Compass module problem
Hi all!
I found a old post about arduino autopilot ( https://forum.sparkfun.com/viewtopic.php?f=14&t=34365) and in this code he has use HMC6343 compass module. I tried to make one like that but my problem is that, I'm using HMC6352 module and unfortunately, i can't receive data from it. I changed the address to 42 but, nothing!
Any help me on it? Thank you!
 #include <Wire.h>
#include <Serial.h>
#include <Servo.h>
#define compassAddress 0x42 >> 1
Servo rudder;                     //Rudder servo object
const float minRudder = - 40.0;
const float maxRudder = 25.0;
const float centerRudder = 90.0;
const float offsetRudder = 9.5;      //Deg to correct prop torque
const unsigned int smallWiggle = 10;
const unsigned long testDelay = 1000;
const unsigned long loopDelay = 1000;
byte compassReadingBytes[2];      //Heading read bytes from compass
unsigned int rudderCommand = 90;  //Command for rudder servo
float compassReading = 0.0;       //Reading from compass
float desiredHeading = 0.0;       //Heading to be followed
float errorDeg = 0.0;             //Error btw course and desired course
float Gain = 1.5;                //Gain for proportional loop
float rudderPosition = 0.0;       //Desired position of rudder
unsigned int loopCount = 0;       //Running loop count
unsigned long initTime = 0;       //Time when compass was initialized
  Serial.begin(38400);            //Start the serial port for testing
  Serial.println("Initializing the system");
  Wire.begin();                   //Start i2c
  // put any needed compass init code below this line
  // Wait for the compass to initialise
  initTime = millis();
  rudder.attach(9);               //Rudder servo on pin 9
  Serial.println("Doing a rudder servo test");
  //Command hard over
  rudderCommand = word(minRudder + 90);
  rudder.write(rudderCommand);
  delay(testDelay);
  //Command hard over the other way
  rudderCommand = word(maxRudder + 90);
  delay(testDelay);
  //Command back to center
  rudderCommand = 90;
  delay(testDelay);
  //check that enough time has passed for compass to be ready
  while(millis() - initTime < 500 ){
    delay(10);
  //get an average of 10 readings to set desired heading
  for(int i = 0; i < 10; i++){
    readCompass();                 //Get heading from compass
    desiredHeading += compassReading/10.0;
    delay(210);
  Serial.print("Desired heading is ");
  Serial.println(desiredHeading);
  Serial.println(" ");
  //Now do a quick rudder wiggle to let the operator
  //know that the tiki is ready for launch
  //Command -10 deg
  rudderCommand = 90 - smallWiggle;
  delay(testDelay/4);
  //Command +10 deg
  rudderCommand = 90 + smallWiggle;
  delay(testDelay/2);
  rudderCommand = 90;
  delay(testDelay/4);
void loop(){
  loopCount++;
  readCompass();
    // compute how many deg offcourse tiki is
  errorDeg = compassReading - desiredHeading;
  if(errorDeg >= 180.0){
    errorDeg = errorDeg - 360.0;
  if(errorDeg <= -180.0){
    errorDeg = errorDeg + 360.0;
  // compute rudder position needed to correct error
    rudderPosition = constrain((Gain * errorDeg), minRudder, maxRudder);
  // translate that position into a servo command
  //rudderCommand = 90 - word(rudderPosition);
  rudderCommand = word(rudderPosition + centerRudder + offsetRudder);
  Serial.print("Loop count is ");
  Serial.println(loopCount);
  Serial.print("Measured heading is ");
  Serial.println(compassReading);
  Serial.print("Rudder position is ");
  Serial.println(rudderPosition);
  Serial.print("Servo command is ");
  Serial.println(rudderCommand);
  delay(loopDelay);
void readCompass(){
  //Instruct compass to read echoes
  Wire.beginTransmission(compassAddress);  // transmit to device
  // the address specified in the datasheet is 66 (0x42)
  // but i2c adressing uses the high 7 bits so it's 33
  Wire.write(0x50);                       // Send a "Post Heading Data" (0x50) command to the HMC6343
  Wire.endTransmission();                 // stop transmitting
  //Wait for readings
  delay(2);                               // datasheet suggests at least 1 ms
  //Request heading reading from compass
  Wire.requestFrom(compassAddress, 2);    // request 2 bytes from slave device #33
  //Receive heading reading from compass
  if(2 <= Wire.available())               // if 2 bytes were received
    for(int i = 0; i<2; i++) {
      compassReadingBytes[i] = Wire.read();
  compassReading = ((int)compassReadingBytes[0]<<8) | ((int)compassReadingBytes[1]);  // heading MSB and LSB
  compassReading = compassReading * 0.1;    //Translate heading to degress
  if(compassReading == 360.0){
Have you seen this?
http://playground.arduino.cc/Learning/Hmc6352
PaulS:
Have you seen this?
Arduino Playground - HomePage
Hi PaulS and thank's for you reply!
So, i connected the pullup 4.7k resistors to the SCL & SDA, also i did the the I2C test and the address it was 21.
I changed the address to 21 but still have not compass data!
After search i found a test code for hmc6352 (http://bildr.org/2011/01/hmc6352/) and the strange thing is that the compass sends the data normally with address 42 !!
Mike_Spot:
I did the the I2C test and the address it was 21.
And the strange thing is that the compass sends the data normally with address 42 !!
The low-order bit of the address byte is used for the Read/Write bit. Sometimes the address is shown as a 7-bit value (like 0x21) and sometimes it is shown shifted left one bit to make room for the R/W bit (0x42).
Hi johnwasser!
I have tested both of these addresses, 0x21 & 0x42 without any results!
The original HMC6343 code you tried, shown in your original post, uses a command of 0x50 "Post Heading Data" to request the heading data.   Wire.write(0x50);                       // Send a "Post Heading Data" (0x50) command to the HMC6343
The test code which you say works uses 0x41:
int HMC6352ReadAddress = 0x41; //"A" in hex, A command is:
 Wire.send(HMC6352ReadAddress); // The "Get Data" command
I think that if you take the original code shown in your original post and change 0x50 to 0x41 it will work with your HMC6352 compass.
johnwasser:
Thank you my friend, it works!!!
