Compilation error:a function -definition is not allowed here before '{token
can anyone know whats the problem on it it says that my int getfingerprintidez a function-definition is not allowed here before
heres my sample code
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino:493:9: error: ambiguating new declaration of 'uint8_t getFingerprintIDez()'
 uint8_t getFingerprintIDez();
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino:27:5: note: old declaration 'int getFingerprintIDez()'
 int getFingerprintIDez();
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino:494:8: error: expected constructor, destructor, or type conversion before '(' token
   delay(50);             //don't ned to run this at full speed.
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino: In function 'uint8_t getFingerprintID()':
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino:657:26: error: a function-definition is not allowed here before '{' token
 int getFingerprintIDez() {
C:\Users\Ribbon\Downloads\New folder\ARDUINO\Fingerprint_door_lock_electronoobs\Fingerprint_door_lock_electronoobs.ino:672:5: error: 'else' without a previous 'if'
Multiple libraries were found for "SD.h"
  Used: C:\Users\Ribbon\Documents\Arduino\libraries\SD
  Not used: C:\Users\Ribbon\AppData\Local\Arduino15\libraries\SD
exit status 1
Compilation error: ambiguating new declaration of 'uint8_t getFingerprintIDez()'
#include <SoftwareSerial.h>
#include <Wire.h>
#include <SD.h>
#include <DS3231.h>
#include <Adafruit_Fingerprint.h>
/*  Webpage: https://www.electronoobs.com/eng_arduino_tut41.php
 *  Schematic: https://www.electronoobs.com/eng_arduino_tut40_sch1.php
 *  Code: https://www.electronoobs.com/eng_arduino_tut40_code3.php
 *  Youtube Channel: https://www.youtube.com/c/Electronoobs */
////////////////////////////////////INCLUDE ALL LIBRARIES/////////////////////////////////////////////
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);  //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
//Fingerprint libraries
SoftwareSerial mySerial(10, 11);  // pin #2 is IN from sensor (GREEN wire)/ pin #3 is OUT from arduino (WHITE wire)
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
//Real time clock libraries
#include <DS3231.h>
DS3231  rtc(SDA, SCL);// Init the DS3231 using the hardware interface
//SD card read/write libraries
#include <SPI.h>
#include <SD.h>
File myFile;
//servo library
#include <Servo.h>
Servo miServo;
/////////////////////////////////////Input and outputs////////////////////////////////////////////////
int scan_pin = 13;      //Pin for the scan push button
int add_id_pin = 12;    //Pin for the add new ID push button
int open_door = 9;     //Pin to open the door button
int RELAY_PIN = 6;        //Pin for the Servo PWM signal
const int buzzer = 8;  // Sound the alarm
//////////////////////////////////////Editable variables//////////////////////////////////////////////
int main_user_ID = 1;                 //Change this value if you want a different main user
int door_open_delay =  0.2;
int door_close_delay = 10000;
String file_name_to_save = "blackBox.txt";
//Other used variables in the code. Do not change!
bool scanning = false;
int counter = 0;
int id_ad_counter = 0;
bool id_ad = false;
uint8_t num = 1;
bool id_selected = false;
uint8_t id;
bool first_read = false;
bool main_user = false;
bool add_new_id = false;
bool door_locked = true;
  Serial.begin(57600);        //Start serial communication for fingerprint TX RX data.
  rtc.begin();                //Start the real time clock (remember to set time before this code)
  SD.begin(53);               //Start SD card module with CS pin connected to D53 of the Arduino MEGA. The other pins are SPI pins
  /*Now we open the new created file, write the data, and close it back*/
  myFile = SD.open(file_name_to_save, FILE_WRITE);   //Create a new file on the SD card named before
  myFile.print("Door lock system started at ");
  myFile.print(rtc.getTimeStr()); myFile.print(" and day ");  myFile.print(rtc.getDateStr());
  myFile.println(" ");myFile.println(" ");
  myFile.close();
  lcd.init();                     //Init the LCD with i2c communication and print text
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("   Press SCAN   ");
  lcd.setCursor(0,1);
  lcd.print(" -door  locked- ");
  //Define pins as outputs or inputs
  pinMode(scan_pin,INPUT);
  pinMode(add_id_pin,INPUT);
  pinMode(open_door,INPUT);
  pinMode(RELAY_PIN, OUTPUT);
  miServo.write(door_close_delay);  //Door close
  digitalWrite(RELAY_PIN,HIGH);
  delay(10000);                   // Door open
  digitalWrite(RELAY_PIN,LOW);    // Door close
  finger.begin(57600);                // set the data rate for the sensor serial port
   //BUZZER
  pinMode(buzzer, OUTPUT);
/////////////////////////////////////////////VOID LOOP////////////////////////////////////////////////
/////////////////////////////////////////DOOR OPEN BUTTON PRESSED///////////////////////////////////
  if(digitalRead(open_door))
    door_locked = true;
    lcd.setCursor(0,0);
    lcd.print("  Door closed!  ");
    lcd.setCursor(0,1);
    lcd.print("                ");
    delay(2000);
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    myFile.print(rtc.getDateStr()); myFile.print(" -- "); myFile.print(rtc.getTimeStr());
    myFile.println(" -- Door was closed by a user");
    myFile.close();
