Compilation problems for my linked list library
Hi all, I'm trying to write a linked list library to allow my sketch to create dynamically sized lists. A linked list seemed to be an obvious way to do that but I cannot get it to compile.
Here are my files:
LinkedList.h
#ifndef _LinkedList_H_
#define _LinkedList_H_
#include "Arduino.h"
class Node {
public:
	Node(double value);
	void setValue(double value);
	void setNext(Node next);
	double getValue();
	Node getNext();
private:
	double value;
	Node* nextNode;
class LinkedList {
public:
	LinkedList(double& value);
	void append(double value);
	double get(int index);
	void remove(int index);
	int size();
private:
	Node node1;
	Node lastNode;
	int length = 0;
//Do not add code below this line
#endif /* _LinkedList_H_ */
LinkedList.cpp
// Do not remove the include below
#include "LinkedList.h"
LinkedList :: LinkedList(double& value) {
	node1(value);
	lastNode = node1;
	length = 1;
void LinkedList :: append(double value) {
	Node node(value);
	lastNode.setNext(node);
	lastNode = node;
	length++;
double LinkedList :: get(int index) {
	int x = 0;
	Node* nextNode = &node1;
	while(nextNode != NULL) {
		if(x == index) {
			return (*nextNode).getValue();
		x++;
		nextNode = &(*nextNode).getNext();
	return NULL; // Shouldn't ever reach this statement
void LinkedList :: remove(int index) {
	if (index < 0 || index >= length) {
		return;
	if(index == 0) {
		node1 = node1.getNext();
		int x = 1;
		Node* thisNode = &node1.getNext();
		Node lastNode = node1;
		while(thisNode != NULL) {
			if(x == index) {
				lastNode.setNext(thisNode.getNext());
			lastNode = lastNode.getNext();
			x++;
			thisNode = &(*thisNode).getNext();
	length--;
int LinkedList :: size() {
	return length;
 * Node class
Node :: Node(double value) {
	this->value = value;
	nextNode = NULL;
void Node :: setValue(double value) {
void Node :: setNext(Node next) {
	nextNode = &next;
double Node :: getValue() {
	return this->value;
Node Node :: getNext() {
	return *nextNode;
I get several errors on compilation:
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In constructor 'LinkedList::LinkedList(double)':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:5:36: error: no matching function for call to 'Node::Node()'
 LinkedList::LinkedList(double value){
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:5:36: note: candidates are:
In file included from C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:2:0:
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:14:2: note: Node::Node(double)
  Node(double value);
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:14:2: note:   candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note: constexpr Node::Node(const Node&)
 class Node {
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note:   candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note: constexpr Node::Node(Node&&)
  Node(double value);
 class Node {
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:6:8: error: no match for 'operator=' (operand types are 'Node' and 'Node*')
  node1 = new Node(value);
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:6:8: note: candidates are:
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note: Node& Node::operator=(const Node&)
 class Node {
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note:   no known conversion for argument 1 from 'Node*' to 'const Node&'
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note: Node& Node::operator=(Node&&)
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.h:12:7: note:   no known conversion for argument 1 from 'Node*' to 'Node&&'
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In member function 'void LinkedList::append(double)':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:12:28: error: conversion from 'Node*' to non-scalar type 'Node' requested
  Node node = new Node(value);
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In member function 'double LinkedList::get(int)':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:28:19: error: no match for 'operator!=' (operand types are 'Node' and 'int')
  } while(nextNode != NULL);
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In member function 'void LinkedList::remove(int)':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:50:20: error: no match for 'operator!=' (operand types are 'Node' and 'int')
   } while(thisNode != NULL);
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In member function 'void Node::setNext(Node)':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:74:17: error: cannot convert 'Node' to 'Node*' in assignment
  this->nextNode = next;
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp: In member function 'Node Node::getNext()':
C:\Program Files (x86)\Arduino\libraries\LinkedList\LinkedList.cpp:82:15: error: could not convert '((Node*)this)->Node::nextNode' from 'Node*' to 'Node'
  return this->nextNode;
exit status 1
Error compiling.
For context: I'm usually a Java/Python developer and I'm using eclipse & Sloeber plugin.
I think my problems might have something to do with pointers but my attempts to include */& in this were only marginally fruitful.
Can anybody spot any obvious mistakes I have made? Am I just being a noob?
Thanks
Why does this constructor take a reference?
	Node getNext();
Why does this method not return a pointer?
Linked lists are ALL about dynamic allocation and pointers.
The reference in the constructor was an attempt to make it work, I should have removed that before posting.
PaulS:
	Node getNext();
Does a C++ always have to return a pointer? Like I said I'm new to C++ so maybe I need to get some basic tutorials under my belt before writing a library.
	Node node1;
	Node lastNode;
These values are default constructed.
class Node {
public:
	Node(double value);
	double getValue();
	Node getNext();
Your node class doesn't have a default constructor.
Get the picture?
janion:
No it does not.
The fact that you couldn't spot that plain error message right at the beginning and figure out from that what was wrong suggests that you are far too much of a novice to try tackling a linked list.
They do, along with the fact that you apparently don't know the differences between stack and heap allocation, object lifetimes, and the difference between passing by value and by reference. You can't just randomly append * and & to your variable declarations and hope they work, those things do have actual meanings.
No dynamic allocation is the showstopper. It's impossible to make a resizable container without it.
Unfortunately, yes.
