Continuing the discussion from [SOLVED] Where has WebServer.h gone? :
Using an UNO R4 WiFi. WebServer.h not found!!!
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
Compile error:
HTML2.ino.ino:5:10: fatal error: WebServer.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: WebServer.h: No such file or directory
What library is WebServer.h in?
I don't think it uses it..
Did you see the examples for the UNO R4 Wifi??
WiFi Webserver Example
good luck.. ~q
Thank you for the response.
Trying to read the response from a web form on my phone. Simplest case is two buttons. I want to be able to read the response to determine which button was pushed. Later I will add a text box to the form so I can retrieve a string of characters typed by the user to display on the R4's LED matrix.
Example from ChatGTP:
#include <WiFi.h>
const char* ssid = "xxxxxxxx";
const char *password = "yyyyyyyy";
WebServer server(80);
pinMode(13, OUTPUT);
Serial.print("connecting to ");
Serial.println(ssid);
while(WiFi.begin(ssid, password) != WL_CONNECTED) {
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.print("IP address: ");
server.on("/", handleRoot);
server.begin();
Serial.println("Server started.");
server.handleClient();
void handleRoot() {
if(server.hasArg("button")) {
String buttonValue = server.arg("button");
Serial.println("Button pressed: " + buttonValue);
Serial.println("No button pressed");
String html = "<html><body>"
"<form action='/' method='POST'>"
"<button name='button' value='Button1'?Button 1</button?"
"<button name='button' value='Button2'?Button 2</button?"
"</form>"
"</body></html>";
server,send(200, "text/html", html);
Won't compile
I don't see anything in the examples that will help me read the response from the client.
Not exactly a webserver then, ok..
did you look at all the examples??
WiFiS3 examples
There are a few Web client examples in there too..
~q
Juraj
July 4, 2024, 5:42am
5
there is no WebServer library for Uno R4 WiFi. never was
system
Closed
December 31, 2024, 5:43am
6
