compilation error
Hi all,
I’m trying to send a temperature read from DHT11 sensor and with this code below I’m having the following error:
DHTTest.ino:4:17: fatal error: DHT.h: No such file or directory
compilation terminated.
I have installed in the arduino library folder a DHT library.
Does anyone help me on how to solve this error ?
Thanks in advance.
This is the code:
// Program: Sensor DHT11 - Send data over bluetooth
#include "DHT.h"
#define dht_pin A5
#define DHTTYPE DHT11
DHT dht(dht_pin, DHTTYPE);
 // wait one second before read sensor
 dht.begin();
 float h = dht.readHumidity();
 float t = dht.readTemperature();
 // show values
 Serial.print("Temp. = ");
 Serial.print(t);
 Serial.print(" C ");
 Serial.print("Um. = ");
 Serial.print(h);
 Serial.println(" % ");
 // wait two seconds to the next read
 delay(2000);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
You must restart all instances of the IDE after installing a new library (depending on which version you use)
(Adafruit's library?)
