Hello everyone, I am trying to make a comparison between two functions pData and t1 in order to turn on an actuator (relay) but I am having this problem I know that is because I cannot combine two types of functions but I wanna know what can I change.
Thanks and Regards
Compilation error: ISO C++ forbids comparison between pointer and integer [-fpermissive]
It worked but now I am having a problem with my sensor it gives me a nan value when i am trying to read its value
Temperature:
23.43?
Temperature2:
nan %
#include "ThingSpeak.h"
#include "WiFi.h"
#include "BLEDevice.h"
#include "DHT.h"
#define DHTPIN 13
#define DHTTYPE DHT11
const char* ssid = "uiw-resnet"; //SSID de vuestro router.
const char* password = ""; //Contraseña de vuestro router.
unsigned long ID = 2050217; //ID de vuestro canal.
const char* APIKey = "H62ZCHN3C0703GUT"; //Write API Key de vuestro canal.
WiFiClient cliente;
int rele = 12;
DHT dht(DHTPIN, DHTTYPE);
// The remote service we wish to connect to.
static BLEUUID serviceUUID("180F");
// The characteristic of the remote service we are interested in.
static BLEUUID charUUID("2A19");
static boolean doConnect = false;
static boolean connected = false;
static boolean doScan = false;
static BLERemoteCharacteristic* pRemoteCharacteristic;
static BLEAdvertisedDevice* myDevice;
static void notifyCallback(
BLERemoteCharacteristic* pBLERemoteCharacteristic,
uint8_t* pData,
size_t length,
bool isNotify) {
float t1 = dht.readTemperature();
Serial.println("Temperature: ");
Serial.println((char*)pData);
Serial.println(" ");
Serial.println("Temperature2: ");
Serial.print(t1);
Serial.print(" %\t");
ThingSpeak.writeFields(ID,APIKey);
ThingSpeak.setField (1,(char*)pData);
ThingSpeak.setField (2,t1);
if (*(char*)pData > t1){
digitalWrite(rele, HIGH);
}else{
digitalWrite(rele, LOW);
class MyClientCallback : public BLEClientCallbacks {
void onConnect(BLEClient* pclient) {
void onDisconnect(BLEClient* pclient) {
connected = false;
Serial.println("onDisconnect");
bool connectToServer() {
Serial.print("Forming a connection to ");
Serial.println(myDevice->getAddress().toString().c_str());
BLEClient* pClient = BLEDevice::createClient();
Serial.println(" - Created client");
pClient->setClientCallbacks(new MyClientCallback());
// Connect to the remove BLE Server.
pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
Serial.println(" - Connected to server");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
if (pRemoteService == nullptr) {
Serial.print("Failed to find our service UUID: ");
Serial.println(serviceUUID.toString().c_str());
pClient->disconnect();
return false;
Serial.println(" - Found our service");
// Obtain a reference to the characteristic in the service of the remote BLE server.
pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
if (pRemoteCharacteristic == nullptr) {
Serial.print("Failed to find our characteristic UUID: ");
Serial.println(charUUID.toString().c_str());
return false;
Serial.println(" - Found our characteristic");
// Read the value of the characteristic.
if(pRemoteCharacteristic->canRead()) {
std::string value = pRemoteCharacteristic->readValue();
Serial.print("The characteristic value was: ");
Serial.println(value.c_str());
if(pRemoteCharacteristic->canNotify())
pRemoteCharacteristic->registerForNotify(notifyCallback);
connected = true;
* Scan for BLE servers and find the first one that advertises the service we are looking for.
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
* Called for each advertising BLE server.
void onResult(BLEAdvertisedDevice advertisedDevice) {
Serial.print("BLE Advertised Device found: ");
Serial.println(advertisedDevice.toString().c_str());
// We have found a device, let us now see if it contains the service we are looking for.
if (advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID)) {
BLEDevice::getScan()->stop();
myDevice = new BLEAdvertisedDevice(advertisedDevice);
doConnect = true;
doScan = true;
} // Found our server
} // onResult
}; // MyAdvertisedDeviceCallbacks
Serial.println("Starting Arduino BLE Client application...");
BLEDevice::init("");
dht.begin();
WiFi.begin(ssid,password);
Serial.print(".");
Serial.println("Wifi conect!");
ThingSpeak.begin(cliente);
pinMode(rele, OUTPUT);
BLEScan* pBLEScan = BLEDevice::getScan();
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setInterval(1349);
pBLEScan->setWindow(449);
pBLEScan->setActiveScan(true);
pBLEScan->start(5, false);
// This is the Arduino main loop function.
