Compilation error UIKit/UIKit.h: No such file or directory
i use pulseoximeter code to find hr and spo2
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include "MAX30102.h"
#include "Pulse.h"
#include <avr/pgmspace.h>
#include <EEPROM.h>
#include <avr/sleep.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
SSD1306 oled;
MAX30102 sensor;
Pulse pulseIR;
Pulse pulseRed;
MAFilter bpm;
#define LED LED_BUILTIN
#define BUTTON 3
#define OPTIONS 7
static const uint8_t heart_bits[] PROGMEM = { 0x00, 0x00, 0x38, 0x38, 0x7c, 0x7c, 0xfe, 0xfe, 0xfe, 0xff,
                                        0xfe, 0xff, 0xfc, 0x7f, 0xf8, 0x3f, 0xf0, 0x1f, 0xe0, 0x0f,
                                        0xc0, 0x07, 0x80, 0x03, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
                                        0x00, 0x00 };
//spo2_table is approximated as  -45.060*ratioAverage* ratioAverage + 30.354 *ratioAverage + 94.845 ;
const uint8_t spo2_table[184] PROGMEM =
        { 95, 95, 95, 96, 96, 96, 97, 97, 97, 97, 97, 98, 98, 98, 98, 98, 99, 99, 99, 99,
          99, 99, 99, 99, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100,
          100, 100, 100, 100, 99, 99, 99, 99, 99, 99, 99, 99, 98, 98, 98, 98, 98, 98, 97, 97,
          97, 97, 96, 96, 96, 96, 95, 95, 95, 94, 94, 94, 93, 93, 93, 92, 92, 92, 91, 91,
          90, 90, 89, 89, 89, 88, 88, 87, 87, 86, 86, 85, 85, 84, 84, 83, 82, 82, 81, 81,
          80, 80, 79, 78, 78, 77, 76, 76, 75, 74, 74, 73, 72, 72, 71, 70, 69, 69, 68, 67,
          66, 66, 65, 64, 63, 62, 62, 61, 60, 59, 58, 57, 56, 56, 55, 54, 53, 52, 51, 50,
          49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 31, 30, 29,
          28, 27, 26, 25, 23, 22, 21, 20, 19, 17, 16, 15, 14, 12, 11, 10, 9, 7, 6, 5,
          3, 2, 1 } ;
int getVCC() {
  //reads internal 1V1 reference against VCC
  #if defined(__AVR_ATmega1284P__)
    ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  // For ATmega1284
  #else
    ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  // For ATmega328
  #endif
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA, ADSC));
  uint8_t low = ADCL;
  unsigned int val = (ADCH << 8) | low;
  //discard previous result
  low = ADCL;
  return (((long)1024 * 1100) / val)/100;
void print_digit(int x, int y, long val, char c=' ', uint8_t field = 3,const int BIG = 2)
    uint8_t ff = field;
    do {
        char ch = (val!=0) ? val%10+'0': c;
        oled.drawChar( x+BIG*(ff-1)*6, y, ch, BIG);
        val = val/10;
        --ff;
    } while (ff>0);
 *   Record, scale  and display PPG Wavefoem
const uint8_t MAXWAVE = 72;
class Waveform {
  public:
    Waveform(void) {wavep = 0;}
      void record(int waveval) {
        waveval = waveval/8;         // scale to fit in byte  缩放以适合字节
        waveval += 128;              //shift so entired waveform is +ve
        waveval = waveval<0? 0 : waveval;
        waveform[wavep] = (uint8_t) (waveval>255)?255:waveval;
        wavep = (wavep+1) % MAXWAVE;
      void scale() {
        uint8_t maxw = 0;
        uint8_t minw = 255;
        for (int i=0; i<MAXWAVE; i++) {
          maxw = waveform[i]>maxw?waveform[i]:maxw;
          minw = waveform[i]<minw?waveform[i]:minw;
        uint8_t scale8 = (maxw-minw)/4 + 1;  //scale * 8 to preserve precision
        uint8_t index = wavep;
          disp_wave[i] = 31-((uint16_t)(waveform[index]-minw)*8)/scale8;
          index = (index + 1) % MAXWAVE;
void draw(uint8_t X) {
    uint8_t y = disp_wave[i];
    oled.drawPixel(X+i, y);
    if (i<MAXWAVE-1) {
      uint8_t nexty = disp_wave[i+1];
      if (nexty>y) {
        for (uint8_t iy = y+1; iy<nexty; ++iy)
        oled.drawPixel(X+i, iy);
        else if (nexty<y) {
          for (uint8_t iy = nexty+1; iy<y; ++iy)
private:
    uint8_t waveform[MAXWAVE];
    uint8_t disp_wave[MAXWAVE];
    uint8_t wavep = 0;
} wave;
int  beatAvg;
int  SPO2, SPO2f;
int  voltage;
bool filter_for_graph = false;
bool draw_Red = false;
uint8_t pcflag =0;
uint8_t istate = 0;
uint8_t sleep_counter = 0;
