Compilation error: text section exceeds available space in board
je ne comprends pas pouvez vous m'aidez mon code est tout petit
#include "BluetoothSerial.h"
#include "esp_bt_main.h"
#include "esp_bt_device.h"
#include <WiFi.h>
String  Data;
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
void printDeviceAddress() {
const uint8_t* point = esp_bt_dev_get_address();
for (int i = 0; i < 6; i++) {
   char str[3];
   sprintf(str, "%02X", (int)point[i]);
   Serial.print(str);
   if (i < 5){
   Serial.print(":");}
IPAddress staticIP428_20(192,168,1,20);
IPAddress gateway428_20(192,168,1,1);
IPAddress subnet428_20(255,255,255,0);
WiFiClient client;
String myurl = "/";
void close_door() {
  myurl += "close";
  client.print(String("GET ") + myurl + " HTTP/1.1\r\n" +
            "Host: " + "192.168.1.10" + "\r\n" +
           "Connection: close\r\n\r\n");
  myurl="/";
void GO_TO() {
Data = "";
pinMode(22, OUTPUT);
pinMode(21, OUTPUT);
  Serial.println("start");
  SerialBT.begin("Friends Loop");
  printDeviceAddress();
  WiFi.begin("Friends LOOP","123456789");
  WiFi.config(staticIP428_20, gateway428_20, subnet428_20);
    if (SerialBT.available()) {
      client.connect("192.168.1.10", 80);
      Data = (SerialBT.readString());
      Serial.println(Data);
      if (Data == "gare") {
        GO_TO();
      } else if (Data == "gelos") {
        GO_TO();
      } else if (Data == "close") {
        close_door();
        digitalWrite(22,LOW);
        digitalWrite(21,LOW);
error code
  `Le croquis utilise 1677237 octets (127%) de l'espace de stockage de programmes. Le maximum est de 1310720 octets.
Les variables globales utilisent 59468 octets (18%) de mémoire dynamique, ce qui laisse 268212 octets pour les variables locales. Le maximum est de 327680 octets.
Croquis trop gros; vois https://support.arduino.cc/hc/en-us/articles/360013825179 pour des conseils de réduction.
Compilation error: text section exceeds available space in board`
Post mis dans la mauvaise section, on parle anglais dans les forums généraux, je viens de déplacer le post dans la section francophone.
Merci de prendre en compte les recommandations listées dans "Les bonnes pratiques du Forum Francophone".
J'ai copié votre code et je l'ai construit. C'est quand même énorme, mais 95% et non 127%.
Bonjour
en apperence oui, en réalité non
Les bibliothèques Bluetooth pour ESP32 occupent beaucoup de place en mémoire Flash
Un programme avec Bluetooth et WiFI est toujours de fait un 'gros' programme
Toutes les cartes avec des ESP32 n'offrent pas la même taille de mémoire Flash
Pour une carte donnée il esiste plusieurs options d'utilisation de la mémoire Flash:
avec ou sans OTA ? taille réservée un système de fichiers ?.......
Voir 'Partition scheme' dans le menu de l'IDE
Lire ceci dans la console :
laisse penser que le choix actuel de partitionnement limite fortement (1/3) la part de mémoire Flash allouée au code.... à supposer que la carte utilisée offre 4MB de mémoire Flash
et comment peut-on augmenter cet espace
dans le menu Tools/Partition Scheme , choisir une option attribuant plus de memoire Flash au code et moins au reste (OTA, Fichiers...)
Quelle carte est utilisée ? (on trouve des microcontrolleurs ESP32 sur un grand nombre de cartes différentes)
Quelles sont les options 'Partition Scheme' pour cette carte ?
Souvent une des options permet d'allouer environ 3MB au code
