Compilation error: 'PORTA' was not declared in this scope
// Pin Definitions
#define MAX7219_LOAD_PIN     PB0
#define MAX7219_CLK_PIN      PB1
#define MAX7219_DATA_PIN     PB2
#define TEMP_SET_SWITCH      PC0
#define TEMP_TOGGLE_SWITCH1  PA0
#define TEMP_TOGGLE_SWITCH2  PA1
#define MOTOR_SPEED_SWITCH1  PA2
#define MOTOR_SPEED_SWITCH2  PA3
#define BUZZER_PIN           PA4
#define LED1_PIN             PA5
#define LED2_PIN             PA6
#define LED3_PIN             PA7
#define MOTOR_SEGMENTS_PIN   PC1
// Global Variables
volatile uint8_t temperatureSet = 0;
volatile uint8_t temperatureReady = 0;
volatile uint8_t motorSpeed = 0;
// Function Declarations
void initGPIO();
void initADC();
void initSPI();
void initInterrupts();
void displayNumber(uint8_t number);
void buzzerOn();
void buzzerOff();
void motorSpeedControl();
int main() {
  // Initialize
  initGPIO();
  initADC();
  initSPI();
  initInterrupts();
  // Turn on LED1 to indicate power
  PORTA |= (1 << LED1_PIN);
  // Main Loop
  while (1) {
    // Read temperature sensor
    ADCSRA |= (1 << ADSC);  // Start ADC conversion
    while (ADCSRA & (1 << ADSC));  // Wait for conversion to complete
    uint16_t adcValue = ADC;
    // Calculate temperature
    float voltage = (adcValue * 5.0) / 1024.0;  // ADC reference voltage is 5V
    float resistance = (5.0 * 10000.0 / voltage) - 10000.0;  // NTC resistance
    float temperature = 1 / (1 / 298.15 + log(resistance / 100000.0) / 3950.0) - 273.15;  // NTC temperature equation
    // Check if temperature set switch is on
    if (temperatureSet) {
      // Set the temperature threshold (e.g., 25°C)
      if (temperature >= temperatureSet) {
        // Temperature threshold reached, turn on LED3
        PORTA |= (1 << LED3_PIN);
        temperatureReady = 1;
        // Temperature below threshold, turn off LED3
        PORTA &= ~(1 << LED3_PIN);
    // Check if temperature toggle switches are on
    if ((PINA & (1 << TEMP_TOGGLE_SWITCH1)) && (PINA & (1 << TEMP_TOGGLE_SWITCH2))) {
      // Both toggle switches are on, turn on heater
      // Either one or both toggle switches are off, turn off heater
    // Update motor speed based on the switches
    // Display motor speed on 2811AS seven-segment display
    displayNumber(motorSpeed);
    _delay_ms(100);  // Delay for stability
  return 0;
void initGPIO() {
  // Set pin directions
  DDRC |= (1 << MAX7219_LOAD_PIN) | (1 << MAX7219_CLK_PIN) | (1 << MAX7219_DATA_PIN);
  DDRA &= ~(1 << TEMP_SET_SWITCH) & ~(1 << TEMP_TOGGLE_SWITCH1) & ~(1 << TEMP_TOGGLE_SWITCH2) & ~(1 << MOTOR_SPEED_SWITCH1) & ~(1 << MOTOR_SPEED_SWITCH2);
  DDRA |= (1 << BUZZER_PIN) | (1 << LED1_PIN) | (1 << LED2_PIN) | (1 << LED3_PIN);
  DDRC |= (1 << MOTOR_SEGMENTS_PIN);
Welcome to the forum
Which Arduino board are you compiling this for ?
I am compiling for: ATTINY1634R
This code is not compatible for Attiny
Correction:
This code is not compatible with Attiny or with your attiny package installed.
What the package you used for Attiny 1634 ?
can i use it with atmega128
Arduino ide
Select the atmega128 in IDE and try to compile.
Bare Arduino IDE probably is not enough for this.
To work with Attiny-group controllers is strictly recommended to install a dedicated package, for example AttinyCore:
It would be better to use the code exactly with mcu to which it programmed.
Especially if you don't have a much expediency with micro-controllers.
Where did you find this code? Does the project have any description? Maybe it says what chip it is for?