void button(void){
    pcflag = 1;
void checkbutton(){
    if (pcflag && !digitalRead(BUTTON)) {
      istate = (istate +1) % 4;
      filter_for_graph = istate & 0x01;
      draw_Red = istate & 0x02;
      EEPROM.write(OPTIONS, filter_for_graph);
      EEPROM.write(OPTIONS+1, draw_Red);
    pcflag = 0;
void Display_5(){
   if(pcflag && !digitalRead(BUTTON)){
     draw_oled(5);
     delay(1100);
   pcflag = 0;
void go_sleep() {
    oled.fill(0);
    oled.off();
    delay(10);
    sensor.off();
    delay(10);
    cbi(ADCSRA, ADEN);  // disable adc
    delay(10);
    pinMode(0,INPUT);
    pinMode(2,INPUT);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_mode();  // sleep until button press
    // cause reset
    setup();
void draw_oled(int msg) {
    oled.firstPage();
    do{
    switch(msg){
        case 0:  oled.drawStr(10,0,F("Device error"),1);
        case 1:  oled.drawStr(0,0,F("PLACE YOUR"),2);
                 oled.drawStr(25,18,F("FINGER"),2);
        case 2:  print_digit(86,0,beatAvg);
                 oled.drawStr(0,3,F("PULSE RATE"),1);
                 oled.drawStr(11,17,F("OXYGEN"),1);
                 oled.drawStr(0,25,F("SATURATION"),1);
                 print_digit(73,16,SPO2f,' ',3,2);
                 oled.drawChar(116,16,'%',2);
        case 3:  oled.drawStr(33,0,F("Pulse"),2);
                 oled.drawStr(17,15,F("Oximeter"),2);
                 //oled.drawXBMP(6,8,16,16,heart_bits);
        case 4:  oled.drawStr(28,12,F("OFF IN"),1);
                 oled.drawChar(76,12,10-sleep_counter/10+'0');
                 oled.drawChar(82,12,'s');
        case 5:  oled.drawStr(0,0,F("Avg Pulse"),1);
                 print_digit(75,0,beatAvg);
                 oled.drawStr(0,15,F("AVG OXYGEN"),1);
                 oled.drawStr(0,22,F("saturation"),1);
                 print_digit(75,15,SPO2);
    } while (oled.nextPage());
void setup(void) {
  pinMode(LED, OUTPUT);
  pinMode(BUTTON, INPUT_PULLUP);
  filter_for_graph = EEPROM.read(OPTIONS);
  draw_Red = EEPROM.read(OPTIONS+1);
  oled.init();
  oled.fill(0x00);
  draw_oled(3);
  delay(3000);
  if (!sensor.begin())  {
    draw_oled(0);
    while (1);
  sensor.setup();
  attachInterrupt(digitalPinToInterrupt(BUTTON),button, CHANGE);
long lastBeat = 0;    //Time of the last beat
long displaytime = 0; //Time of the last display update
bool led_on = false;
void loop()  {
    sensor.check();
    long now = millis();   //start time of this cycle
    if (!sensor.available()) return;
    uint32_t irValue = sensor.getIR();
    uint32_t redValue = sensor.getRed();
    sensor.nextSample();
    if (irValue<5000) {
        voltage = getVCC();
        checkbutton();
        draw_oled(sleep_counter<=50 ? 1 : 4); // finger not down message
        //? : 是三元运算符,整个表达式根据条件返回不同的值,如果x>y为真则返回x,如果为假则返回y,之后=赋值给z。相当于:if(x>y)z=x;elsez=y
        delay(200);
        ++sleep_counter;
        if (sleep_counter>100) {
          go_sleep();
          sleep_counter = 0;
        sleep_counter = 0;
        // remove DC element移除直流元件
        int16_t IR_signal, Red_signal;
        bool beatRed, beatIR;
        if (!filter_for_graph) {//图形过滤器
           IR_signal =  pulseIR.dc_filter(irValue) ;
           Red_signal = pulseRed.dc_filter(redValue);
           beatRed = pulseRed.isBeat(pulseRed.ma_filter(Red_signal));
           beatIR =  pulseIR.isBeat(pulseIR.ma_filter(IR_signal));
           IR_signal =  pulseIR.ma_filter(pulseIR.dc_filter(irValue)) ;
           Red_signal = pulseRed.ma_filter(pulseRed.dc_filter(redValue));
           beatRed = pulseRed.isBeat(Red_signal);
           beatIR =  pulseIR.isBeat(IR_signal);
        // invert waveform to get classical BP waveshape
        wave.record(draw_Red ? -Red_signal : -IR_signal );
        // check IR or Red for heartbeat
        if (draw_Red ? beatRed : beatIR){
            long btpm = 60000/(now - lastBeat);
            if (btpm > 0 && btpm < 200) beatAvg = bpm.filter((int16_t)btpm);
            lastBeat = now;
            digitalWrite(LED, HIGH);
