Hi everyone!
Lately I have been trying wirting a code for an arduino controlled motor car.
During this program I trigger an interrupt every 1sec. in this interrupt I try to read the azimuth from QMC5883L digital compass (I2C).
#include <Arduino.h>
#include <Wire.h>
#include <QMC5883LCompass.h>
// #ifdef F_CPU
// #undef F_CPU
// #define F_CPU 16000000UL
// #endif
// Define motor control pins
#define RIGHT_FORWARD 2
#define RIGHT_BACKWARD 3
#define LEFT_FORWARD 6
#define LEFT_BACKWARD 7
// Define motor speeds
#define FS 0x8F // Full Speed
#define CS 0x55 // Correct Speed
#define LS 0x50 // Low Speed
#define STOP 0x00
bool ledState = 0;
byte state = 0;
QMC5883LCompass compass;
int A;
Wire.begin();
pinMode(13, OUTPUT);
digitalWrite(13, 0);
pinMode(RIGHT_FORWARD, OUTPUT);
pinMode(RIGHT_BACKWARD, OUTPUT);
pinMode(LEFT_FORWARD, OUTPUT);
pinMode(LEFT_BACKWARD, OUTPUT);
compass.init();
compass.setCalibration(-1666, 32, -353, 1371, 0, 1112);
compass.read();
A = compass.getAzimuth();
Serial.println(A);
// Setting right motor PWM
// Drive D2 & D3 HIGH when TCNT3 < OCR3x while up-counting
// Drive D2 & D3 LOW when TCNT3 > OCR3x while up-counting
//>>>>>>>> DATASHEETS PG. 154
// Set outputs to work in Fast PWM mode
// >>>>>>>> DATASHEETS PG. 145 <<<<<<<<
// Set timers to count without prescalar
// >>>>>>>> DATASHEETS PG. 156 <<<<<<<<
TCCR3A = 0b00101001; // Pin toggling mode (HIGH to LOW)
TCCR3B |= 0b00001001; // Prescalar and Fast PWM
TCCR3B &= 0b11111001;
TIMSK3 |= 0b00001100; // Enable On-Compare-Interrupt B&C
OCR3B = 0x00; // RIGHT_FORWARD speed (MAX is 0xFF)
OCR3C = 0x00; // RIGHT_BACKWARD speed (MAX is 0xFF)
//Drive D6 & D7 HIGH when TCNT4 < OCR4x while up-counting
// Drive D6 & D7 LOW when TCNT4 > OCRx while up-counting
TCCR4A = 0b10100001; // Pin toggling mode (HIGH to LOW)
TCCR4B |= 0b00001001; // Prescalar and Fast PWM
TCCR4B &= 0b11111001;
TIMSK4 |= 0b00000110; // Enable On-Compare-Interrupt B&C
OCR4A = 0x00; // LEFT_FORWARD speed (MAX is 0xFF)
OCR4B = 0x00; // LEFT_BACKWARD speed (MAX is 0xFF)
// LED blink interrupt
TCCR1A = 0;
TCCR1B = 0b00000100;
TCNT1 = 0;
TIMSK1 = 0x02;
OCR1A = 65000;
sei();
ISR(TIMER1_COMPA_vect){
TCNT1 = 0;
// compass.read();
// int a = compass.getAzimuth();
// Serial.println(a);
digitalWrite(13, ledState);
ledState = !ledState;
ISR(TIMER3_COMPB_vect){} // RIGHT_FORWARD
ISR(TIMER3_COMPC_vect){} // RIGHT_BACKWARD
ISR(TIMER4_COMPA_vect){} // LEFT_FORWARD
ISR(TIMER4_COMPB_vect){} // LEFT_BACKWARD
Inside the interrupt the LED is blinking for a visual indication. The problem begins when I add the lines under comment inside the ISR;
compass.read();
Serial.println(a);
For some reason the LED stops blinking, which means for me that the interrupt does not occur. Does anyone have an idea why it appens? does the I2C uses one of my timers??
I will really appreciate your help guys!
Thank in advance,
Bnaya.
