Compilation failed when using BSEC for BME680 Calibration with ESP8266 V3
Hi, there!! I am working on a project in which I am interfacing BME680 to ESP8266 Node MCU.
To get the calibrated sensor value of BME680, I have installed the library BSEC(BOSCH Sensortech Environmental Cluster).
I have followed the steps given in the tutorial but I am using ESP8266 Node MCU V2:
[https://bluedot.space/tutorials/how-to-measure-indoor-air-quality-iaq-with-the-bme680]/
But, while compiling I am facing an error:
1.
c:/users/user/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\user\AppData\Local\Temp\arduino\sketches\B7141D2A4CA07993157E1BD8D6875821/basic.ino.elf section .text1' will not fit in region iram1_0_seg'.
  1. At first, the COM port was detected, but after trying to upload the code sometimes, it throws the above error and the controller disconnects many times.
  2. When connecting the device to a different port the COM port does not change.
Please look into the topic and share your views.
The Basic Code for Calibration I used is from Examples of BSEC library:
[GitHub - boschsensortec/BSEC-Arduino-library: Arduino library for BSEC to simplify integration into compatible platforms. To report issues, go to https://community.bosch-sensortec.com/t5/Bosch-Sensortec-Community/ct-p/bst_community]
#include "bsec.h"
// Helper functions declarations
void checkIaqSensorStatus(void);
void errLeds(void);
// Create an object of the class Bsec
Bsec iaqSensor;
String output;
// Entry point for the example
void setup(void)
Wire.begin();
iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
Serial.println(output);
checkIaqSensorStatus();
bsec_virtual_sensor_t sensorList[10] = {
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_LP);
// Print the header
output = "Timestamp [ms], raw temperature [°C], pressure [hPa], raw relative humidity [%], gas [Ohm], IAQ, IAQ accuracy, temperature [°C], relative humidity [%], Static IAQ, CO2 equivalent, breath VOC equivalent";
// Function that is looped forever
void loop(void)
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
output = String(time_trigger);
output += ", " + String(iaqSensor.rawTemperature);
output += ", " + String(iaqSensor.pressure);
output += ", " + String(iaqSensor.rawHumidity);
output += ", " + String(iaqSensor.gasResistance);
output += ", " + String(iaqSensor.iaq);
output += ", " + String(iaqSensor.iaqAccuracy);
output += ", " + String(iaqSensor.temperature);
output += ", " + String(iaqSensor.humidity);
output += ", " + String(iaqSensor.staticIaq);
output += ", " + String(iaqSensor.co2Equivalent);
output += ", " + String(iaqSensor.breathVocEquivalent);
// Helper function definitions
if (iaqSensor.status != BSEC_OK) {
if (iaqSensor.status < BSEC_OK) {
output = "BSEC error code : " + String(iaqSensor.status);
for (;:wink:
errLeds(); /* Halt in case of failure */
output = "BSEC warning code : " + String(iaqSensor.status);
if (iaqSensor.bme680Status != BME680_OK) {
if (iaqSensor.bme680Status < BME680_OK) {
output = "BME680 error code : " + String(iaqSensor.bme680Status);
for (;:wink:
output = "BME680 warning code : " + String(iaqSensor.bme680Status);
void errLeds(void)
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