            led_on = true;
            // compute SpO2 ratio
            long numerator   = (pulseRed.avgAC() * pulseIR.avgDC())/256;
            long denominator = (pulseRed.avgDC() * pulseIR.avgAC())/256;
            int RX100 = (denominator>0) ? (numerator * 100)/denominator : 999;
            // using formula
            SPO2f = (10400 - RX100*17+50)/100;
            // from table
            if ((RX100>=0) && (RX100<184))
              SPO2 = pgm_read_byte_near(&spo2_table[RX100]);
        // update display every 50 ms if fingerdown
        if (now-displaytime>50) {
            displaytime = now;
            wave.scale();
            draw_oled(2);
        Display_5();
    // flash led for 25 ms
    if (led_on && (now - lastBeat)>25){
        digitalWrite(LED, LOW);
        led_on = false;
and this error appear
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit SSD1306@2.5.9 Adafruit SSD1306 Wemos Mini OLED@1.1.2]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit SSD1306@2.5.9 Adafruit SSD1306 Wemos Mini OLED@1.1.2]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for Adafruit_GFX.h: [Adafruit GFX Library@1.11.9]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit GFX Library@1.11.9]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 -Ic:\libraries\libraries\Adafruit_GFX_Library C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.15.0]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit BusIO@1.15.0]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 -Ic:\libraries\libraries\Adafruit_GFX_Library -Ic:\libraries\libraries\Adafruit_BusIO C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 -Ic:\libraries\libraries\Adafruit_GFX_Library -Ic:\libraries\libraries\Adafruit_BusIO -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 -Ic:\libraries\libraries\Adafruit_GFX_Library -Ic:\libraries\libraries\Adafruit_BusIO -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
Alternatives for MAX30102.h: [MAX3010x Sensor Library@1.0.5]
ResolveLibrary(MAX30102.h)
  -> candidates: [MAX3010x Sensor Library@1.0.5]
C:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\libraries\libraries\Adafruit_SSD1306 -Ic:\libraries\libraries\Adafruit_GFX_Library -Ic:\libraries\libraries\Adafruit_BusIO -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\l0l0-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\libraries\libraries\MAX3010x_Sensor_Library\src C:\Users\l0l0-\AppData\Local\Temp\arduino\sketches\BFD729C60AD7E9BF4947D04B801FCA9B\sketch\oximeter_max30102.ino.cpp -o nul
In file included from C:\libraries\oximeter_max30102\oximeter_max30102.ino:5:0:
C:\libraries\oximeter_max30102\Pulse.h:9:9: fatal error: UIKit/UIKit.h: No such file or directory
 #import <UIKit/UIKit.h>
compilation terminated.
Alternatives for UIKit/UIKit.h: []
ResolveLibrary(UIKit/UIKit.h)
  -> candidates: []
exit status 1
Compilation error: UIKit/UIKit.h: No such file or directory
when i searched about it i found this library work with IOS, and i use windows 11, so is there another code to be use?
the pulse.h library:
//  Pulse.h
//  Pulse
//  Created by Omar Allaham on 1/17/17.
//  Copyright © 2017 Bemaxnet. All rights reserved.
//! Project version number for Pulse.
FOUNDATION_EXPORT double PulseVersionNumber;
//! Project version string for Pulse.
FOUNDATION_EXPORT const unsigned char PulseVersionString[];
// In this header, you should import all the public headers of your framework using statements like #import <Pulse/PublicHeader.h>
You started a topic in the Uncategorised category of the forum
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
I find that #import very strange. It sounds like you're mixing C++ and Python.
You also seem to have a strange installation with libraries in C:\libraries and not in the sketchbook directory. What is the sketchbook directory set to in files / preferences in the IDE?
This library is written in Swift language, it is incompatible with Arduino platform.
Why did you included it in the project?
