Compilation error: read ECONNRESET
Heya all
So for the past few weeks(!) I've been getting a now very annoying error message:
read ECONNRESET
This happens when I compile my code (ANY piece of code), regardless of whether or not a board is connected. It works fine on a new install once, after that the message-madness ensues.
However after this it gets even stranger, because any subsequent attempt at compiling without restarting the software will result in the error-message:
No connection established
Compilation error: No connection established
I am at an absolute loss. I've tried to search online for solutions but have found little to no helpfull advice, I've checked the code with some other students and my professor and it seems to work there, so whatever is wrong is with the software install itself but I do not know what.
Things to note are:
  • As of writting this, I am running Arduino IDE 2.0.4 on Windows 11Pro 22H2
  • The software has been uninstalled and reinstalled( with different setting each time) multiple times
  • reinstalling/updateing the software allows me to compile my code once, after that the nonsense starts
  • ECONNRESET only appears once as the error, after that it's a connection error
  • The selected board is an Arduino Nano
  • Files are stored localy
  • libraries are stored localy
Any help is appreciated.
Love
DerpingLizzy
Hi @derpinlizzy. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<username>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  7. Wait for Arduino IDE to finish starting.
  8. Perform the operations required to produce the "No connection established" error, just as you did before.
  9. Switch back to the PowerShell window.
  10. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  11. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  12. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  13. Open a forum reply here by clicking the Reply button.
  14. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  15. Press Ctrl+V.
    This will paste the output into the code block.
  16. Move the cursor outside of the code block markup before you add any additional text to your reply.
  17. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hello @ptillisch
Here is the additional information you requested:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.4
Starting backend process. PID: 17020
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Naomi%20Moser/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-03-30T07:50:36.127Z root INFO Backend Object.initialize: 5.8 ms [Finished 2.064 s after backend start]
2023-03-30T07:50:36.127Z root INFO Backend Object.configure: 4.7 ms [Finished 2.064 s after backend start]
2023-03-30T07:50:36.127Z root INFO Backend MessagingContribution.onStart: 2.3 ms [Finished 2.064 s after backend start]
2023-03-30T07:50:36.129Z root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 2.117 s after backend start]
2023-03-30T07:50:36.130Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.117 s after backend start]2023-03-30T07:50:36.131Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 2.117 s after backend start]
2023-03-30T07:50:36.132Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 52.5 ms [Finished 2.117 s after backend start]
2023-03-30T07:50:36.133Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.3 ms [Finished 2.117 s after backend start]
2023-03-30T07:50:36.134Z root INFO Backend ElectronTokenBackendContribution.configure: 1.6 ms [Finished 2.119 s after backend start]
2023-03-30T07:50:36.135Z config INFO >>> Initializing CLI configuration...
2023-03-30T07:50:36.135Z root INFO Backend PluginDeployerContribution.initialize: 0.8 ms [Finished 2.119 s after backend start]
2023-03-30T07:50:36.137Z root INFO Backend ConfigServiceImpl.onStart: 1.2 ms [Finished 2.120 s after backend start]
2023-03-30T07:50:36.138Z config INFO Loading CLI configuration from c:\Users\Naomi Moser\.arduinoIDE\arduino-cli.yaml...2023-03-30T07:50:36.139Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.5 ms [Finished 2.122 s after backend start]
2023-03-30T07:50:36.140Z root INFO Backend ArduinoDaemonImpl.onStart: 1.6 ms [Finished 2.123 s after backend start]
2023-03-30T07:50:36.140Z root INFO Backend NodeFileUploadService.configure: 3.0 ms [Finished 2.123 s after backend start]
2023-03-30T07:50:36.140Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-03-30T07:50:36.141Z discovery-log INFO start
2023-03-30T07:50:36.141Z discovery-log INFO start new deferred
2023-03-30T07:50:36.141Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 2.125 s after backend start]
2023-03-30T07:50:36.141Z root INFO Backend BoardDiscovery.onStart: 1.9 ms [Finished 2.126 s after backend start]
2023-03-30T07:50:36.142Z root INFO Backend FileDownloadEndpoint.configure: 2.2 ms [Finished 2.127 s after backend start]2023-03-30T07:50:36.142Z root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 2.130 s after backend start]
2023-03-30T07:50:36.142Z root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 2.130 s after backend start]
2023-03-30T07:50:36.144Z root INFO Backend HostedPluginReader.configure: 0.9 ms [Finished 2.132 s after backend start]
2023-03-30T07:50:36.144Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.133 s after backend start]
2023-03-30T07:50:36.144Z root INFO Backend PlotterBackendContribution.configure: 1.4 ms [Finished 2.134 s after backend start]
2023-03-30T07:50:36.148Z root INFO Theia app listening on http://localhost:59986.
