I facing the same error like discussed here https://forum.arduino.cc/index.php?topic=470991.0 but with Platform.IO.
Does anybody perhaps know how to solve this? In the post only a downgrade to an older Arduino GUI solved the issue and I did not find anything else.
Cheers,
Nils
C:\Users\nrott.platformio\packages\framework-arduino-avr-digistump\cores\dtiny/pins_arduino.h:81:93: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
#define portInputRegister(P) ( (volatile uint8_t )( pgm_read_byte( port_to_input_PGM + (P))) )
C:\Users\nrott.platformio\lib\OneWire\util/OneWire_direct_gpio.h:13:42: note: in expansion of macro 'portInputRegister'
#define PIN_TO_BASEREG(pin) (portInputRegister(digitalPinToPort(pin)))
C:\Users\nrott.platformio\lib\OneWire\OneWire.cpp:151:12: note: in expansion of macro 'PIN_TO_BASEREG'
baseReg = PIN_TO_BASEREG(pin);
C:\Users\nrott.platformio\lib\OneWire\OneWire.cpp: In static member function 'static uint16_t OneWire::crc16(const uint8_t, uint16_t, uint16_t)':
C:\Users\nrott.platformio\lib\OneWire\OneWire.cpp:554:42: error: '_crc16_update' was not declared in this scope
crc = _crc16_update(crc, input*);*
*** [.pio\build\digispark-tiny\lib03a\OneWire\OneWire.cpp.o] Error 1