// If the flag "doConnect" is true then we have scanned for and found the desired
// BLE Server with which we wish to connect. Now we connect to it. Once we are
// connected we set the connected flag to be true.
if (doConnect == true) {
if (connectToServer()) {
Serial.println("We are now connected to the BLE Server.");
Serial.println("We have failed to connect to the server; there is nothin more we will do.");
doConnect = false;
// If we are connected to a peer BLE Server, update the characteristic each time we are reached
// with the current time since boot.
if (connected) {
String newValue = "Time since boot: " + String(millis()/1000);
Serial.println("Setting new characteristic value to \"" + newValue + "\"");
// Set the characteristic's value to be the array of bytes that is actually a string.
pRemoteCharacteristic->writeValue(newValue.c_str(), newValue.length());
}else if(doScan){
BLEDevice::getScan()->start(0); // this is just eample to start scan after disconnect, most likely there is better way to do it in arduino
delay(15000); // Delay a second between loops.
} // End of loop
I checked the sensor in other boards and it works fine but this one gives me that nan value what could it be maybe power or some function I am using wrong
These are my two codes the statement from weshowe worked but now I am having problems reading the values from the DHT11 it just gives me a nan as shown here:
Temperature2:
nan %
Temperature:
23.43?
my codes
#include "WiFi.h"
#include "DHT.h"
#define DHTPIN 13
WiFiClient cliente;
int rele = 12;
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.print(t1);
}else{
connected = false;
return false;
return false;
connected = true;
doConnect = true;
doScan = true;
} // onResult
dht.begin();
Serial.print(".");
doConnect = false;
if (connected) {
}else if(doScan){
} // End of loop
#include <ArduinoBLE.h>
#include <Arduino_HS300x.h>
BLEService temperatureService("180F");
//BLEUnsignedCharCharacteristic temperatureLevelChar("2A19", // standard 16-bit characteristic UUID
// BLERead | BLENotify); // remote clients will be able to get notifications if this characteristic changes
BLECharacteristic temperatureLevelChar("2A19",
BLERead | BLENotify, 7); //limit of "xxx.xx" + null terminator
float old_temp = 0;
float old_hum = 0;
long previousMillis = 0;
Serial.begin(9600); // initialize serial communication
while (!Serial);
pinMode(LED_BUILTIN, OUTPUT);
if (!HS300x.begin()) {
Serial.println("Failed to initialize humidity temperature sensor!");
while (1);
// begin initialization
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
/* Set a local name for the Bluetooth® Low Energy device
This name will appear in advertising packets
and can be used by remote devices to identify this Bluetooth® Low Energy device
The name can be changed but maybe be truncated based on space left in advertisement packet
BLE.setLocalName("TemperatureMonitor");
BLE.setAdvertisedService(temperatureService); // add the service UUID
temperatureService.addCharacteristic(temperatureLevelChar); // add the battery level characteristic
BLE.addService(temperatureService);
/* Start advertising Bluetooth® Low Energy. It will start continuously transmitting Bluetooth® Low Energy
advertising packets and will be visible to remote Bluetooth® Low Energy central devices
until it receives a new connection */
// start advertising
BLE.advertise();
Serial.println("Bluetooth® device active, waiting for connections...");
// wait for a Bluetooth® Low Energy central
BLEDevice central = BLE.central();
// if a central is connected to the peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's BT address:
Serial.println(central.address());
// turn on the LED to indicate the connection:
digitalWrite(LED_BUILTIN, HIGH);
while (central.connected()) {
long currentMillis = millis();
if (currentMillis - previousMillis >= 200) {
updatetemperatureLevel();
// when the central disconnects, turn off the LED:
digitalWrite(LED_BUILTIN, LOW);
Serial.print("Disconnected from central: ");
void updatetemperatureLevel() {
/* Read the current voltage level on the A0 analog input pin.
This is used here to simulate the charge level of a battery.
float temperature = HS300x.readTemperature();
// print each of the sensor values
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
static char temperatureCTemp[7]; //"xxx.xx" + null terminator
sprintf(temperatureCTemp, "%.2f", temperature);//two places after dp
temperatureLevelChar.writeValue(temperatureCTemp); // and update the battery level characteristic
old_temp = temperature;
This part will read the values from the peripheral BLE SENSE and compare it with the data from a DHT11 connected to the esp32 in such a case that the temperature from the BLE SENSE is greater than the one from the DHT11 a fan will turn on until the temperature from the BLE decrease.
The data that you read from the BLE is string, but the temperature from the sensor is integer. For example, first is "25" and second is 24. Controller can't compares the data of different types directly.
To compare the values you have to bring them to the same type. For example, use the atoi() function to convert pData to integer:
int ble_data = atoi(pData);
if ( ble_data > t1){
else{
Yes the DHT11 works fine in the ESP32 I am just having trouble with the power supply. apparently, I need an external source for both (DHT11 and ESP32) due to the power from the USB cable is not enough. I will also try this just to make sure.
Thank you all for your support I am sorry I could not answer earlier.
As far as now I have been able to send and read the data without a problem, using the sensor dht11 and solving the issue of the NAN value, everything works well now.
I am here again asking for help. I wanna use an if-else statement in order to compare my two temperatures values(t1 and pData) and in the case, the pData is greater than t1 led will turn on and in any other case the led will be off all the time.
