Compilation error on code that was compiling before. "conversion from 'String' to non-scalar type"
Code that previously (2 weeks ago) was compiling without problems now suddenly gives this error message:
45 | std::string value = pLedCharacteristic->getValue();
exit status 1
Compilation error: conversion from 'String' to non-scalar type 'std::string' {aka 'std::__cxx11::basic_string'} requested
The code is from this randomnerd tutorial
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-web-bluetooth/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLEServer* pServer = NULL;
BLECharacteristic* pSensorCharacteristic = NULL;
BLECharacteristic* pLedCharacteristic = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value = 0;
const int ledPin = 2; // Use the appropriate GPIO pin for your setup
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID        "19b10000-e8f2-537e-4f6c-d104768a1214"
#define SENSOR_CHARACTERISTIC_UUID "19b10001-e8f2-537e-4f6c-d104768a1214"
#define LED_CHARACTERISTIC_UUID "19b10002-e8f2-537e-4f6c-d104768a1214"
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer) {
class MyCharacteristicCallbacks : public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic* pLedCharacteristic) {
        if (value.length() > 0) {
            Serial.print("Characteristic event, written: ");
            Serial.println(static_cast<int>(value[0])); // Print the integer value
            int receivedValue = static_cast<int>(value[0]);
            if (receivedValue == 1) {
                digitalWrite(ledPin, HIGH);
                digitalWrite(ledPin, LOW);
  pinMode(ledPin, OUTPUT);
  // Create the BLE Device
  BLEDevice::init("ESP32");
  // Create the BLE Server
  pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create the BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  // Create a BLE Characteristic
  pSensorCharacteristic = pService->createCharacteristic(
                      SENSOR_CHARACTERISTIC_UUID,
                      BLECharacteristic::PROPERTY_READ   |
                      BLECharacteristic::PROPERTY_WRITE  |
                      BLECharacteristic::PROPERTY_NOTIFY |
                      BLECharacteristic::PROPERTY_INDICATE
  // Create the ON button Characteristic
  pLedCharacteristic = pService->createCharacteristic(
                      LED_CHARACTERISTIC_UUID,
  // Register the callback for the ON button characteristic
  pLedCharacteristic->setCallbacks(new MyCharacteristicCallbacks());
  // https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
  // Create a BLE Descriptor
  pSensorCharacteristic->addDescriptor(new BLE2902());
  pLedCharacteristic->addDescriptor(new BLE2902());
  // Start the service
  pService->start();
  // Start advertising
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(false);
  pAdvertising->setMinPreferred(0x0);  // set value to 0x00 to not advertise this parameter
  BLEDevice::startAdvertising();
  Serial.println("Waiting a client connection to notify...");
    // notify changed value
    if (deviceConnected) {
        pSensorCharacteristic->setValue(String(value).c_str());
        pSensorCharacteristic->notify();
        value++;
        Serial.print("New value notified: ");
        Serial.println(value);
        delay(3000); // bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
    // disconnecting
    if (!deviceConnected && oldDeviceConnected) {
        Serial.println("Device disconnected.");
        delay(500); // give the bluetooth stack the chance to get things ready
        pServer->startAdvertising(); // restart advertising
        Serial.println("Start advertising");
        oldDeviceConnected = deviceConnected;
    // connecting
    if (deviceConnected && !oldDeviceConnected) {
        // do stuff here on connecting
        Serial.println("Device Connected");
Makes me think it is something related to updated libraries or board manager but reverting back to previous releases doesn't help. Any ideas what could be causing this?
I think that this change is what happened.
https://github.com/espressif/arduino-esp32/pull/8724
BREAKING CHANGE! Changed API return and parameter type from std::string to Arduino style String.
This will compile and run
//std::string value = pLedCharacteristic->getValue();
String value = pLedCharacteristic->getValue();
You saved my week! Thanks a lot!
they corrected the example ...
