Compilation error
I get the following error ….
error: invalid conversion from 'TwoWire*' to 'uint8_t' {aka 'unsigned char'} [-fpermissive]
when compiling my project.
I am using the latest library #include <Adafruit_BMP280.h> V2.6.8 but have tried several others without success.
The error occurs at this line :- bool status = bmp.begin( 0x77,&Wire);
Any help would be much appreciated and of course I will submit all code if required.
Yeah, the full code can help us to try and possibly give you an answer.
PS: remember to enclose the full and already indented code within "CODE" tags.
To make things easier, load the IDE with your sketch then click Ctrl-T for auto-indent if required, then use "Copy for forum," menu function (or press Ctrl-shift-C) and paste it here.
replace with
bool status = bmp.begin();
The begin() function doesn't have a version that accepts address followed by Wire pointer. 0x77 is the default address and Wire is the default I2C interface so a begin without args will work just fine.
Your suggestion is not quite correct.
The begin() function is defined in the library as:
bool begin(uint8_t addr = BMP280_ADDRESS, uint8_t chipid = BMP280_CHIPID);
chipid isn't a TwoWire ptr
please do it
The DB_Meter works and I can post to Thingsboard on my own server.
I would like to have the data also from the BMP280 & the AHT10
The bus wiring is correct at I can see the devices with test apps
```cpp
//SoundI2cTempHumPres1 - 4/10/25
int versionno = 1;
//#include <Spi.h>
#include <Wire.h>
//#include <Adafruit_AHT10.h>
#include <WiFi.h>
#include <HTTPClient.h>
// SDA and SCL pins for the decibel meter module
#define I2C_SDA 21  // 5
#define I2C_SCL 22  // 18
//AHT10 myAHT20(AHT10_ADDRESS_0X38, AHT20_SENSOR);
// I2C address for the module
#define DBM_ADDR 0x48
// Device registers
#define DBM_REG_VERSION 0x00
#define DBM_REG_ID3 0x01
#define DBM_REG_ID2 0x02
#define DBM_REG_ID1 0x03
#define DBM_REG_ID0 0x04
#define DBM_REG_SCRATCH 0x05
#define DBM_REG_CONTROL 0x06
#define DBM_REG_TAVG_HIGH 0x07
#define DBM_REG_TAVG_LOW 0x08
#define DBM_REG_RESET 0x09
#define DBM_REG_DECIBEL 0x0A
#define DBM_REG_MIN 0x0B
#define DBM_REG_MAX 0x0C
#define DBM_REG_THR_MIN 0x0D
#define DBM_REG_THR_MAX 0x0E
#define DBM_REG_HISTORY_0 0x14
#define DBM_REG_HISTORY_99 0x77
Adafruit_BMP280 bmp;
TwoWire dbmeter = TwoWire(0);  //( i2c for sound sensor)
// delay (2000);
uint8_t db, dbmin, dbmax;
String DBMjson;
// Buffer for printing decibel values over UART
char buf[64];
// Function to read a register from decibel meter
uint8_t dbmeter_readreg(TwoWire *dev, uint8_t regaddr) {
  dev->beginTransmission(DBM_ADDR);
  dev->write(regaddr);
  dev->endTransmission();
  dev->requestFrom(DBM_ADDR, 1);
  delay(10);
  return dev->read();
// Function to write a register to decibel meter module
uint8_t dbmeter_writereg(TwoWire *dev, uint8_t regaddr, uint8_t regdata) {
  dev->write(regdata);
  delay(10);
  return dbmeter_readreg(dev, regaddr);
  dbmeter.begin(I2C_SDA, I2C_SCL);
  delay(2000);
  //bmp.begin (I2C_SDA, I2C_SCL);  // this line stops the other i2c device
  //delay (2000);
  Serial.println("Decibel Meter test sketch");
  Serial.println("with Oled display======");
  Serial.print("Version no ");
  Serial.println(versionno);  // ser print version no
  // Wait and set up Wi-Fi connection
  WiFi.begin("xxxxxxxx", "xxxxxxxxx");
    delay(5000);
    Serial.println("Connecting to WiFi network 'Airtel'...");
  Serial.println("Connected!");
