Compilation error: 'class TFT_eSPI' has no member named 'getTouch' ESP32 Error
Hello everyone, I have a small piece of code that works like this: The program starts with a "Hello" message on an ILI9341, 15 seconds later, the "Hello" message is cleared and a menu with 2 buttons appears, Button 1 sets both Button 1 and Button 2 on a green color, while Button 2 sets both buttons back into their standard color (blue). Then an error appears, here is all of it:
In function 'void loop()':
     if (tft.getTouch(&touchX, &touchY)) {
exit status 1
I have Arduino IDE 2.1.0 and I just updated the libraries, I saw a solution that is downgrading the TFT_eSPI from the lastest version to version 2.3.4, I did it, even restarted Arduino, and still nothing. Here's my code:
#include <Arduino.h>
#include <TFT_eSPI.h>
// Initialize TFT display
TFT_eSPI tft;
const unsigned long timerInterval = 15000;
hw_timer_t *timer = NULL;
volatile bool alarmActivated = false;
int buttonX1 = 30;  // X-coordinate of the button's top-left corner
int buttonY1 = 30;  // Y-coordinate of the button's top-left corner
int buttonX2 = 30;  // X-coordinate of the button's top-left corner
int buttonY2 = 70;  // Y-coordinate of the button's top-left corner
int tiempo_temp;  // Variable to store the selected time
int buttonWidth = 300;  // Width of the button
int buttonHeight = 30;  // Height of the button
int control1 = 0;
int done = 0;
void drawButton() {
  tft.fillRect(10, 30, 300, 30, TFT_BLUE);
  tft.fillRect(10, 70, 300, 30, TFT_BLUE);
  tft.setTextColor(TFT_WHITE);
  tft.setTextSize(2);
  tft.drawString("Button 1", 120, 40);
  tft.drawString("Button 2", 120, 80);
void greenButton() {
  tft.fillRect(10, 30, 300, 30, TFT_GREEN);
  tft.fillRect(10, 70, 300, 30, TFT_GREEN);
  tft.setTextSize(2);
void btn1() {
  tft.setTextSize(2);
  tft.drawString("Hello", 160, 40);
  tft.fillRect(240, 200, 70, 30, TFT_WHITE);
  tft.setTextColor(TFT_BLACK);
  tft.setTextSize(2);
  tft.drawString("Menu", 245, 210);
void btn2() {
  tft.fillScreen(TFT_BLACK);
  tft.setTextSize(2);
  tft.drawString("Bye", 160, 40);
  tft.setTextSize(2);
void IRAM_ATTR callback() {
  alarmActivated = true;
  tft.begin();
  tft.setRotation(1);
  while (!Serial);
  timer = timerBegin(0, 80, true);
  timerAttachInterrupt(timer, &callback, true);
  timerAlarmWrite(timer, timerInterval * 1000, true);
  Serial.println("Timer started");
  // Check touch input
  uint16_t touchX, touchY;
  if (control1 == 1) {
    if (done == 0) {tft.fillScreen(TFT_BLACK); drawButton(); done = 1;}
      // ======================= BUTTON 1 TOUCH ============================
      if (touchX >= buttonX1 && touchX <= buttonX1 + buttonWidth && touchY >= buttonY1 && touchY <= buttonY1 + buttonHeight) {
        // Button 1 is pressed
        greenButton();
      // ====================== BUTTON 2 TOUCH =============================
      if (touchX >= buttonX2 && touchX <= buttonX2 + buttonWidth && touchY >= buttonY2 && touchY <= buttonY2 + buttonHeight) {
        // Button 2 is pressed
        drawButton();
  timerAlarmEnable(timer);
  if (control1 == 0) {
    if (!alarmActivated) {
      btn1();
      delay(100);
      control1 = 1;
      drawButton();
      delay(100);
      if (touchX >= 240 && touchX <= 240 + 70 && touchY >= 200 && touchY <= 200 + 30) {
        control1 = 1;
        drawButton();
@someonethatcodes Welcome to the forum..
hmm, my guess, you haven't defined TOUCH_CS??
from TFT_eSPI.h..
**                         Section 9: TFT_eSPI class conditional extensions
// Load the Touch extension
#ifdef TOUCH_CS
  #if defined (TFT_PARALLEL_8_BIT) || defined (RP2040_PIO_INTERFACE)
    #if !defined(DISABLE_ALL_LIBRARY_WARNINGS)
      #error >>>>------>> Touch functions not supported in 8/16 bit parallel mode or with RP2040 PIO.
    #endif
  #else
    #include "Extensions/Touch.h"        // Loaded if TOUCH_CS is defined by user
  #endif
#else
      #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available!
    #endif
#endif
it's defined inside User_Setup.h
check the screen docs for which pin..
good luck.. ~q
Hello @qubits-us, Yes, that was the problem, every single time I update the library it always has that line commented, the screen works great now. Thanks.