2023-03-30T07:50:36.148Z root INFO Finished starting backend application: 7.4 ms [Finished 2.139 s after backend start]
2023-03-30T07:50:36.151Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Naomi%20Moser/.arduinoIDE/plugins does not exist.
2023-03-30T07:50:36.161Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Naomi%20Moser/.arduinoIDE/extensions does not exist.
2023-03-30T07:50:36.162Z root WARN The local plugin referenced by local-dir:C:\Users\Naomi Moser\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\Naomi Moser\Documents\Informatik Praxis\Arduino\Nunchuck_read_n_print
isTempSketch: false. Input was c:\Users\Naomi Moser\Documents\Informatik Praxis\Arduino\Nunchuck_read_n_print\Nunchuck_read_n_print.ino
2023-03-30T07:50:36.197Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.198Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-03-30T07:50:36.198Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.198Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.7" with engines:
2023-03-30T07:50:36.199Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-03-30T07:50:36.199Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.199Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-03-30T07:50:36.200Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-03-30T07:50:36.200Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.200Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-03-30T07:50:36.200Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-03-30T07:50:36.201Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.201Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-03-30T07:50:36.203Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.203Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-03-30T07:50:36.204Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.204Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-03-30T07:50:36.205Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-03-30T07:50:36.205Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.205Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-03-30T07:50:36.206Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.206Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-03-30T07:50:36.207Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.207Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-03-30T07:50:36.207Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-03-30T07:50:36.208Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.208Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-03-30T07:50:36.209Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-03-30T07:50:36.210Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.210Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-03-30T07:50:36.210Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-03-30T07:50:36.211Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-03-30T07:50:36.212Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-30T07:50:36.212Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-03-30T07:50:36.221Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\Naomi Moser\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-03-30T07:50:36.224Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-03-30T07:50:36.225Z config INFO Loaded the CLI configuration.
2023-03-30T07:50:36.259Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Naomi%20Moser/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Naomi%20Moser/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-03-30T07:50:36.263Z config INFO Validating the CLI configuration...
2023-03-30T07:50:36.268Z config INFO The CLI config is valid.
2023-03-30T07:50:36.275Z config INFO <<< Initialized the CLI configuration.
2023-03-30T07:50:36.303Z root INFO Resolve plugins list: 164.9 ms [Finished 2.293 s after backend start]
2023-03-30T07:50:36.312Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 8.7 ms [Finished 2.302 s after backend start]
2023-03-30T07:50:36.317Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.7" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 5.1 ms [Finished 2.308 s after backend start]
2023-03-30T07:50:36.332Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 14.9 ms [Finished 2.322 s after backend start]
2023-03-30T07:50:36.336Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 4.3 ms [Finished 2.327 s after backend start]
2023-03-30T07:50:36.337Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.2 ms [Finished 2.328 s after backend start]
2023-03-30T07:50:36.450Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 112.4 ms [Finished 2.441 s after backend start]
2023-03-30T07:50:36.476Z daemon INFO INFO[0000] Using config file: c:\Users\Naomi Moser\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.31.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"59987"}
2023-03-30T07:50:36.477Z daemon INFO Daemon is running.
