I can run the following code correctly in Code::Blocks and get the output. But when I try to verify it in Arduino, I face a problem. What is the difference between Arduino IDE and Code::Blocks in compiling codes? The error is:
Compilation error: cannot convert 'unsigned char (*)[16]' to 'unsigned char*' for argument '1' to 'int crypto_aead_encrypt(unsigned char*, long long unsigned int*, const unsigned char*, long long unsigned int, const unsigned char*, long long unsigned int, const unsigned char*, const unsigned char*, const unsigned char*)'
My code is as follows.
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <stdint.h>
#include <stdbool.h>
#define ROUND 12
#define min(x,y) ((x)<(y)?(x):(y))
#define max(x,y) ((x)>(y)?(x):(y))
#define D 8
#define S 4
#define RATE_INBITS 128
#define RATE_INBYTES ((RATE_INBITS + 7) / 8)
#define SQUEEZE_RATE_INBITS 128
#define SQUEEZE_RATE_INBYTES ((SQUEEZE_RATE_INBITS + 7) / 8)
#define CAPACITY_INBITS 128
#define CAPACITY_INBYTES ((CAPACITY_INBITS + 7) / 8)
#define STATE_INBITS (RATE_INBITS + CAPACITY_INBITS)
#define STATE_INBYTES ((STATE_INBITS + 7) / 8)
#define KEY_INBITS (CRYPTO_KEYBYTES * 8)
#define KEY_INBYTES (CRYPTO_KEYBYTES)
#define NOUNCE_INBITS (CRYPTO_NPUBBYTES * 8)
#define NOUNCE_INBYTES (CRYPTO_NPUBBYTES)
#define TAG_INBITS 128
#define TAG_INBYTES ((TAG_INBITS + 7) / 8)
#define LAST_THREE_BITS_OFFSET (STATE_INBITS - (STATE_INBYTES - 1) * 8 - 3)
#define TAG_MATCH 0
#define TAG_UNMATCH -1
#define OTHER_FAILURES -2
#define ENC 0
#define DEC 1
#define CRYPTO_KEYBYTES 16
#define CRYPTO_NSECBYTES 0
#define CRYPTO_NPUBBYTES 16
#define CRYPTO_ABYTES 16
#define CRYPTO_NOOVERLAP 1
typedef uint8_t byte;
typedef uint32_t u32;
typedef uint64_t u64;
typedef uint32_t CWord;
typedef u32 tword;
typedef struct{
u64 h;
u64 l;
}u128; // state word
const byte ReductionPoly = 0x3;
const byte WORDFILTER = ((byte) 1<<S)-1;
int DEBUG = 0;
/* to be completed for one time pass mode */
unsigned long long MessBitLen = 0;
const byte RC[D][12] = {
{1, 3, 7, 14, 13, 11, 6, 12, 9, 2, 5, 10},
{0, 2, 6, 15, 12, 10, 7, 13, 8, 3, 4, 11},
{2, 0, 4, 13, 14, 8, 5, 15, 10, 1, 6, 9},
{6, 4, 0, 9, 10, 12, 1, 11, 14, 5, 2, 13},
{14, 12, 8, 1, 2, 4, 9, 3, 6, 13, 10, 5},
{15, 13, 9, 0, 3, 5, 8, 2, 7, 12, 11, 4},
{13, 15, 11, 2, 1, 7, 10, 0, 5, 14, 9, 6},
{9, 11, 15, 6, 5, 3, 14, 4, 1, 10, 13, 2}
const byte MixColMatrix[D][D] = {
{ 2, 4, 2, 11, 2, 8, 5, 6},
{12, 9, 8, 13, 7, 7, 5, 2},
{ 4, 4, 13, 13, 9, 4, 13, 9},
{ 1, 6, 5, 1, 12, 13, 15, 14},
{15, 12, 9, 13, 14, 5, 14, 13},
{ 9, 14, 5, 15, 4, 12, 9, 6},
{12, 2, 2, 10, 3, 1, 1, 14},
{15, 1, 13, 10, 5, 10, 2, 3}
byte sbox[16] = {12, 5, 6, 11, 9, 0, 10, 13, 3, 14, 15, 8, 4, 7, 1, 2};
byte FieldMult(byte a, byte b)
byte x = a, ret = 0;
int i;
for(i = 0; i < S; i++) {
if((b>>i)&1) ret ^= x;
if((x>>(S-1))&1) {
x <<= 1;
x ^= ReductionPoly;
else x <<= 1;
return ret&WORDFILTER;
void PrintState(byte state[D][D])
if(!DEBUG) return;
int i, j;
for(i = 0; i < D; i++){
for(j = 0; j < D; j++)
printf("%2X ", state[i][j]);
printf("\n");
printf("\n");
void PrintState_Column(CWord state[D])
if(!DEBUG) return;
int i, j;
printf("%2X ", (state[j]>>(i*S)) & WORDFILTER);
