Compilation error: missing terminating " character Web Server in ESP32 with HTML Codes
Hi Everyone, I am new to the community and exploring ESP32
Hope you can guys help me out in my error.
what i want to do is to have a webserver in esp32 and html to make 2 buttons to have 2 leds turn off and on. i dont get what is my error
#include <WiFi.h>
#include <WebServer.h>
#define gpio16LEDPin 16 /* One LED connected to GPIO16 - RX2 */
#define gpio17LEDPin 17 /* One LED connected to GPIO17 - TX2 */
const char* ssid = "Kurt's Galaxy S10"; /* Add your router's SSID */
const char* password = "13572468"; /*Add the password */
int gpio16Value;
int gpio17Value;
WiFiServer server(80); /* Instance of WiFiServer with port number 80 */
/* 80 is the Port Number for HTTP Web Server */
/* A String to capture the incoming HTTP GET Request */
String request;
Serial.begin(115200); /* Begin Serial Communication with 115200 Baud Rate */
/* Configure GPIO16 and GPIO17 Pins as OUTPUTs */
pinMode(gpio16LEDPin, OUTPUT);
pinMode(gpio17LEDPin, OUTPUT);
/* Set the initial values of GPIO16 and GPIO17 as LOW*/
/* Both the LEDs are initially OFF */
digitalWrite(gpio16LEDPin, LOW);
digitalWrite(gpio17LEDPin, LOW);
Serial.print("\n");
Serial.print("Connecting to: ");
Serial.println(ssid);
WiFi.mode(WIFI_STA); /* Configure ESP32 in STA Mode */
WiFi.begin(ssid, password); /* Connect to Wi-Fi based on the above SSID and Password */
while(WiFi.status() != WL_CONNECTED)
Serial.print("*");
delay(100);
Serial.print("\n");
Serial.print("Connected to Wi-Fi: ");
Serial.println(WiFi.SSID());
delay(100);
/* The next four lines of Code are used for assigning Static IP to ESP32 */
/* Do this only if you know what you are doing */
/* You have to check for free IP Addresses from your Router and */
/* assign it to ESP32 */
/* If you are comfortable with this step, */
/* please un-comment the next four lines and make necessary changes */
/* If not, leave it as it is and proceed */
//IPAddress ip(192,168,1,6);
//IPAddress gateway(192,168,1,1);
//IPAddress subnet(255,255,255,0);
//WiFi.config(ip, gateway, subnet);
delay(2000);
Serial.print("\n");
Serial.println("Starting ESP32 Web Server...");
espServer.begin(); /* Start the HTTP web Server */
Serial.println("ESP32 Web Server Started");
Serial.print("\n");
Serial.print("The URL of ESP32 Web Server is: ");
Serial.print("http://");
Serial.print("\n");
Serial.println("Use the above URL in your Browser to access ESP32 Web Server\n");
server.begin();
WiFiClient client = server.available(); /* Check if a client is available */
if(!client)
return;
Serial.println("New Client!!!");
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
request += c;
Serial.write(c);
/* if you've gotten to the end of the line (received a newline */
/* character) and the line is blank, the http request has ended, */
/* so you can send a reply */
if (c == '\n' && currentLineIsBlank)
/* Extract the URL of the request */
/* We have four URLs. If IP Address is 192.168.1.6 (for example),
* then URLs are:
* 192.168.1.6/GPIO16ON
* 192.168.1.6/GPIO16OFF
* 192.168.1.6/GPIO17ON
* 192.168.1.6/GPIO17OFF
/* Based on the URL from the request, turn the LEDs ON or OFF */
if (request.indexOf("/GPIO16ON") != -1)
Serial.println("GPIO16 LED is ON");
digitalWrite(gpio16LEDPin, HIGH);
gpio16Value = HIGH;
if (request.indexOf("/GPIO16OFF") != -1)
Serial.println("GPIO16 LED is OFF");
gpio16Value = LOW;
if (request.indexOf("/GPIO17ON") != -1)
Serial.println("GPIO17 LED is ON");
digitalWrite(gpio17LEDPin, HIGH);
gpio17Value = HIGH;
if (request.indexOf("/GPIO17OFF") != -1)
Serial.println("GPIO17 LED is OFF");
gpio17Value = LOW;
/* HTTP Response in the form of HTML Web Page */
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println(); // IMPORTANT
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>");
client.println("html { font-family: Courier New; display: inline-block; margin: 0px auto; text-align:
center;}");
client.println(".button {border: none; color: white; padding: 10px 20px; text-align: center;");
client.println("text-decoration: none; font-size: 25px; margin: 2px; cursor: pointer;}");
client.println(".button1 {background-color: #FF0000;}");
client.println(".button2 {background-color: #00FF00;}");
client.println("</style>");
client.println("</head>");
client.println("<body>");
client.println("<h2>ESP32 Web Server</h2>");
if(gpio16Value == LOW)
client.println("<p>GPIO16 LED Status: OFF</p>");
client.print("<p><a href=\"/GPIO16ON\"><button class=\"button button1\">Click to turn ON
</button></a></p>");
client.println("<p>GPIO16 LED Status: ON</p>");
client.print("<p><a href=\"/GPIO16OFF\"><button class=\"button button2\">Click to turn OFF
if(gpio17Value == LOW)
client.println("<p>GPIO17 LED Status: OFF</p>");
client.print("<p><a href=\"/GPIO17ON\"><button class=\"button button1\">Click to turn ON
client.println("<p>GPIO17 LED Status: ON</p>");
client.print("<p><a href=\"/GPIO17OFF\"><button class=\"button button2\">Click to turn OFF
client.println("</body>");
client.println("</html>");
if(c == '\n')
else if(c != '\r')
currentLineIsBlank = false;
//client.print("\n
delay(1);
request = "";
//client.flush();
client.stop();
Serial.println("Client disconnected");
Serial.print("\n");
Have you tried prepending the single quote after Kurt with a backslash?
Kurt\'s
Why would that be necessary?
The single quote had no special meaning in C++ (unlike, say, Python...)
Where, exactly, does it report that error?
The compiler output should show the line it's complaining about, and give a little pointer ^ to where it thinks the error is.
Copy & paste the full error, with the context - post it as code...
To eliminate possibilities... it will eventually be used in HTML, which might/might-not need the escaped quote.
