Compilation error while using IRremote.h Library
Hello,
I have added the IRremote.h library and i am getting an error while compiling the following code
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
Compilation Error :
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.6 (Mac OS X), Board: “Arduino Leonardo”
In file included from /Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:13:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremoteInt.h:87: error: ‘uint8_t’ does not name a type
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremoteInt.h:88: error: ‘uint8_t’ does not name a type
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremoteInt.h:89: error: ‘uint8_t’ does not name a type
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremoteInt.h:92: error: ‘uint8_t’ does not name a type
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRsend::mark(int)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:173: error: ‘delayMicroseconds’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRsend::space(int)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:181: error: ‘delayMicroseconds’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRsend::enableIROut(int)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:200: error: ‘OUTPUT’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:200: error: ‘pinMode’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:201: error: ‘LOW’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:201: error: ‘digitalWrite’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In constructor ‘IRrecv::IRrecv(int)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:217: error: ‘volatile struct irparams_t’ has no member named ‘recvpin’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:218: error: ‘volatile struct irparams_t’ has no member named ‘blinkflag’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRrecv::enableIRIn()’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:241: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:242: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:246: error: ‘volatile struct irparams_t’ has no member named ‘recvpin’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:246: error: ‘INPUT’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:246: error: ‘pinMode’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRrecv::blink13(int)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:252: error: ‘volatile struct irparams_t’ has no member named ‘blinkflag’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:254: error: ‘OUTPUT’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:254: error: ‘pinMode’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In function ‘void TIMER2_OVF_vect()’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:268: error: ‘volatile struct irparams_t’ has no member named ‘recvpin’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:268: error: ‘digitalRead’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:271: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:273: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:275: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:284: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:285: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:287: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:293: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:295: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:300: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:302: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:310: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:321: error: ‘volatile struct irparams_t’ has no member named ‘blinkflag’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:323: error: ‘B00100000’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:326: error: ‘B11011111’ was not declared in this scope
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘void IRrecv::resume()’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:332: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:333: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘int IRrecv::decode(decode_results*)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:343: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:344: error: ‘volatile struct irparams_t’ has no member named ‘rcvstate’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘long int IRrecv::decodeNEC(decode_results*)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:392: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:400: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘long int IRrecv::decodeSony(decode_results*)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:433: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:443: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp: In member function ‘long int IRrecv::decodeRC5(decode_results*)’:
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:518: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
/Users/sahirismail/Documents/Arduino/libraries/IRremote/IRremote.cpp:529: error: ‘volatile struct irparams_t’ has no member named ‘rawlen’
Please let me know how to resolve the above error
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the ‘Code’ button above the posting area. (It looks like a scroll with < > inside it)
How to use this forum
Where exactly did you get the IRremote library? (link)