printf("\n");
printf("\n");
void AddKey(byte state[D][D], int round)
int i;
state[i][0] ^= RC[i][round];
void SubCell(byte state[D][D])
int i,j;
state[i][j] = sbox[state[i][j]];
void ShiftRow(byte state[D][D])
int i, j;
byte tmp[D];
for(i = 1; i < D; i++) {
tmp[j] = state[i][j];
state[i][j] = tmp[(j+i)%D];
void MixColumn(byte state[D][D])
int i, j, k;
byte tmp[D];
for(j = 0; j < D; j++){
for(i = 0; i < D; i++) {
byte sum = 0;
for(k = 0; k < D; k++)
sum ^= FieldMult(MixColMatrix[i][k], state[k][j]);
tmp[i] = sum;
state[i][j] = tmp[i];
void Permutation(byte state[D][D], int R)
int i;
for(i = 0; i < R; i++) {
if(DEBUG) printf("--- Round %d ---\n", i);
AddKey(state, i); PrintState(state);
#ifndef _TABLE_
SubCell(state); PrintState(state);
ShiftRow(state); PrintState(state);
MixColumn(state);
#else
SCShRMCS(state);
#endif
PrintState(state);
void PHOTON_Permutation(unsigned char *State_in)
byte state[D][D];
int i;
for (i = 0; i < D * D; i++)
state[i / D][i % D] = (State_in[i / 2] >> (4 * (i & 1))) & 0xf;
Permutation(state, ROUND);
memset(State_in, 0, (D * D) / 2);
State_in[i / 2] |= (state[i / D][i % D] & 0xf) << (4 * (i & 1));
/* Declaration of basic internal functions */
static uint8_t selectConst(
const bool condition1,
const bool condition2,
const uint8_t option1,
const uint8_t option2,
const uint8_t option3,
const uint8_t option4);
static void concatenate(
uint8_t *out,
const uint8_t *in_left, const size_t leftlen_inbytes,
const uint8_t *in_right, const size_t rightlen_inbytes);
static void XOR(
uint8_t *out,
const size_t iolen_inbytes);
static void XOR_const(
uint8_t *State_inout,
const uint8_t Constant);
static void ROTR1(
uint8_t *out,
const uint8_t *in,
static void ShuffleXOR(
uint8_t *DataBlock_out,
const uint8_t *OuterState_in,
const uint8_t *DataBlock_in,
const size_t DBlen_inbytes);
static void rhoohr(
uint8_t *OuterState_inout,
const size_t DBlen_inbytes,
const uint32_t EncDecInd);
static void HASH(
const uint8_t *Data_in,
const uint64_t Dlen_inbytes,
static void ENCorDEC(
uint8_t *Data_out,
const uint8_t Constant,
static void TAG(
uint8_t *Tag_out,
uint8_t *State);
/* Definition of basic internal functions */
if (condition1 && condition2) return option1;
if (condition1) return option2;
if (condition2) return option3;
return option4;
uint8_t *out,
memcpy(out, in_left, leftlen_inbytes);
memcpy(out + leftlen_inbytes, in_right, rightlen_inbytes);
static void XOR(
uint8_t *out,
size_t i;
for (i = 0; i < iolen_inbytes; i++) out[i] = in_left[i] ^ in_right[i];
State_inout[STATE_INBYTES - 1] ^= (Constant << LAST_THREE_BITS_OFFSET);
static void ROTR1(
uint8_t *out,
const uint8_t *in,
uint8_t tmp = in[0];
size_t i;
for (i = 0; i < iolen_inbytes - 1; i++)
out[i] = (in[i] >> 1) | ((in[(i+1)] & 1) << 7);
out[iolen_inbytes - 1] = (in[i] >> 1) | ((tmp & 1) << 7);
const uint8_t *OuterState_part1 = OuterState_in;
const uint8_t *OuterState_part2 = OuterState_in + RATE_INBYTES / 2;
uint8_t OuterState_part1_ROTR1[RATE_INBYTES / 2] = { 0 };
size_t i;
ROTR1(OuterState_part1_ROTR1, OuterState_part1, RATE_INBYTES / 2);
i = 0;
while ((i < DBlen_inbytes) && (i < RATE_INBYTES / 2))
