Hello,
I'm using ADS1115 with Arduino Mega 250 board everything was going good till yesterday. From morning I'm getting this error when trying to compile. Can anyone please help me in this? I'm not getting proper solution for below error.
c:\users\abc\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\util\delay.h: In function 'Adafruit_ADS1115::readADC_SingleEnded(unsigned char) [clone .part.1] [clone .constprop]':
c:\users\abc\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\util\delay.h:276:28: error: __builtin_avr_delay_cycles expects a compile time integer constant
__builtin_avr_delay_cycles(__ticks_dc);
lto-wrapper.exe: fatal error: C:\Users\abc\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/users/abc/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
Using library Adafruit_ADS1115-master in folder: C:\Users\abc\Documents\Arduino\libraries\Adafruit_ADS1115-master (legacy)
Using library Wire at version 1.0 in folder: C:\Users\abc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Using library Arduino-LiquidCrystal-I2C-library-master in folder: C:\Users\abc\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master (legacy)
Using library MCP_DAC at version 0.1.8 in folder: C:\Users\abc\Documents\Arduino\libraries\MCP_DAC
Using library SPI at version 1.0 in folder: C:\Users\abc\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
@stryxter Hello , yes i have tried all of above points that you have mentioned. i have attched my sketch kindly refer that might help us to resolve issue.
As you told i had done same changes in ADS1115.cpp and tried to compile code but still same errors i got .please find attachment with this post.
I got below errors while compile.
"C:\\Users\\abc\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972/sketch_jan07a.ino.elf" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\sketch\\sketch_jan07a.ino.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\Adafruit_ADS1115-master\\Adafruit_ADS1115.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\MCP_DAC\\MCP_DAC.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972\\libraries\\Arduino-LiquidCrystal-I2C-library-master\\LiquidCrystal_I2C.cpp.o" "C:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972/core\\core.a" "-LC:\\Users\\abc\\AppData\\Local\\Temp\\arduino_build_76972" -lm
exit status 1
please, please never ever again post pictures of text... Not only they are not readable nor usable directly for copy&paste but they use up lots of storage and internet bandwidth which contributes to polluting the planet.
➜ do your part and do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation for your ask).
