Compilation error
We have a problem. The programm says these problems: Si hay españoles, ayudadnos porfavor no tenemos ni idea de porque nos salen estos problemas!!!
dale.ino: In function 'void loop()':
dale.ino:25:17: error: expected initializer before '.' token
dale.ino:26:17: error: expected initializer before '.' token
dale.ino:30:5: error: case label '68' not within a switch statement
dale.ino:32:17: error: expected initializer before '.' token
dale.ino:33:17: error: expected initializer before '.' token
dale.ino:35:7: error: break statement not within loop or switch
dale.ino:37:5: error: case label '67' not within a switch statement
dale.ino:39:17: error: expected initializer before '.' token
dale.ino:40:17: error: expected initializer before '.' token
dale.ino:42:7: error: break statement not within loop or switch
dale.ino:44:5: error: case label '76' not within a switch statement
dale.ino:46:17: error: expected initializer before '.' token
dale.ino:47:17: error: expected initializer before '.' token
dale.ino:49:7: error: break statement not within loop or switch
dale.ino:51:5: error: case label '82' not within a switch statement
dale.ino:53:17: error: expected initializer before '.' token
dale.ino:54:17: error: expected initializer before '.' token
dale.ino:56:7: error: break statement not within loop or switch
Error de compilación
int servo1 = 4;
int servo2 = 5;
byte dato;
Serial.begin (9600);
pinMode(4 ,OUTPUT);
pinMode(5 ,OUTPUT);
if(Serial.available())
dato=Serial.read();
switch(dato)
case 85:
int servo1.writeMicroseconds(1800);
int servo2.writeMicroseconds(0);
case 68:
int servo1.writeMicroseconds(1000);
int servo2.writeMicroseconds(3000);
case 67:
int servo1.writeMicroseconds(1425);
int servo2.writeMicroseconds(1580);
case 76:
case 82:
 switch(dato)
    case 85:
Missing { brace
Too much "int"
I've corrected all the compilation errors but I have no idea if it will run.
#include <Servo.h>  //YOU NEED THIS LIBRARY
Servo servo1;       //NOTE THESE ARE SERVOS, NOT INTS
Servo servo2;
byte dato;
  servo1.attach(4);//you need this to attach the servo
  servo2.attach(5);
  //  pinMode(4 ,OUTPUT); THESE LINES ARE REDUNDANT
  //  pinMode(5 ,OUTPUT);
    dato=Serial.read();
    switch(dato)
     { //this bracket was missing
    case 85:
      //{ this bracket is redundant
       //NO DON'T PUT INT IN FRONT OF THESE STATEMENTS
       //int servo1.writeMicroseconds(1800);
       //int servo2.writeMicroseconds(0);
      //} this bracket is redundant
    case 68:
      //{this bracket is redundant
      //}this bracket is redundant
    case 67:
    case 76:
    case 82:
