After a while I opened up the Arduino IDE again (version 1.8.12) to change some things in a sketch I made previously. Now this sketch that worked before cannot be compiled anymore and so can't any other sketches I create, even the simplest one possible, with no imports and empty setup() and loop() functions. The error message also does not seem to have anything to do with my code. The error message is too long to post here in its entirety, so I pruned it a bit in the middle (denoted by "<...>"). The whole thing can be found in this pastebin. I googled the message but did not find anything. Could it be caused by some recent update?
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano 33 BLE"
In file included from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/DigitalIn.h:22:0,
from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/mbed.h:54,
from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/Arduino.h:32,
from sketch\<projectname>.ino.cpp:1:
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/hal/gpio_api.h:58:29: error: 'gpio_t' does not name a type; did you mean 'gpio_set'?
int gpio_is_connected(const gpio_t *obj);
gpio_set
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/hal/gpio_api.h:65:16: error: variable or field 'gpio_init' declared void
void gpio_init(gpio_t *obj, PinName pin);
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/InterruptIn.h:172:16: error: field 'gpio_irq' has incomplete type 'gpio_irq_t {aka gpio_irq_s}'
gpio_irq_t gpio_irq;
In file included from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/InterruptIn.h:25:0,
from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/UARTSerial.h:27,
from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/mbed.h:74,
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/hal/gpio_irq_api.h:42:16: note: forward declaration of 'gpio_irq_t {aka struct gpio_irq_s}'
typedef struct gpio_irq_s gpio_irq_t;
In file included from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/mbed.h:75:0,
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/FlashIAP.h:163:13: error: field '_flash' has incomplete type 'flash_t {aka flash_s}'
flash_t _flash;
In file included from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/FlashIAP.h:27:0,
from C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/mbed.h:75,
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/hal/flash_api.h:30:16: note: forward declaration of 'flash_t {aka struct flash_s}'
typedef struct flash_s flash_t;
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/FlashIAP.h: In constructor 'constexpr mbed::FlashIAP::FlashIAP()':
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/FlashIAP.h:69:5: error: member 'mbed::FlashIAP::_flash' must be initialized by mem-initializer in 'constexpr' constructor
C:\Users\<username>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.1.4\cores\arduino/mbed/drivers/FlashIAP.h:163:13: note: declared here
flash_t _flash;
exit status 1
Kind regards,
Alexander
