This sketch is part of a Binary Kaleidosciope Clock project. Changing colors of the 8,4,2,1 positions denote time changes. A new random color code number is compared to the lastColor of the respective digits, and a new color number is generated if the newColor == lastColor. There are only 11 colors, so the chances are good that it may take multiple random generations to get unmatched color for the change. I'm trying to test the coding, but can't get it to compile.
int newColor_8;
int newColor_4;
int newColor_2;
int newColor_1;
int lastColor_8 = 0;
int lastColor_4 = 0;
int lastColor_2 = 0;
int lastColor_1 = 0;
void setup(){
void loop(){
color_8_4();
color_8_2_1();
color_8_2();
color_8_1();
color_8();
color_4_2();
color_4_1();
color_4();
color_2_1();
color_2();
color_1();
// HOUR 12 Binary 8-4
void color_8_4(){
newColor_8 = random(11);
Serial.print("newColor_8 is");
Serial.print(newColor_8);
new_8_4();
Serial.print("lastColor_8");
Serial.print(lastColor_8);
while(lastColor_8 == newColor_8)
newColor_8 = random(11); // Generate new random color
newColor_4 = newColor_8;
Serial.print("newColor_4 is");
Serial.print(newColor_4);
Serial.print("lastColor_4");
Serial.print(lastColor_4);
while(lastColor_4 == newColor_4)
newColor_4 = random(11);
newColor_8 = newColor_4;
while (lastColor_8 == newColor_8 || lastColor_4 == newColor_4)
Serial.print("newtColor_4");
new_8_4();
Serial.print("newColor_8");
return;
// HOUR 11 Binary 8-2-1
void color_8_2_1() {
new_8_2_1();
newColor_2 = newColor_8;
newColor_1 = newColor_8;
while(lastColor_2 == newColor_2)
newColor_2 = random(11);
newColor_8 = newColor_2;
newColor_1 = newColor_2;
while (lastColor_8 == newColor_8 || lastColor_2 == newColor_2 || lastColor_1 == newColor_1)
new_8_2_1();
return;
// HOUR 10 Binary 8-2
void color_8_2() {
new_8_2();
while (lastColor_8 == newColor_8 || lastColor_2 == newColor_2)
new_8_2();
return;
// HOUR 9 Binary 8-1
void color_8_1() {
new_8_1();
while(lastColor_1 == newColor_1)
newColor_1 = random(11);
newColor_8 = newColor_1;
while (lastColor_8 == newColor_8 || lastColor_1 == newColor_1)
new_8_1();
return;
// HOUR 8 Binary 8
void color_8() {
return;
// HOUR 7 Binary 4-2-1
void color_4_2_1() {
new_4_2_1();
newColor_4 = random(11); // Generate new random color
newColor_2 = newColor_4;
newColor_1 = newColor_4;
newColor_4 = newColor_2;
while (lastColor_4 == newColor_4 || lastColor_2 == newColor_2 || lastColor_1 == newColor_1)
new_4_2_1();
return;
// HOUR 6 Binary 4-2
void color_4_2() {
new_4_2();
while (lastColor_4 == newColor_4 || lastColor_2 == newColor_2)
new_4_2();
return;
// HOUR 5 Binary 4-1
void color_4_1() {
newColor_4_1 = random(11);
new_4_1();
newColor_4 = newColor_1;
new_4_1();
return;
// HOUR 4 Binary 4
void color_4() {
return;
// HOUR 3 Binary 2-1
void color_2_1() {
new_2_1();
newColor_2 = random(11); // Generate new random color
newColor_2 = newColor_1;
while (lastColor_2 == newColor_2 || lastColor_1 == newColor_1)
new_2_1();
return;
// HOUR 2 Binary 2
void color_2() {
return;
// HOUR 1 Binary 1
void color_1() {
return;
Here are the errors:
newColor_v_1A_test.ino: In function 'void color_8_4()':
newColor_v_1A_test:37: error: 'new_8_4' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_8_2_1()':
newColor_v_1A_test:83: error: 'new_8_2_1' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_8_2()':
newColor_v_1A_test:111: error: 'new_8_2' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_8_1()':
newColor_v_1A_test:134: error: 'new_8_1' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_4_2_1()':
newColor_v_1A_test:167: error: 'new_4_2_1' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_4_2()':
newColor_v_1A_test:192: error: 'new_4_2' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_4_1()':
newColor_v_1A_test:213: error: 'newColor_4_1' was not declared in this scope
newColor_v_1A_test:214: error: 'new_4_1' was not declared in this scope
newColor_v_1A_test.ino: In function 'void color_2_1()':
newColor_v_1A_test:246: error: 'new_2_1' was not declared in this scope
Thanks very much for your time.