No, the Megas and the Tinys are very different
When I try to compile the code I get an error for _delay_ms
If I comment that out it wont compile because of the missing bracket } at the end but nothing about PORTA
This is the complete code:
// ATTINY1634R Motor_Temperature Control Code
// Include required libraries
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <math.h>
// Pin Definitions
// Global Variables
void initGPIO();
void initADC();
void initSPI();
void buzzerOn();
void buzzerOff();
int main() {
  // Initialize
  initGPIO();
  initADC();
  initSPI();
  initInterrupts();
  // Main Loop
  while (1) {
  return 0;
void initGPIO() {
  // Enable internal pull-up resistors for switches
  PORTA |= (1 << TEMP_SET_SWITCH) | (1 << TEMP_TOGGLE_SWITCH1) | (1 << TEMP_TOGGLE_SWITCH2) | (1 << MOTOR_SPEED_SWITCH1) | (1 << MOTOR_SPEED_SWITCH2);
void initADC() {
  // Set voltage reference to AVCC
  ADMUX |= (1 << REFS0);
  // Enable ADC, enable ADC interrupts, and set ADC prescaler to 128
  ADCSRA |= (1 << ADEN) | (1 << ADIE) | (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
void initSPI() {
  // Set SPI pins as output
  DDRB |= (1 << MAX7219_LOAD_PIN) | (1 << MAX7219_CLK_PIN) | (1 << MAX7219_DATA_PIN);
  // Enable SPI, set as master, and set clock rate to fck/16
  SPCR |= (1 << SPE) | (1 << MSTR) | (1 << SPR0);
void initInterrupts() {
  // Enable external interrupts on INT0 (PA0)
  EIMSK |= (1 << INT0);
  // Trigger interrupt on any logical change
  EICRA |= (1 << ISC00);
  EICRA &= ~(1 << ISC01);
  // Enable global interrupts
  sei();
void displayNumber(uint8_t number) {
  // Send data to MAX7219 using SPI
  PORTC &= ~(1 << MAX7219_LOAD_PIN);  // Enable load pin
  // Send command for the first segment
  SPDR = 1;  // Register address
  while (!(SPSR & (1 << SPIF)));  // Wait for transmission to complete
  SPDR = number % 10;  // Data for the first segment
  // Send command for the second segment
  SPDR = 2;  // Register address
  SPDR = number / 10;  // Data for the second segment
  PORTC |= (1 << MAX7219_LOAD_PIN);  // Disable load pin
void buzzerOn() {
  PORTA |= (1 << BUZZER_PIN);
void buzzerOff() {
  PORTA &= ~(1 << BUZZER_PIN);
void motorSpeedControl() {
  // Read motor speed switches
  uint8_t speedSwitch1 = (PINA & (1 << MOTOR_SPEED_SWITCH1)) ? 1 : 0;
  uint8_t speedSwitch2 = (PINA & (1 << MOTOR_SPEED_SWITCH2)) ? 1 : 0;
  // Determine motor speed based on switch states
  if (!speedSwitch1 && !speedSwitch2) {
    motorSpeed = 0;  // Speed 0
  } else if (!speedSwitch1 && speedSwitch2) {
    motorSpeed = 1;  // Speed 1
  } else if (speedSwitch1 && !speedSwitch2) {
    motorSpeed = 2;  // Speed 2
  } else if (speedSwitch1 && speedSwitch2) {
    motorSpeed = 3;  // Speed 3
// Interrupt Service Routine for temperature set switch
ISR(INT0_vect) {
  // Toggle temperature set
  temperatureSet = !temperatureSet;
  // Turn on LED2 to indicate temperature set
  PORTA ^= (1 << LED2_PIN);
  // Generate a short beep
  buzzerOn();
  _delay_ms(100);
  buzzerOff();
// Interrupt Service Routine for ADC conversion complete
ISR(ADC_vect) {
  // ADC conversion complete
  // Handle any necessary actions here
Try to install package from the post #8
What procedure are you using to compile?
When I use ATtinyCore (as people are suggesting), I get a bunch of errors related to to your SPI initialization - that's because the 1634 doesn't have an "SPI" peripheral; it has a USI that can be used for SPI. (which is weird; usually the chips that have USI are deficient in other peripherals as well, being really "bare bones." But the 1634 has TWI and 2(!) UARTs...)
