Hi, i have the sme problem. this skecth work very well on arduino desktop, but not work on web editor
please, i need some hints
thank you
// this is the skect for sensor MQ7
// Digital pin 9 will be called 'pin8'
int pin9 = 9;
// Analog pin 0 will be called 'sensor'
int sensor = A0;
// Set the initial sensorValue to 0
int sensorValue = 0;
// The setup routine runs once when you press reset
// Initialize the digital pin 8 as an output
pinMode(pin9, OUTPUT);
// Initialize serial communication at 9600 bits per second
// The loop routine runs over and over again forever
// Read the input on analog pin 0 (named 'sensor')
sensorValue = analogRead(sensor);
// Print out the value you read
Serial.println(sensorValue, DEC);
// If sensorValue is greater than 500
if (sensorValue > 500) {
// Activate digital output pin 8 - the LED will light up
digitalWrite(pin9, HIGH);
else {
// Deactivate digital output pin 8 - the LED will not light up
digitalWrite(pin9, LOW);
Please dont just jump into other peoples posts.
Might I suggest you read the forum rules.
BTW you are simply missing a bracket to get it to compile.
Works here *with the required bracket"
i am sorry, I am new in this. I will read it the fourum rules!!
in other hand, I missed to copy the whole code, it include the braket
however It does not run
this is the online code
any help?
int pin9 = 9;
int sensor = A0;
// Activate digital output pin 9 - the LED will light up
else {
// Deactivate digital output pin 9 - the LED will not light up
I compiled the code in the CREATE editor and it compiled just fine.
Do you mean it will not upload ?
If so what are the error messages you see in the lower console ?
