Compatability....
I have a Duemilanove. It is a good 10 years old. I want to know if ARDUINO 1.8.9 is compatable with it. I have loaded it, set the board to my board type and when I went to Port it simple said com7 without a name following.
Thanks, John
Yes, it's compatible. The port not having a board name is normal and expected. It's because the Duemilanove uses the FTDI FT232RL USB chip and that chip has a generic VID/PID. This means the Arduino IDE can't distinguish it from any of the other devices that also use that chip. However, this makes no functional difference. The board name in the port menu only makes it a little bit easier for the user to pick the right port. It doesn't affect the usage of the board in any way.
Ok, that clears that up. Next problem. When I do an upload to the board I get an error. Do you know what would cause and error? I am doing the simple hook a variable resistor between gnd and 5 volts. I’m not getting to the program obviously. Do I have to load the board with something first?
Thanks again in advance. John
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to “Show verbose output during: compilation”
  • Check the checkbox next to "Show verbose output during: upload
  • Click “OK”
  • Sketch > Upload
  • After the upload fails, you’ll see a button on the right side of the orange bar “Copy error messages” (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
Sketch uses 1868 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b57600 -D -Uflash:w:C:\Users\Johna\AppData\Local\Temp\arduino_build_428919/AnalogReadSerial.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x81
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x84
avrdude done. Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
Select Tools > Processor > ATmega168.
Spot on. It works. Now I can write a program to do what I wanted to do in the first place. Just needed to make sure I had a working Arduino. By the if anyone continues to read this post, is there a version of Arduino that will handle higher frequency inputs to the analog ports than the ones on this Duemilanove board? I am wanting to sample frequencies of 7 meg hz and would like as many readings as possible in one sine wave cycle.
Thanks for getting me where I needed to be.
John
On a 16MHz processor? Dream on.
Thanks for that input. Can one get an arduino that is faster?
John
Simple answer is YES.
Look at the products page to score a better board.
MKR's are quite stable and faster along with a couple more boards.
Thanks a bunch. I will look into this board.
John