2023-03-30T07:50:36.596Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 146.4 ms [Finished 2.587 s after backend start]
2023-03-30T07:50:36.608Z daemon INFO INFO[0000] Loading hardware from: c:\Users\Naomi Moser\AppData\Local\Arduino15\packages
2023-03-30T07:50:36.765Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 168.8 ms [Finished 2.756 s after backend start]
2023-03-30T07:50:36.766Z daemon INFO INFO[0000] Loading package arduino from: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\Naomi Moser\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0000] Checking signature                            index="c:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Loading libraries index file                  index="c:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\library_index.json"
2023-03-30T07:50:36.868Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 102.4 ms [Finished 2.858 s after backend start]
2023-03-30T07:50:36.869Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="c:\\Users\\Naomi Moser\\Arduino\\libraries" location=user
2023-03-30T07:50:36.981Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 113.0 ms [Finished 2.972 s after backend start]
2023-03-30T07:50:37.049Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 67.6 ms [Finished 3.039 s after backend start]
2023-03-30T07:50:37.142Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 92.8 ms [Finished 3.132 s after backend start]
2023-03-30T07:50:37.145Z discovery-log INFO start request start watch
2023-03-30T07:50:37.146Z discovery-log INFO start requested start watch
2023-03-30T07:50:37.146Z discovery-log INFO start resolved watching
2023-03-30T07:50:37.243Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 101.2 ms [Finished 3.233 s after backend start]
2023-03-30T07:50:37.244Z daemon INFO INFO[0000] starting discovery builtin:mdns-discovery process
INFO[0000] starting discovery builtin:serial-discovery process
INFO[0000] started discovery builtin:serial-discovery process
INFO[0000] started discovery builtin:mdns-discovery process
INFO[0000] sending command HELLO 1 "arduino-cli 0.31.0" to discovery builtin:mdns-discovery
INFO[0000] sending command HELLO 1 "arduino-cli 0.31.0" to discovery builtin:serial-discovery
INFO[0000] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0000] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0000] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0000] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-03-30T07:50:37.345Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 101.8 ms [Finished 3.335 s after backend start]
2023-03-30T07:50:37.387Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 42.1 ms [Finished 3.377 s after backend start]
2023-03-30T07:50:37.475Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 88.2 ms [Finished 3.466 s after backend start]
2023-03-30T07:50:37.570Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 94.5 ms [Finished 3.560 s after backend start]
2023-03-30T07:50:37.665Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 95.6 ms [Finished 3.656 s after backend start]
2023-03-30T07:50:37.745Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 79.3 ms [Finished 3.735 s after backend start]
2023-03-30T07:50:37.796Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 51.5 ms [Finished 3.787 s after backend start]
2023-03-30T07:50:37.898Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 102.0 ms [Finished 3.889 s after backend start]
2023-03-30T07:50:37.899Z root INFO Deploy plugins list: 164.9 ms [Finished 3.889 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-03-30T07:50:38.546Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 270.0 ms [Finished 2.266 s after frontend start]
2023-03-30T07:50:38.688Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\Naomi Moser\Documents\Informatik Praxis\Arduino\Nunchuck_read_n_print\Nunchuck_read_n_print.ino>, response: <c:\Users\Naomi Moser\Documents\Informatik Praxis\Arduino\Nunchuck_read_n_print>.
2023-03-30T07:50:38.829Z root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 191.4 ms [Finished 2.586 s after frontend start]
2023-03-30T07:50:38.857Z root INFO Start frontend contributions: 694.6 ms [Finished 2.593 s after frontend start]
2023-03-30T07:50:38.859Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-03-30T07:50:38.880Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-03-30T07:50:38.882Z root INFO >>> Restoring the layout state...