DataBlock_out[i] = OuterState_part2[i] ^ DataBlock_in[i];
i++;
while (i < DBlen_inbytes)
DataBlock_out[i] = OuterState_part1_ROTR1[i - RATE_INBYTES / 2] ^ DataBlock_in[i];
i++;
static void rhoohr(
ShuffleXOR(DataBlock_out, OuterState_inout, DataBlock_in, DBlen_inbytes);
if (EncDecInd == ENC)
XOR(OuterState_inout, OuterState_inout, DataBlock_in, DBlen_inbytes);
XOR(OuterState_inout, OuterState_inout, DataBlock_out, DBlen_inbytes);
static void HASH(
uint8_t *State = State_inout;
size_t Dlen_inblocks = (Dlen_inbytes + RATE_INBYTES - 1) / RATE_INBYTES;
size_t LastDBlocklen;
size_t i;
for (i = 0; i < Dlen_inblocks - 1; i++)
PHOTON_Permutation(State);
XOR(State, State, Data_in + i * RATE_INBYTES, RATE_INBYTES);
LastDBlocklen = Dlen_inbytes - i * RATE_INBYTES;
XOR(State, State, Data_in + i * RATE_INBYTES, LastDBlocklen);
if (LastDBlocklen < RATE_INBYTES) State[LastDBlocklen] ^= 0x01; // ozs
XOR_const(State, Constant);
uint8_t *Data_out,
size_t i;
rhoohr(State, Data_out + i * RATE_INBYTES, Data_in + i * RATE_INBYTES, RATE_INBYTES, EncDecInd);
rhoohr(State, Data_out + i * RATE_INBYTES, Data_in + i * RATE_INBYTES, LastDBlocklen, EncDecInd);
static void TAG(
uint8_t *Tag_out,
uint8_t *State)
size_t i;
i = TAG_INBYTES;
while (i > SQUEEZE_RATE_INBYTES)
memcpy(Tag_out, State, SQUEEZE_RATE_INBYTES);
Tag_out += SQUEEZE_RATE_INBYTES;
i -= SQUEEZE_RATE_INBYTES;
memcpy(Tag_out, State, i);
unsigned char *c, unsigned long long *clen,
const unsigned char *m, unsigned long long mlen,
const unsigned char *ad, unsigned long long adlen,
const unsigned char *nsec,
const unsigned char *npub,
const unsigned char *k
... the code for the cipher implementation goes here,
... generating a ciphertext c[0],c[1],...,c[*clen-1]
... from a plaintext m[0],m[1],...,m[mlen-1]
... and associated data ad[0],ad[1],...,ad[adlen-1]
... and nonce npub[0],npub[1],..
... and secret key k[0],k[1],...
... the implementation shall not use nsec
... return 0;
uint8_t *C = c;
uint8_t *T = c + mlen;
const uint8_t *M = m;
const uint8_t *A = ad;
const uint8_t *N = npub;
const uint8_t *K = k;
uint8_t State[STATE_INBYTES] = { 0 };
uint8_t c0;
uint8_t c1;
(void)nsec;
concatenate(State, N, NOUNCE_INBYTES, K, KEY_INBYTES);
if ((adlen == 0) && (mlen == 0))
XOR_const(State, 1);
TAG(T, State);
*clen = TAG_INBYTES;
return 0;
c0 = selectConst((mlen != 0), ((adlen % RATE_INBYTES) == 0), 1, 2, 3, 4);
c1 = selectConst((adlen != 0), ((mlen % RATE_INBYTES) == 0), 1, 2, 5, 6);
if (adlen != 0) HASH(State, A, adlen, c0);
if ( mlen != 0) ENCorDEC(State, C, M, mlen, c1, ENC);
TAG(T, State);
*clen = mlen + TAG_INBYTES;
return 0;
int main() {
unsigned char c[16];
unsigned long long clen;
const unsigned char m[] = {};
unsigned long long mlen = 0;
const unsigned char ad[] = {};
unsigned long long adlen = 0;
const unsigned char nsec;
const unsigned char nonce[16] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f};
const unsigned char key[16] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f};
crypto_aead_encrypt(&c, &clen, &m, mlen, &ad, adlen, &nsec, &nonce, &key);
for (int i = 0; i < sizeof(c); i++) {
printf("%02X", c[i]);
return 0;
Can anyone help me? I just want to run this code on Arduino.
