This code was created by DIY Machines (youtuber) 4 years ago. I've been running into few errors when compiling and can't get past this one. I'm very new at this world of coding so I'd appreciate any guidance
. Thank you.
Error msg:
In file included from C:\Users\XXXXX\Documents\Arduino\wemos\wemos.ino:7:
C:\Users\XXXXX\Documents\Arduino\wemos\Switch.h:11:7: error: redefinition of 'class Switch'
11 | class Switch {
#ifndef SWITCH_H
#define SWITCH_H
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiUDP.h>
#include "CallbackFunction.h"
class Switch {
private:
ESP8266WebServer *server = NULL;
WiFiUDP UDP;
String serial;
String persistent_uuid;
String device_name;
unsigned int localPort;
CallbackFunction onCallback;
CallbackFunction offCallback;
bool switchStatus;
void startWebServer();
void handleEventservice();
void handleUpnpControl();
void handleRoot();
void handleSetupXml();
public:
Switch();
Switch(String alexaInvokeName, unsigned int port, CallbackFunction onCallback, CallbackFunction offCallback);
~Switch();
String getAlexaInvokeName();
void serverLoop();
void respondToSearch(IPAddress& senderIP, unsigned int senderPort);
void sendRelayState();
#endif
b707
April 3, 2023, 6:23pm
2
Please show the whole code rather than one class
wemos.ino code
#include <avdweb_Switch.h>
#include <WiFiUdp.h>
#include <functional>
#include "switch.h"
#include "UpnpBroadcastResponder.h"
// prototypes
boolean connectWifi();
//on/off callbacks
bool deckingCurtainOn();
bool deckingCurtainOff();
// Change this before you flash
const char* ssid = "xxxxx";
const char* password = "xxxxx";
boolean wifiConnected = false;
UpnpBroadcastResponder upnpBroadcastResponder;
Switch *office = NULL;
//Switch *kitchen = NULL;
bool isdeckingCurtainOn = false;
//bool isKitchenLightstsOn = false;
// Motor -------------------------
#define SLEEP 16 //6 actually enable
#define STEP 13 //4
#define DIR 0 //2
#define STEPS_PER_ROTATION 300
boolean outstandingWork = false;
unsigned long TimerTravel; //"ALWAYS use unsigned long for timers"
//End of motor--------------------
// Initialise wifi connection
wifiConnected = connectWifi();
if(wifiConnected){
upnpBroadcastResponder.beginUdpMulticast();
// Define your switches here. Max 10
// Format: Alexa invocation name, local port no, on callback, off callback
office = new Switch("deckingcurtains", 80, deckingCurtainOn, deckingCurtainOff);
Serial.println("Adding switches upnp broadcast responder");
upnpBroadcastResponder.addDevice(*office);
// upnpBroadcastResponder.addDevice(*kitchen);
pinMode(SLEEP,OUTPUT);
pinMode(STEP,OUTPUT);
pinMode(DIR,OUTPUT);
//end motor ---------------
if(wifiConnected){
upnpBroadcastResponder.serverLoop();
office->serverLoop();
if (((millis()-TimerTravel) <= 7100UL) && (outstandingWork == true)) // Set the 'UL' figure to the tine it takes to open or close your curtain
Serial.println(F("Moving Curtain"));
moveCurtain();
//Serial.println(F("Finished doing my work!"));
//Serial.println(F("SLEEP HIGH"));
digitalWrite(SLEEP,HIGH);
bool deckingCurtainOn() {
Serial.println("Switch 1 turn on ...");
Serial.print("Curtain turned on.... Closing the curtain...");
closeCurtain();
isdeckingCurtainOn = true;
return isdeckingCurtainOn;
bool deckingCurtainOff() {
Serial.println("Switch 1 turn off ...");
Serial.print("Curtain turned off... Opening the curtain...");
openCurtain();
// connect to wifi – returns true if successful or false if not
boolean connectWifi(){
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting ...");
Serial.print(".");
if (i > 10){
state = false;
i++;
if (state){
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
else {
Serial.println("");
Serial.println("Connection failed.");
return state;
void openCurtain() {
Serial.print("Still Opening the curtain...");
Serial.println(F("dir HIGH"));
digitalWrite(DIR,HIGH);
TimerTravel= millis();
Serial.println(F("SLEEP LOW"));
digitalWrite(SLEEP,LOW);
outstandingWork = true;
//delay(1000); // waits for a second
void closeCurtain() {
Serial.print("Still closing the curtain...");
Serial.println(F("dir LOW"));
digitalWrite(DIR,LOW);
// for the motor -------------
void stepNow(int totalSteps) {
Serial.print(totalSteps);
Serial.println(F(" steps."));
int i;
for(i=0;i<totalSteps;++i) {
digitalWrite(STEP,HIGH);
delayMicroseconds(1100);
digitalWrite(STEP,LOW);
void moveCurtain() {
delayMicroseconds(500);
stepNow(STEPS_PER_ROTATION);
avdweb_Switch .h defines a class Switch .
The code you posted in #1 above looks like it might be your swicht .h , which also defines a class Switch .
So pick a unique name. Or use one or the other.
What is switch .h for?
Where did you get the code that brought you this far?
a7
Thank you so much. I must've added when trying to figure out which libraries to upload. The code is created by DIY Machines, a youtuber. This is a DIY tutorial on making a Alexa Curtain Control System.
system
Closed
September 30, 2023, 7:37pm
6