2023-03-30T07:50:38.882Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-03-30T07:50:38.882Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Naomi%20Moser/Documents/Informatik%20Praxis/Arduino/Nunchuck_read_n_print/Nunchuck_read_n_print.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":10,\"column\":10},\"position\":{\"lineNumber\":10,\"column\":10}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":2,\"column\":1},\"firstPositionDeltaTop\":-11},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":31,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":272,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"},\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2023-03-30T07:50:38.885Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-03-30T07:50:38.948Z root INFO [d300288c-d615-4acc-92cf-bce278854d97] Waiting for backend deployment: 116.8 ms [Finished 2.705 s after frontend start]
2023-03-30T07:50:39.423Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408) starting instance
2023-03-30T07:50:39.894Z root INFO [d300288c-d615-4acc-92cf-bce278854d97] Sync of 21 plugins: 950.3 ms [Finished 3.655 s after frontend start]
2023-03-30T07:50:40.177Z root INFO <<< The layout has been successfully restored.
2023-03-30T07:50:40.303Z root INFO Initialize the workbench layout: 1311.3 ms [Finished 3.939 s after frontend start]
2023-03-30T07:50:40.306Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-03-30T07:50:40.307Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][marus25.cortex-debug]: Loaded contributions.
2023-03-30T07:50:40.308Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][arduino.vscode-arduino-tools]: Loaded contributions.
2023-03-30T07:50:40.309Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.cpp]: Loaded contributions.
2023-03-30T07:50:40.309Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.json]: Loaded contributions.
2023-03-30T07:50:40.309Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.json-language-features]: Loaded contributions.
2023-03-30T07:50:40.310Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-03-30T07:50:40.315Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-03-30T07:50:40.315Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-03-30T07:50:40.315Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-03-30T07:50:40.315Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-03-30T07:50:40.316Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-03-30T07:50:40.316Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-03-30T07:50:40.316Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-03-30T07:50:40.316Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-03-30T07:50:40.317Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-03-30T07:50:40.318Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-03-30T07:50:40.318Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-03-30T07:50:40.319Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-03-30T07:50:40.319Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-03-30T07:50:40.319Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-03-30T07:50:40.320Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-03-30T07:50:40.320Z root INFO [d300288c-d615-4acc-92cf-bce278854d97] Load contributions of 21 plugins: 122.1 ms [Finished 4.062 s after frontend start]
2023-03-30T07:50:40.380Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-03-30T07:50:40.381Z root WARN a registered grammar configuration for 'cpp' language is overridden
[18568:0330/095040.482:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2023-03-30T07:50:40.812Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): PluginManagerExtImpl/init()
2023-03-30T07:50:40.816Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.823Z root INFO [hosted-plugin: 16408] Debugger contribution has been registered: cortex-debug
2023-03-30T07:50:40.825Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-arduino-tools@0.0.2-beta.7 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.827Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.828Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.829Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.830Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.831Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.832Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.834Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.835Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.837Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.838Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.839Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.840Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.841Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.842Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.843Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.844Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.845Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.845Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.847Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-03-30T07:50:40.850Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-03-30T07:50:40.929Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-03-30T07:50:40.957Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][marus25.cortex-debug]: Started plugin.
2023-03-30T07:50:40.958Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][arduino.vscode-arduino-tools]: Started plugin.2023-03-30T07:50:40.958Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.cpp]: Started plugin.
2023-03-30T07:50:40.959Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.json]: Started plugin.
2023-03-30T07:50:40.959Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][vscode.json-language-features]: Started plugin.
