Compilation error with 1.8.4 and Adafruit ST7735 library
I get the following error while compiling a sketch. Any pointers to this issue would be appreciated.
I hope non verbose is enough :slight_smile:
Thank you.
Arduino: 1.8.4 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:161:12: error: expected unqualified-id before ',' token
       255 },                  //     255 = 500 ms delay
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:163:11: error: expected constructor, destructor, or type conversion before '=' token
   Rcmd1[] = {                 // Init for 7735R, part 1 (red or green tab)
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:198:13: error: expected unqualified-id before ',' token
       0x05 },                 //     16-bit color
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:200:16: error: expected constructor, destructor, or type conversion before '=' token
   Rcmd2green[] = {            // Init for 7735R, part 2 (green tab only)
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:207:24: error: expected unqualified-id before ',' token
       0x00, 0x9F+0x01 },      //     XEND = 159
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:208:14: error: expected constructor, destructor, or type conversion before '=' token
   Rcmd2red[] = {              // Init for 7735R, part 2 (red tab only)
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:215:19: error: expected unqualified-id before ',' token
       0x00, 0x9F },           //     XEND = 159
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:217:11: error: expected constructor, destructor, or type conversion before '=' token
   Rcmd3[] = {                 // Init for 7735R, part 3 (red or green tab)
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::initB()':
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:306:14: error: 'Bcmd' was not declared in this scope
   commonInit(Bcmd);
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::initR(uint8_t)':
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:312:14: error: 'Rcmd1' was not declared in this scope
   commonInit(Rcmd1);
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:314:17: error: 'Rcmd2green' was not declared in this scope
     commandList(Rcmd2green);
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:319:17: error: 'Rcmd2red' was not declared in this scope
     commandList(Rcmd2red);
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:321:15: error: 'Rcmd3' was not declared in this scope
   commandList(Rcmd3);
Using library AdafruitGFX in folder: C:\Users\Andy\Dropbox\CODE\libraries\AdafruitGFX (legacy)
Using library AdafruitST7735 in folder: C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735 (legacy)
Using library Arduino-PID-Library-master at version 1.2.1 in folder: C:\Users\Andy\Dropbox\CODE\libraries\Arduino-PID-Library-master
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library SD at version 1.1.1 in folder: C:\Program Files (x86)\Arduino\libraries\SD
exit status 1
Error compiling for board Arduino Nano.
It looks like an issue with the comma. Check your code. Something is wrong there, maybe it's even before the #include where this is included.
wvmarle:
Thanks, I deleted the first lines of the error for no good reason... does this not highlight an issue with the cpp rather than the sketch? I can't seem to open the cpp file within the arduino ide.
C:\Users\Andy\Dropbox\CODE\libraries\AdafruitST7735\Adafruit_ST7735.cpp:103:16: error: 'prog_uchar' does not name a type
 PROGMEM static prog_uchar
   commonInit(Bcmd);
   commonInit(Rcmd1);
   commandList(Rcmd3);
exit status 1
option enabled in File -> Preferences.
Thanks for the help but the lib must have been corrupt. I re-downloaded the lib from github and installed it from the zip. Now works as expected. Phew.
That indicates that you must have had an older version. The "prog" types have been depricated for a while.
Delta_G:
Ahhh, that makes sense. Thanks.
negativ3:
The Arduino IDE indeed won't open .cpp or .h files - you have to use a separate editor for that.
This being C, compile errors can come from somewhere else. It's sometimes really surprising how far down the missing } the compiler finally throws an error.
wvmarle:
Thanks. Would Atmel Studio be more appropriate?
A simple text editor will open those files so you can read them.
Tom.. :slight_smile:
