Transistor: TIP122 NPN Darlington
Board: Wemos D1 32 & Mini
Error message:
Executable segment sizes:
IROM : 264008 - code in flash (default or ICACHE_FLASH_ATTR) **
IRAM : 28792 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...) **
DATA : 1316 ) - initialized variables (global, static) in RAM/HEAP **
RODATA : 936 ) / 81920 - constants (global, static) in RAM/HEAP **
BSS : 25416 ) - zeroed variables (global, static) in RAM/HEAP **
Sketch uses 295052 bytes (28%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27668 bytes (33%) of dynamic memory, leaving 54252 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM8
Connecting......................................____Traceback (most recent call last):
** File "C:\Users\Lwin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in
** esptool.main(cmdline)
** File "C:/Users/Lwin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
** esp.connect(args.before)
** File "C:/Users/Lwin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
** raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))**
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Here is the CODE:
//Source taken from: https://learn.linksprite.com/jpeg-camera/tutorial-of-using-linksprite-2mp-uart-jpeg-camera-with-arduino/
//CP05/06: Camera commands (byte sequence) below are for LS-Y201 camera model. You will have to modify accordingly for your Serial Camera model following the manual (Manual_for_serial_camera.pdf)
// www.linksprite.com
// Note:
// 1. SD must be formated to FAT16
// 2. As the buffer of softserial has 64 bytes,
// so the code read 32 bytes each time
// 3. Please add the libaray to the lib path
// * SD card attached to ESP8266 nodeMCU SPI bus as follows:
// * MOSI – D7
// * MISO – D6
// * CLK – D5
// * CS – D8
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
SoftwareSerial mySerial(D4, D3); // Set Arduino pin 4 and 5 as softserial (RxD, TxD)
byte ZERO = 0x00;
byte incomingbyte;
long int j = 0, k = 0, count = 0, i = 0x0000;
uint8_t MH, ML;
boolean EndFlag = 0;
File myFile;
void SendResetCmd()
mySerial.write(0x56);
mySerial.write(ZERO);
mySerial.write(0x26);
/* Set ImageSize :
/* <1> 0x22 : 160*120
/* <2> 0x11 : 320*240
/* <3> 0x00 : 640*480
/* <4> 0x1D : 800*600
/* <5> 0x1C : 1024*768
/* <6> 0x1B : 1280*960
/* <7> 0x21 : 1600*1200
void SetImageSizeCmd(byte Size)
mySerial.write(0x54);
mySerial.write(0x01);
mySerial.write(Size);
/* Set BaudRate :
/* <1> 0xAE : 9600
/* <2> 0x2A : 38400
/* <3> 0x1C : 57600
/* <4> 0x0D : 115200
/* <5> 0xAE : 128000
/* <6> 0x56 : 256000
void SetBaudRateCmd(byte baudrate)
mySerial.write(0x24);
mySerial.write(0x03);
mySerial.write(baudrate);
void SendTakePhotoCmd()
mySerial.write(0x36);
void SendReadDataCmd()
MH = i / 0x100;
ML = i % 0x100;
mySerial.write(0x32);
mySerial.write(0x0c);
mySerial.write(0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write(0x20);
i += 0x20;
void StopTakePhotoCmd()
Serial.print("Initializing SD card...");
int intNameCount = 0;
/*void loop()
digitalWrite (transistor, HIGH);
digitalWrite (transistor, LOW);
if (!SD.begin(D8)) { //D8 stands for SD_CS
Serial.println("initialization failed!");
return;
const int transistor = D2;
pinMode (transistor, OUTPUT);
Serial.println("initialization done.");
Serial.println("please wait.....");
Serial.println("Transistor online in 3sec...");
delay(3000);
//digitalWrite (transistor, HIGH);
byte a[32];
int ii;
i = 0x0000;
intNameCount ++;
mySerial.begin(115200);
delay(200);
SendResetCmd(); //Wait 2-3 second to send take picture command
delay(2000);
SetBaudRateCmd(0x2A);
delay(100);
mySerial.begin(38400);
delay(100);
SetImageSizeCmd(0x11); //Change Image Bit Size (Currently: 320 * 240)
delay(100);
SendTakePhotoCmd();
delay(3000);
while (mySerial.available() > 0)
incomingbyte = mySerial.read();
myFile = SD.open(String(intNameCount) + "pic.jpg", FILE_WRITE); //<strong><span style="color: #ff0000;">The file name should not be too long</span></strong>
while (!EndFlag)
j = 0;
k = 0;
count = 0;
SendReadDataCmd();
delay(5);
k++;
delayMicroseconds(100);
if ((k > 5) && (j < 32) && (!EndFlag))
a[j] = incomingbyte;
if ((a[j - 1] == 0xFF) && (a[j] == 0xD9)) //tell if the picture is finished
EndFlag = 1;
j++;
count++;
for (j = 0; j < count; j++)
if (a[j] < 0x10) Serial.print("0");
Serial.print(a[j], HEX); // observe the image through serial port
Serial.print(" ");
for (ii = 0; ii < count; ii++)
myFile.write(a[ii]);
myFile.close();
Serial.print("Finished writing data to file");
StopTakePhotoCmd();
EndFlag = 0;
//digitalWrite (transistor, LOW);
delay(2500);
Hello everyone, I am a newbie to Arduino so I hope you guys can help me out. Backstory, this is a 6 months school project and I was tasked to take multiple picture of a particular area to monitor it over 10 days and it has come to my attention that the camera when it is connected to Vin PIN constantly, the battery gets drained easily. So my teacher suggested me to use a transistor to act as a switch between the Vin and the Camera. Before adding in the transistor codes, the code does not have any problem and it can complie and do it intended task which was to take multiple picture and save it into the SDCard, however after adding in the transistor, it always have compilation error unless i take out the output pin connected to the base of the transistor or the RX,TX pin of the camera.
Thank you so much for your help.