  // Read version register
  uint8_t version = dbmeter_readreg(&dbmeter, DBM_REG_VERSION);
  Serial.printf("Version = 0x%02X\r\n", version);
  Serial.println(buf);
  // Read ID registers
  uint8_t id[4];
  id[0] = dbmeter_readreg(&dbmeter, DBM_REG_ID3);
  id[1] = dbmeter_readreg(&dbmeter, DBM_REG_ID2);
  id[2] = dbmeter_readreg(&dbmeter, DBM_REG_ID1);
  id[3] = dbmeter_readreg(&dbmeter, DBM_REG_ID0);
  Serial.printf("Unique ID = %02X %02X %02X %02X\r\n", id[3], id[2], id[1], id[0]);
  // Clear the MIN and MAX reading
  dbmeter_writereg(&dbmeter, DBM_REG_RESET, 0x02);
  //.......BMP20.....initaisation
  if (!bmp.begin(0x77, &Wire)) {
    Serial.println("Could not find a valid BMP280 sensor, check wiring!");
    while (1)
  //bmp.begin(0x77);
  /* bool  status = bmp.begin( 0x77,&Wire);
  if (!status) {
    while (1);
  while (1) {
    // Read decibel, min and max
    db = dbmeter_readreg(&dbmeter, DBM_REG_DECIBEL);
    if (db == 255)
      continue;  // module is not ready
    dbmin = dbmeter_readreg(&dbmeter, DBM_REG_MIN);
    dbmax = dbmeter_readreg(&dbmeter, DBM_REG_MAX);
    Serial.printf("dB reading = %03d \t [MIN: %03d \tMAX: %03d] \r\n", db, dbmin, dbmax);
    // Assemble JSON with dB SPL reading
    DBMjson = "{\"db\": " + String(db) + "}";
    Serial.println("JSON: \n" + DBMjson);
    Serial.print("Temperature = ");
    Serial.print(bmp.readTemperature());
    Serial.print("Pressure = ");
    Serial.print(bmp.readPressure() / 100.0F);
    Serial.println(" *C");
    // Make a POST request with the data
    if ((WiFi.status() == WL_CONNECTED)) {
      //Check the current connection status
      HTTPClient http;
      http.begin("http://192.168.1.140:8080/api/v1/twR9jeaRwqmyZyCh9k4i/telemetry");
      http.addHeader("Content-Type", "application/json");
      int httpResponseCode = http.POST(DBMjson);  //Send the actual POST request
      if (httpResponseCode > 0) {
        //Get the response to the request
        String response = http.getString();
        Serial.println(httpResponseCode);  //Print return code
        Serial.println(response);          //Print request answer
        Serial.print("Error on sending POST: ");
      http.end();  //Free resources
      Serial.println("Something wrong with WiFi?");
    // Wait for 5 seconds before posting another reading
    delay(2000);
  delay(2000);
If you going to use a separate Wire object for BMP280 sensor, an idea of the solution shown by pseudo-code below:
#include <Wire.h>
Adafruit_BMP280 *bmp;
  bmp = new Adafruit_BMP280( &Wire);
  if (!bmp->begin(0x77)) {
    while (1) ;
    Serial.print(bmp->readTemperature());
    Serial.print(bmp->readPressure() / 100.0F);
Many thanks for the response.
The code for addressing the sound module came from the module supplier.–
I wanted to include data from other sensors so I proceeded to modify teh code.
I would welcome a full explanation of your pseudo code ( if you have the time).
As an old timer (79yrs) it will expand my knowledge on the subject.
I will give it a try and advise you accordingly.
I get the following error on compilation.
Please advise
\sound_i2c_New2.ino: In function 'void setup()':
\sound_i2c_New2\sound_i2c_New2.ino:133:12: error: request for member 'begin' in 'bmp', which is of pointer type 'Adafruit_BMP280*' (maybe you meant to use '->' ?)
133 | if (!bmp.begin(0x77)) {
In my code, bmp is a pointer, so you have to replace all instances of bmp. to bmp->.
See my code in #8:
All working now.
Many thanks
