Compilation Failed Please Report
Got this Message:
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Micro"
In file included from C:\Users\Feargaill\Downloads\ArduinoProMicro_MPU9250InertialMouse__X_\ArduinoProMicro_MPU9250InertialMouse__X_.ino:14:0:
C:\Users\Feargaill\Documents\Arduino\libraries\MPU9250_asukiaaa\src/MPU9250_asukiaaa.h:27:7: error: redefinition of 'class MPU9250'
 class MPU9250 {
In file included from C:\Users\Feargaill\Downloads\ArduinoProMicro_MPU9250InertialMouse__X_\ArduinoProMicro_MPU9250InertialMouse__X_.ino:3:0:
C:\Users\Feargaill\Documents\Arduino\libraries\IMU_10DOF-master/MPU9250.h:408:7: error: previous definition of 'class MPU9250'
 class MPU9250 {
exit status 1
Error compiling for board Arduino/Genuino Micro.
option enabled in File -> Preferences.
Please post your full sketch. If possible, you should always post code directly in the forum thread as text using code tags (</> button on the toolbar). This will make it easy for anyone to look at it, which will increase the likelihood of you getting help. If the sketch is longer than the forum will allow then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link.
Please always do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
Thanks, for whatever reason it issue resolved itself
In file included from ArduinoProMicro_MPU9250InertialMouse__X_.ino: line 14
In file included from ArduinoProMicro_MPU9250InertialMouse__X_.ino: line 3
FYI: You were including two libraries: "MPU9250_asukiaaa" and "IMU_10DOF-master" which each declared an object class named "MPU9250". Maybe you got rid of one of them.
