Compilation Error
I've been trying to get a sketch to work that allows me to control lights/relays with Alexa and Sinric Pro for a few days, searching and frustratingly installing at least 20g of ESP background stuff and I've had no success. The problem is there seems to be some component that I'm supposed to install, I've found it on the net however I have no idea what to do with it and where to place it so I always end up with a #include "soc/soc_caps.h no such file or directory error". Any suggestions would be welcome.
 *  TITLE: ESP32 Alexa Home Automation with Sinric | Manual & WiFi control 8-Relays with feedback
 *  Click on the following links to learn more.
 *  YouTube Video: https://youtu.be/b5yr-H6jJAc
 *  Related Blog : https://iotcircuithub.com/esp32-projects/
 *  by Subhajit (Tech StudyCell)
 *  Preferences--> Aditional boards Manager URLs :
 *  https://dl.espressif.com/dl/package_esp32_index.json, http://arduino.esp8266.com/stable/package_esp8266com_index.json
 *  Download Board ESP32: https://github.com/espressif/arduino-esp32
 *  Download the libraries
 *  ArduinoJson Library: https://github.com/bblanchon/ArduinoJson/tags
 *  arduinoWebSockets Library: https://github.com/Links2004/arduinoWebSockets/releases
 *  AceButton Library: https://github.com/bxparks/AceButton
 *  Install the libraries at Arduino IDE -> Sketch - Include Library -> Add Zip Library
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WebSocketsClient.h>
#include <ArduinoJson.h>
#include <StreamString.h>
#include <AceButton.h>
using namespace ace_button;
WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey "----------------" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "--------" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "------" // TODO: Change to your Wifi network password
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
String device_ID_1 = "------------------------";
String device_ID_2 = "------------------------";
String device_ID_3 = "------------------------";
String device_ID_4 = "------------------------";
String device_ID_5 = "------------------------";
String device_ID_6 = "------------------------";
String device_ID_7 = "------------------------";
String device_ID_8 = "------------------------";
// define the GPIO connected with Relays and switches
//Relays
#define RelayPin1 23  //D23
#define RelayPin2 22  //D22
#define RelayPin3 21  //D21
#define RelayPin4 19  //D19
#define RelayPin5 18  //D18
#define RelayPin6 5   //D5
#define RelayPin7 25  //D25
#define RelayPin8 26  //D26
// Switches
#define SwitchPin1 13  //D13
#define SwitchPin2 12  //D12
#define SwitchPin3 14  //D14
#define SwitchPin4 27  //D27
#define SwitchPin5 33  //D33
#define SwitchPin6 32  //D32
#define SwitchPin7 15  //D15
#define SwitchPin8 4   //D4
//WiFi Status LED
#define wifiLed    2   //D2
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
ButtonConfig config4;
AceButton button4(&config4);
ButtonConfig config5;
AceButton button5(&config5);
ButtonConfig config6;
AceButton button6(&config6);
ButtonConfig config7;
AceButton button7(&config7);
ButtonConfig config8;
AceButton button8(&config8);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void handleEvent4(AceButton*, uint8_t, uint8_t);
void handleEvent5(AceButton*, uint8_t, uint8_t);
void handleEvent6(AceButton*, uint8_t, uint8_t);
void handleEvent7(AceButton*, uint8_t, uint8_t);
void handleEvent8(AceButton*, uint8_t, uint8_t);
void setPowerStateOnServer(String deviceId, String value);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
  if (deviceId == device_ID_1) // Device ID of 1st device
    Serial.print("Turn on device id: ");
    Serial.println(deviceId);
    digitalWrite(RelayPin1, LOW);
  if (deviceId == device_ID_2) // Device ID of 2nd device
    digitalWrite(RelayPin2, LOW);
  if (deviceId == device_ID_3) // Device ID of 3rd device
    digitalWrite(RelayPin3, LOW);
  if (deviceId == device_ID_4) // Device ID of 4th device
    digitalWrite(RelayPin4, LOW);
  if (deviceId == device_ID_5) // Device ID of 5th device
    digitalWrite(RelayPin5, LOW);
  if (deviceId == device_ID_6) // Device ID of 6th device
    digitalWrite(RelayPin6, LOW);
  if (deviceId == device_ID_7) // Device ID of 7th device
    digitalWrite(RelayPin7, LOW);
  if (deviceId == device_ID_8) // Device ID of 8th device
    digitalWrite(RelayPin8, LOW);
void turnOff(String deviceId) {
    Serial.print("Turn off Device ID: ");
    digitalWrite(RelayPin1, HIGH);
    digitalWrite(RelayPin2, HIGH);
    digitalWrite(RelayPin3, HIGH);
    digitalWrite(RelayPin4, HIGH);
    digitalWrite(RelayPin5, HIGH);
    digitalWrite(RelayPin6, HIGH);
    digitalWrite(RelayPin7, HIGH);
    digitalWrite(RelayPin8, HIGH);
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
  switch (type) {
    case WStype_DISCONNECTED:
      WiFiMulti.addAP(MySSID, MyWifiPassword);
      Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
    case WStype_CONNECTED: {
        isConnected = true;
        Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
        Serial.printf("Waiting for commands from sinric.com ...\n");
    case WStype_TEXT: {
        Serial.printf("[WSc] get text: %s\n", payload);
        // Example payloads
        // For Switch or Light device types
        // {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
        // For Light device type
        // Look at the light example in github
