Compilation error: expected unqualified-id ... 241227
Hello Arduino forum,
Working on programming a WS2812b LED strip.
Started with an Example in the FastLED library
and stripped it down to just go in one direction
and remove any other extraneous code. Got that
working.
Also would like to wiped the strip clear before
repeating the chase. So added to the end of the
chase code the lines that begin:
"for (int NUM_LEDS=0; NUM_LEDS<TOTAL_LEDS;"
and end with "strip.show();"
When compiled the result is:
"Compilation error: expected unqualified-id before numeric constant"
Research indicates that this error is cause by beginning a variable with a number. But the variable is "NUM_LEDS"
which is not a number.
Why is the IDE complaining about the variable?
Thanks.
Allen Pitts
/// @file    Cylon.ino
/// @brief   An animation that moves a single LED back and forth (Larson Scanner effect)
/// @example Cylon.ino
#include <FastLED.h>
// How many leds in your strip?
#define NUM_LEDS 80
#define DATA_PIN 3
// Define the array of leds
CRGB leds[NUM_LEDS];
	FastLED.addLeds<WS2812,DATA_PIN,RGB>(leds,NUM_LEDS);
	FastLED.setBrightness(84);
	static uint8_t hue = 0;
	//Serial.print("x");
	// First slide the led in one direction
	for(int i = 0; i < NUM_LEDS; i++) {
		// Set the i'th led to red
		leds[i] = CHSV(hue++, 255, 255);
		// Show the leds
		FastLED.show();
			delay(10);
for (int NUM_LEDS=0; NUM_LEDS<TOTAL_LEDS; NUM_LEDS++)
   strip.setPixelColor(NUM_LEDS, 0,0,0);
  strip.show();
Translating the second line based on the #define of NUM_LEDS in the first line, we get
for (int 80=0; 80<TOTAL_LEDS; 80++)
which is nonsensical.
Replace this...
... by re-using this...
