sensor pins
  pinMode (trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  //Initialise Leds
  pinMode(ledRed, OUTPUT);
  pinMode(ledYellow, OUTPUT);
  pinMode(ledGreen, OUTPUT);
  pinMode(sbyRed, OUTPUT);
  pinMode(sbyGreen, OUTPUT);
  //Set lEDs
  digitalWrite(ledRed, LOW);
  digitalWrite(ledYellow, LOW);
  digitalWrite(ledGreen, LOW);
  digitalWrite(sbyRed, LOW);
  digitalWrite(sbyGreen, LOW);
  //Establish Variables for duration of the ping
  // andthe distance result in cm
  long duration, cm;
  // The ping is triggered by a High Pulse of 2 or more microseconds
  //Give a short low pulse beforehandhigh Pulse
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(5);
  // Take reading on Echo Pin
  duration = pulseIn(echoPin, HIGH);
  distance = duration * .034 / 2;
  //Convert Time to a Distance
  //cm=Microseconds to Centimeters(duration)
  Serial.print("Distance: ");
  Serial.println(distance);
  Serial.print("    cm");
  if (distance>100)
   digitalWrite(sbyGreen, HIGH);
    digitalWrite(ledGreen,LOW);
  if (distance<99);
    digitalWrite(sbyGreen,LOW);
    digitalWrite(ledGreen, HIGH);
Show your code...
You need to look at the && (logical and) and || (logical or) operators.
Then you can write things like
if ((distance > some number) && (distance < some other number))
Steve