#if ARDUINOJSON_VERSION_MAJOR == 5
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject((char*)payload);
#endif
#if ARDUINOJSON_VERSION_MAJOR == 6
        DynamicJsonDocument json(1024);
        deserializeJson(json, (char*) payload);
#endif
        String deviceId = json ["deviceId"];
        String action = json ["action"];
        if (action == "setPowerState") { // Switch or Light
          String value = json ["value"];
          if (value == "ON") {
            turnOn(deviceId);
            turnOff(deviceId);
        else if (action == "test") {
          Serial.println("[WSc] received test command from sinric.com");
    case WStype_BIN:
      Serial.printf("[WSc] get binary length: %u\n", length);
  Serial.print("Connecting to Wifi: ");
  Serial.println(MySSID);
  // Waiting for Wifi connect
  if (WiFiMulti.run() != WL_CONNECTED) {
    Serial.print("Connecting...");
  if (WiFiMulti.run() == WL_CONNECTED) {
    Serial.println("");
    Serial.print("WiFi connected. ");
    Serial.print("IP address: ");
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  pinMode(SwitchPin5, INPUT_PULLUP);
  pinMode(SwitchPin6, INPUT_PULLUP);
  pinMode(SwitchPin7, INPUT_PULLUP);
  pinMode(SwitchPin8, INPUT_PULLUP);
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(RelayPin5, OUTPUT);
  pinMode(RelayPin6, OUTPUT);
  pinMode(RelayPin7, OUTPUT);
  pinMode(RelayPin8, OUTPUT);
  pinMode(wifiLed, OUTPUT);
  //During Starting all Relays should TURN OFF
  //During Starting WiFi LED should TURN OFF
  digitalWrite(wifiLed, LOW);
  config1.setEventHandler(button1Handler);
  config2.setEventHandler(button2Handler);
  config3.setEventHandler(button3Handler);
  config4.setEventHandler(button4Handler);
  config5.setEventHandler(button5Handler);
  config6.setEventHandler(button6Handler);
  config7.setEventHandler(button7Handler);
  config8.setEventHandler(button8Handler);
  button1.init(SwitchPin1);
  button2.init(SwitchPin2);
  button3.init(SwitchPin3);
  button4.init(SwitchPin4);
  button5.init(SwitchPin5);
  button6.init(SwitchPin6);
  button7.init(SwitchPin7);
  button8.init(SwitchPin8);
  // server address, port and URL
  webSocket.begin("iot.sinric.com", 80, "/");
  // event handler
  webSocket.onEvent(webSocketEvent);
  webSocket.setAuthorization("apikey", MyApiKey);
  // try again every 5000ms if connection has failed
  webSocket.setReconnectInterval(5000);   // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
    Serial.println("Not Connected");
    Serial.println(" Connected");
    digitalWrite(wifiLed, HIGH);
    webSocket.loop();
  button1.check();
  button2.check();
  button3.check();
  button4.check();
  button5.check();
  button6.check();
  button7.check();
  button8.check();
  if (isConnected) {
    uint64_t now = millis();
    // Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
    if ((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
      heartbeatTimestamp = now;
      webSocket.sendTXT("H");
void setPowerStateOnServer(String deviceId, String value) {
  JsonObject& root = jsonBuffer.createObject();
#endif
  DynamicJsonDocument root(1024);
#endif
  root["deviceId"] = deviceId;
  root["action"] = "setPowerState";
  root["value"] = value;
  StreamString databuf;
  root.printTo(databuf);
#endif
  serializeJson(root, databuf);
#endif
  webSocket.sendTXT(databuf);
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT1");
  switch (eventType) {
    case AceButton::kEventPressed:
      Serial.println("kEventPressed");
      setPowerStateOnServer(device_ID_1, "ON");
    case AceButton::kEventReleased:
      Serial.println("kEventReleased");
      setPowerStateOnServer(device_ID_1, "OFF");
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT2");
      setPowerStateOnServer(device_ID_2, "ON");
      setPowerStateOnServer(device_ID_2, "OFF");
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT3");
      setPowerStateOnServer(device_ID_3, "ON");
      setPowerStateOnServer(device_ID_3, "OFF");
void button4Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT4");
      setPowerStateOnServer(device_ID_4, "ON");
      setPowerStateOnServer(device_ID_4, "OFF");
void button5Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT5");
      setPowerStateOnServer(device_ID_5, "ON");
      setPowerStateOnServer(device_ID_5, "OFF");
void button6Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT6");
      setPowerStateOnServer(device_ID_6, "ON");
      setPowerStateOnServer(device_ID_6, "OFF");
void button7Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT7");
      setPowerStateOnServer(device_ID_7, "ON");
      setPowerStateOnServer(device_ID_7, "OFF");
void button8Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
  Serial.println("EVENT8");
      setPowerStateOnServer(device_ID_8, "ON");
      setPowerStateOnServer(device_ID_8, "OFF");
Are you compiling the sketch using the Arduino IDE? If so, which board do you have selected? The soc_caps.h file is part of the ESP32 boards package, you should not need to download it separately.
Yes I am using the Arduino IDE and thanks for the reply. I've been compiling this sketch for the ESP8266. Your reply made me realize that I should try compiling it for the ESP32 and so now it works. I'm a newbie and I've been compiling it for the ESP8266 because the ESP32's I've ordered haven't arrived yet.
Thanks for your help.