////////////////////////////////Scan button pressed/////////////////////////////////////////////////
 if(digitalRead(scan_pin) && !id_ad)
  myFile.println(" -- Attempt of openning door");
  myFile.close();
  scanning = true;
  lcd.setCursor(0,0);
  lcd.print("  Place finger  ");
  lcd.setCursor(0,1);
  lcd.print("SCANNING--------");
 while(scanning && counter <= 60)
  getFingerprintID();
  delay(100);
  counter = counter + 1;
  if(counter == 10)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("SCANNING  ------");
  if(counter == 20)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("SCANNING    ----");
  if(counter == 40)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("SCANNING      --");
  if(counter == 50)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("SCANNING        ");
  if(counter == 59)
    lcd.setCursor(0,0);
    lcd.print("    Timeout!    ");
    lcd.setCursor(0,1);
    lcd.print("   Try again!   ");
    myFile.println(" -- Scanning timeout!");
    myFile.close();
    delay(2000);
    if(door_locked)
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("  -door  open-  ");
 scanning = false;
 counter = 0;
///////////////////////////////END WITH SCANNING PART
//////////////////////////////////////////Add new button pressed///////////////////////////////////////////
if(digitalRead(add_id_pin) && !id_ad)
  myFile.println(" -- Add new user attempt. Require identification!");
  myFile.close();
  add_new_id = true;
  lcd.setCursor(0,0);
  lcd.print(" Scan main user ");
  lcd.setCursor(0,1);
  lcd.print("  finger first! ");
  while (id_ad_counter < 40 && !main_user)
    getFingerprintID();
    delay(100);
    id_ad_counter = id_ad_counter+1;
    if(!add_new_id)
      id_ad_counter = 40;
  id_ad_counter = 0;
  add_new_id = false;
  if(main_user)
    lcd.setCursor(0,0);
    lcd.print(" Add new ID# to ");
    lcd.setCursor(0,1);
    lcd.print("  the database  ");
    delay(1500);
    print_num(num);
    id_ad = true;
    myFile.println(" -- Add new user permission granted");
    myFile.close();
    lcd.setCursor(0,0);
    lcd.print("ERROR! Only main");
    lcd.setCursor(0,1);
    lcd.print("user can add IDs");
    delay(1500);
    if(door_locked)
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
    id_ad = false;
    myFile.println(" -- The user does not have permission to add new user");
    myFile.close();
if(digitalRead(scan_pin) && id_ad)
  id=num;
 while (! getFingerprintEnroll() );
  id_ad = false;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("  New ID saved  ");
  lcd.setCursor(4,1);
  lcd.print("as ID #");
  lcd.setCursor(11,1);
  lcd.print(id);
  delay(3000);
  if(door_locked)
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
  add_new_id = false;
  main_user = false;
  id_ad = false;
if(digitalRead(add_id_pin) && id_ad)
  num = num + 1;
  if(num > 16)
    num=1;
  print_num(num);
}//end of void
/*This function will print the ID numbers when adding new ID*/
void print_num(uint8_t)
  if (num == 1)
    lcd.setCursor(0,0);
    lcd.print("Select ID number");
    lcd.setCursor(0,1);
    lcd.print(">1  2   3   4   ");
  if (num == 2)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 1 >2   3   4   ");
  if (num == 3)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 1  2  >3   4   ");
  if (num == 4)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 1  2   3  >4   ");
  if (num == 5)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(">5  6   7   8   ");
  if (num == 6)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 5 >6   7   8   ");
  if (num == 7)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 5  6  >7   8   ");
  if (num == 8)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 5  6   7  >8   ");
  if (num == 9)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(">9  10  11  12  ");
  if (num == 10)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 9 >10  11  12  ");
  if (num == 11)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 9  10 >11  12  ");
  if (num == 12)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 9  10  11 >12  ");
  if (num == 13)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(">13  14  15  16 ");
  if (num == 14)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 13 >14  15  16 ");
  if (num == 15)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 13  14 >15  16 ");
  if (num == 16)
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(" 13  14  15 >16 ");
/*This function will read the fingerprint placed on the sensor*/
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
      // Unlock door
      digitalWrite(buzzer, HIGH);  //turn on buzzer
      delay(100);
      digitalWrite(buzzer, LOW);  //turn off buzzer
    case FINGERPRINT_NOFINGER:
     Serial.println("No finger detected");
     // Sound alarm
     delay(5000);
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
if (p !=FINGERPRINT_OK) {
  return p;
   p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
    case FINGERPRINT_INVALIDIMAGE:
    default:
   if (p != FINGERPRINT_OK) {
    return p;
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
   Serial.println("Found a print match!");
  scanning = false;
  counter = 0;
  if(add_new_id)
    if(finger.fingerID == main_user_ID)
      main_user = true;
      id_ad = false;
      add_new_id = false;
      main_user = false;
      id_ad = false;
  miServo.write(door_open_delay); //delay so door is open
