Hi, I'm having the same issues but I actually have the Giga R1 and I believe I have everything I need to have installed. Full Disclosure : Novice user. I'm getting this and other errors as well on more than have of the example sketches. Any help is appreciated
Error: C:\Users\12146\AppData\Local\Temp.arduinoIDE-unsaved202523-25160-jz0k8u.548rq\sketch_mar3a\sketch_mar3a.ino:1:10: fatal error: Arduino_GigaDisplay_GFX.h: No such file or directory #include "Arduino_GigaDisplay_GFX.h"
compilation terminated.
exit status 1
Compilation error: Arduino_GigaDisplay_GFX.h: No such file or directory
#include "Arduino_GigaDisplayTouch.h"
#include "Arduino_LED_Matrix.h"
GigaDisplay_GFX display;
Arduino_GigaDisplayTouch touch;
ArduinoLEDMatrix matrix;
#define PALETTE_X 50
#define PALETTE_Y 50
#define PALETTE_WIDTH 700
#define PALETTE_HEIGHT 300
display.begin();
touch.begin();
matrix.begin();
drawColorPalette();
drawInterface();
if (touch.available()) {
uint16_t x, y;
touch.getPosition(x, y);
if (x >= PALETTE_X && x < PALETTE_X + PALETTE_WIDTH &&
y >= PALETTE_Y && y < PALETTE_Y + PALETTE_HEIGHT) {
uint16_t color = getColorAtPosition(x, y);
updateSelectedColor(color);
void drawColorPalette() {
for (int x = 0; x < PALETTE_WIDTH; x++) {
for (int y = 0; y < PALETTE_HEIGHT; y++) {
uint8_t r = map(x, 0, PALETTE_WIDTH, 0, 255);
uint8_t g = map(y, 0, PALETTE_HEIGHT, 0, 255);
uint8_t b = 128;
uint16_t color = display.color565(r, g, b);
display.drawPixel(PALETTE_X + x, PALETTE_Y + y, color);
void drawInterface() {
display.setTextColor(0xFFFF);
display.setTextSize(2);
display.setCursor(50, 400);
display.print("Touch the palette to select a color");
uint16_t getColorAtPosition(uint16_t x, uint16_t y) {
uint8_t r = map(x - PALETTE_X, 0, PALETTE_WIDTH, 0, 255);
uint8_t g = map(y - PALETTE_Y, 0, PALETTE_HEIGHT, 0, 255);
uint8_t b = 128;
return display.color565(r, g, b);
void updateSelectedColor(uint16_t color) {
uint8_t r = (color >> 11) << 3;
uint8_t g = ((color >> 5) & 0x3F) << 2;
uint8_t b = (color & 0x1F) << 3;
display.fillRect(300, 420, 200, 50, color);
display.setCursor(300, 480);
display.print("R: ");
display.print(r);
display.print(" G: ");
display.print(g);
display.print(" B: ");
display.print(b);
matrix.beginDraw();
matrix.drawPixel(0, 0, r, g, b);
matrix.endDraw();
Thank you, I think maybe one of the problems was I didn't have all the dependencies installed because I did in fact have "Arduino_GigaDisplay_GFX " installed. I uninstalled and reinstalled and now I'm getting the following error on the same sketch: "C:\Users\12146\AppData\Local\Temp.arduinoIDE-unsaved202523-25160-jz0k8u.548rq\sketch_mar3a\sketch_mar3a.ino:3:10: fatal error: Arduino_LED_Matrix.h: No such file or directory #include "Arduino_LED_Matrix.h"
exit status 1
Compilation error: Arduino_LED_Matrix.h: No such file or directory
The situation is different with the "Arduino_LED_Matrix" library than it was with the "Arduino_GigaDisplay_GFX". The "Arduino_LED_Matrix" library is written specifically for use with the UNO R4 WiFi (which has a built-in LED matrix). For this reason, the library is bundled with the Arduino boards platform that adds support to Arduino IDE for the UNO R4 WiFi board. For this reason, you can't install that library via Library Manager.
It also doesn't really make sense to try to use that library with the GIGA R1 WiFi board, because the GIGA R1 WiFi doesn't have an LED matrix.
Similarly, it doesn't really make sense to use libraries like "Arduino_GigaDisplay_GFX" in the same sketch as the "Arduino_LED_Matrix" library since the GIGA Display Shield is specifically designed to be used with the headers on the GIGA R1 WiFi board which are not present on the UNO R4 WiFi (it is theoretically possible to use GIGA Display Shield with UNO R4 WiFi, but it would not be a convenient "plug and play" operation as it is with the GIGA R1 WiFi).
So I'm quite confused by your sketch code.
Did you write this code yourself, or did you find it somewhere on the Internet? If you found it on the Internet, please provide a link to where you found it.
Do you have an LED matrix connected to your GIGA R1 WiFi board?