2023-03-30T07:50:40.959Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-03-30T07:50:40.959Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-03-30T07:50:40.962Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-03-30T07:50:40.962Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-03-30T07:50:40.963Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-03-30T07:50:40.963Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-03-30T07:50:40.963Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-03-30T07:50:40.963Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-03-30T07:50:40.964Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-03-30T07:50:40.964Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-03-30T07:50:40.964Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-03-30T07:50:40.964Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-03-30T07:50:40.965Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-03-30T07:50:40.965Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-03-30T07:50:40.965Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-03-30T07:50:40.965Z root INFO [d300288c-d615-4acc-92cf-bce278854d97][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-03-30T07:50:40.972Z root INFO [hosted-plugin: 16408] PLUGIN_HOST(16408): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-03-30T07:50:41.013Z root INFO [hosted-plugin: 16408] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-03-30T07:50:41.017Z root INFO [hosted-plugin: 16408] GDB server console created
2023-03-30T07:50:41.030Z root INFO [d300288c-d615-4acc-92cf-bce278854d97] Start of 21 plugins: 716.8 ms [Finished 4.792 s after frontend start]
[18568:0330/095041.589:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.606:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.633:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2023-03-30T07:50:41.643Z root INFO Frontend application start: 3153.3 ms [Finished 7.632 s after backend start]
2023-03-30T07:50:41.649Z root INFO Replace loading indicator with ready workbench UI (animation): 868.1 ms [Finished 4.933 s after frontend start]
2023-03-30T07:50:41.649Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-03-30T07:50:41.650Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
[18568:0330/095041.659:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.689:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
Checking for update
[18568:0330/095041.757:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.788:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.832:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.880:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.904:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.928:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095041.961:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095042.011:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095042.041:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095042.075:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2023-03-30T07:50:42.101Z fwuploader ERROR Error: Error executing "C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: unexpected end of JSON input
    at ChildProcess.<anonymous> (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\exec-util.js:53:31)
    at ChildProcess.emit (node:events:394:28)
    at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
2023-03-30T07:50:42.101Z root ERROR Request updatableBoards failed with error: Error executing "C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: unexpected end of JSON input
[18568:0330/095042.111:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095042.138:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2023-03-30T07:50:42.144Z root INFO Starting language server: arduino:avr:nano:cpu=atmega328
[18568:0330/095042.195:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095042.240:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
Update for version 2.0.4 is not available (latest version: 2.0.4, downgrade is allowed).
2023-03-30T07:50:42.916Z root ERROR ---- !!!SLOW!!! DURATION: search took 950.026 ms. Args: [{"type":"Updatable"}] ----
2023-03-30T07:50:43.293Z daemon INFO INFO[0006] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
INFO[0006] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0006] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-03-30T07:50:43.294Z daemon INFO INFO[0006] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0006] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0006] Adding libraries dir                          dir="c:\\Users\\Naomi Moser\\Arduino\\libraries" location=user
2023-03-30T07:50:43.586Z daemon INFO INFO[0007] Resolving include ArduinoNunchuk.h for arch avr
INFO[0007]   found better lib                            lib=ArduinoNunchuk prio=643
2023-03-30T07:50:43.808Z daemon INFO INFO[0007] Resolving include Wire.h for arch avr
INFO[0007]   found better lib                            lib=Wire prio=64C
2023-03-30T07:50:44.876Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
INFO[0008] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
[18568:0330/095111.130:ERROR:acce:::[19244:0330/095234.164:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is 1.165Z daemon INFO INFO[0034] Required tool                                 tool="arduino:arduinoOTA@1
.3.0"                            :::
INFO[0034] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-03-30T07:51:11.167Z daemon INFO INFO[0034] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
INFO[0034] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0034] Adding libraries dir                          dir="C:\\Users\\Naomi Moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0034] Adding libraries dir                          dir="c:\\Users\\Naomi Moser\\Arduino\\libraries" location=user
2023-03-30T07:51:11.626Z discovery-log INFO error received
2023-03-30T07:51:11.626Z discovery-log ERROR Unexpected error occurred during the boards discovery.
2023-03-30T07:51:11.626Z discovery-log INFO received end
2023-03-30T07:51:11.627Z root ERROR Have not received the build path from the CLI while running the compilation.
2023-03-30T07:51:11.652Z daemon INFO Daemon exited with exit code: 3221226505.
[18568:0330/095111.698:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[18568:0330/095113.576:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2023-03-30T07:51:13.594Z root ERROR Have not received the build path from the CLI while running the compilation.
[18568:0330/095113.656:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
I hope this help
Lizzy