  digitalWrite(RELAY_PIN,HIGH);       //
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("   User match   ");
  lcd.setCursor(0,1);
  lcd.print(" ID: #");
  lcd.setCursor(6,1);
  lcd.print(finger.fingerID);
  lcd.setCursor(9,1);
  lcd.print("%: ");
  lcd.setCursor(12,1);
  lcd.print(finger.confidence);
  myFile.print(" -- User match for ID# "); myFile.print(finger.fingerID);
  myFile.print(" with confidence: ");   myFile.print(finger.confidence); myFile.println(" - door open");
  myFile.close();
  door_locked = false;
  delay(4000);
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  delay(50);
if(p == FINGERPRINT_NOTFOUND) {
  Serial.println("Did not find a match");
 //Sound the alarm
    delay(5000);
  scanning = false;
  id_ad = false;
  counter = 0;
  lcd.setCursor(0,0);
  lcd.print("    No match    ");
  lcd.setCursor(0,1);
  add_new_id = false;
  main_user = false;
  myFile.print(" -- No match for any ID. Door status still the same");
  myFile.close();
  delay(2000);
  if(door_locked)
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
  delay(2);
  //Return the finger ID
  return finger.fingerID;
//end finger error
}// returns -1 if failed, otherwise returns ID #
if (p != FINGERPRINT_OK) return -1;
    Serial.print("Found a print match");
  // Unlock door
  delay(100);
    Serial.print("Did not find a match");
  // Sound alarm
  delay(5000);
/*This function will add new ID to the database*/
uint8_t getFingerprintEnroll() {
  int p = -1;
  if(!first_read)
  lcd.setCursor(0,0);
  lcd.print("Add new as ID#  ");
  lcd.setCursor(14,0);
  lcd.print(id);
  lcd.setCursor(0,1);
  while (p != FINGERPRINT_OK) {
    switch (p) {
      lcd.setCursor(0,0);
      lcd.print("  Image taken!  ");
      lcd.setCursor(0,1);
      lcd.print("                ");
      delay(100);
      first_read = true;
      lcd.setCursor(0,0);
      lcd.print(id);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.print("  Comunication  ");
      lcd.setCursor(0,1);
      lcd.print("     ERROR!     ");
      lcd.setCursor(0,0);
      lcd.print("     -Image     ");
      lcd.setCursor(0,1);
    default:
      lcd.setCursor(0,0);
      lcd.print("    -Unknown    ");
      lcd.setCursor(0,1);
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      lcd.setCursor(0,0);
      lcd.print("Image converted!");
      lcd.setCursor(0,1);
      lcd.print("                ");
      lcd.setCursor(0,0);
      lcd.print("Image too messy!");
      lcd.setCursor(0,1);
      lcd.print("                ");
      return p;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
      lcd.setCursor(0,0);
      lcd.print(" No fingerprint ");
      lcd.setCursor(0,1);
      lcd.print("features found  ");
      return p;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
    default:
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
  lcd.setCursor(0,0);
  lcd.print(" Remove finger! ");
  lcd.setCursor(0,1);
  lcd.print("                ");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  lcd.setCursor(0,1);
  lcd.print("ID# ");
  lcd.setCursor(4,1);
  lcd.print(id);
  p = -1;
  lcd.setCursor(0,0);
  lcd.print("Place again the ");
  lcd.setCursor(0,1);
  lcd.print("same finger     ");
    switch (p) {
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("                ");
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
    default:
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("                ");
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("                ");
      return p;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
    default:
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      return p;
  // OK converted!
 lcd.setCursor(0,0);
 lcd.print(" Creating model ");
 lcd.setCursor(0,1);
 lcd.print("for ID# ");
 lcd.setCursor(8,1);
 lcd.print(id);
  p = finger.createModel();
    lcd.setCursor(0,0);
    lcd.print(" Print matched! ");
    lcd.setCursor(0,1);
    lcd.print("                ");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    lcd.setCursor(0,0);
    lcd.print("Fingerprint did ");
    lcd.setCursor(0,1);
    lcd.print("not match       ");
    return p;
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    return p;
  lcd.setCursor(0,1);
  lcd.print("ID# ");
  lcd.setCursor(4,1);
  lcd.print(id);
  p = finger.storeModel(id);
    lcd.setCursor(0,0);
    lcd.print("     Stored     ");
    lcd.setCursor(0,1);
    lcd.print("                ");
    myFile.print(" -- New fingerprint stored for ID# "); myFile.println(id);
    myFile.close();
    first_read = false;
    id_ad = false;
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    lcd.setCursor(0,0);
    lcd.print("Could not store ");
    lcd.setCursor(0,1);
    lcd.print("in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    lcd.setCursor(0,0);
    lcd.print("Error writing to");
    lcd.setCursor(0,1);
    lcd.print("flash           ");
    return p;
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    return p;
here's my schematic
After you've made 18 postings you still do not know how to post code in code tags?
Help us help you.
Hi @markcleo
Kindly read the forum guidelines first and then edit your post accordingly
If you expect any constructive reply, read the requirements for posting both code and error messages.
i already edit it sir thank u for your cooperation and information i just forgot it