We talked about using "float ble_data = atof((char*)pData);" as our final answer but now that I have already changed the code by adding a new void() I have no clue of what variable or function I can use in order to compare them but at the same time keeping the same architecture, because I spend much time figuring out how to send my two temperatures reading to Thinkspeak and serial monitor being synchronized and without any NAN or power problem.
Thanks very much for your support here is my code:
#include "WiFi.h"
#include "DHT.h"
#define DHTPIN 12
WiFiClient cliente;
int rele = 19;
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.println("Data sent");
void leer(){
Serial.print(t1);
connected = false;
return false;
return false;
connected = true;
doConnect = true;
doScan = true;
} // onResult
dht.begin();
Serial.print(".");
leer();
doConnect = false;
if (connected) {
}else if(doScan){
delay(1000); // Delay a second between loops.
} // End of loop
You can write a new function compare() which takes the result of the atof
and the t1 variable from leer() and do what you want with them.
Things will be easier if both the variable assigned the result of atof() and t1 are global, and not limited to the functions where they first appear and are typed.
I have already tried a few things and does not seem to be working. I cannot define the atof() or the t1 variable in the global because they miss a lot of characteristics that do not allow me to compile. What I've done at the end is define a new function as you said, integrating the protocol which comes with the notify callback function and adding to a new one. I redefine t1 and ble_data again and did the if-else but even when compiles it does not work.
here is the most updated code.
Note that I have added the compare(){}
Thanks for all the support
#include "WiFi.h"
#include "DHT.h"
#define DHTPIN 12
WiFiClient cliente;
int rele = 19;
static void notifyCallback(BLERemoteCharacteristic* pBLERemoteCharacteristic, uint8_t* pData, size_t length, bool isNotify) {
void read(){
Serial.print(t1);
void compare(BLERemoteCharacteristic* pBLERemoteCharacteristic, uint8_t* pData, size_t length, bool isNotify){
else{
connected = false;
return false;
return false;
connected = true;
doConnect = true;
doScan = true;
} // onResult
dht.begin();
Serial.print(".");
read();
doConnect = false;
if (connected) {
}else if(doScan){
} // End of loop
assign them values in the notifyCallback() and the read functions()
Use them them in compare() which becomes a function without parameters but instead uses the global variables. Call compare in loop().
#include "WiFi.h"
#include "DHT.h"
#define DHTPIN 12
WiFiClient cliente;
int rele = 19;
float t1;
float ble_data;
ThingSpeak.setField(1, (char*)pData);
void read()
//float t1 = dht.readTemperature();
Serial.print(t1);
ThingSpeak.setField(2, t1);
//void compare(BLERemoteCharacteristic* pBLERemoteCharacteristic, uint8_t* pData, size_t length, bool isNotify)
void compare( )
//float ble_data = atof((char*)pData);
if (ble_data > t1)
connected = false;
return false;
return false;
if (pRemoteCharacteristic->canRead())
if (pRemoteCharacteristic->canNotify())
connected = true;
class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks
doConnect = true;
doScan = true;
} // onResult
dht.begin();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
read();
compare();
ThingSpeak.writeFields(ID, APIKey);
doConnect = false;
if (connected)
String newValue = "Time since boot: " + String(millis() / 1000);
else if (doScan)
} // End of loop
The program compiles but it does not work. It might be because the values from ble_data and t1 work only inside their loop. I mean the variables are declared but the values of the readings are working only inside the notifyCallback and read functions.
I also tried my previous program the one before this. I forgot to call the compare() in the loop. Now that I did it I also have this error.
Compilation error: too few arguments to function 'void compare(BLERemoteCharacteristic*, uint8_t*, size_t, bool)'
The variables are global, and should be working outside of notifyCallback and read functions.
I think you already have printouts within those two functions, but can you add some additional serial prints to loop() or the compare() function to see what the values are and if they really are not persistent.
Are you certain that the relays work correctly?
Are you using the code I posted, or did you modify some code you already were using. If so, have you made certain there are not local scope variables called t1 or ble-data?
t1 is doing well on its own but ble_data gives me a 0.00 value coming from the global function. Even inside its original function, it gives me a value of 0.00
Here is the last code and its results:
#include "WiFi.h"
#include "DHT.h"
#define DHTPIN 12
WiFiClient cliente;
int rele = 19;
float t1;
float ble_data;
void read()
Serial.print(t1);
void compare()
Serial.print("Test t1");
Serial.print(t1);
Serial.print("Test ble_data");
Serial.print(ble_data);
if (ble_data > t1)
connected = false;
return false;
return false;
connected = true;
doConnect = true;
doScan = true;
} // onResult
dht.begin();
Serial.print(".");
read();
compare();
doConnect = false;
if (connected)
else if (doScan)
} // End of loop
The results are listed as:
Temperature 0.00
Temperature2 21.24
Test t1 21.24
Test ble_data 0.00
