Why do I have these errors when I try to compile the enclosed attachment shown below?.
The compilation stops with this error:
'Mirf' was not declared in this scope
and this in the compiler window:
attiny84_mirf.ino:26:19: warning: SPI85.h: No such file or directory
attiny84_mirf.ino:27:18: warning: Mirf.h: No such file or directory
attiny84_mirf.ino:28:37: warning: MirfHardwareSpi85Driver.h: No such file or directory
In file included from C:\Users\End User\Documents\Arduino\hardware\tiny\cores\tiny/Stream.h:24,
from C:\Users\End User\Documents\Arduino\hardware\tiny\cores\tiny/TinyDebugSerial.h:31,
from attiny84_mirf.ino:29:
When this program is loaded and all the files are in the same folder that are required by the sketch. I can see them and read/modify them all from the tabs in the sketch.
This is an attiny84 example code for the nRF24L01 that can communicate with RF24 library
All the support files and libraries for the attiny85 for nRF24L01 is at repo listed below
* repo : https://github.com/stanleyseow/attiny-nRF24L01
* Author : Stanley Seow
* e-mail : stanleyseow@gmail.com
* date : 8 Aug 2013
Some default values to take note when using this mirf/spi85 library
Uses Mirf forked library from https://github.com/xdarklight/arduino-nrf24l01
- node addressing is similar to RF24 libs but the bytes are flipped
byte TADDR[] = {0xe3, 0xf0, 0xf0, 0xf0, 0xf0}; will matches receiver node of RF24 below
const uint64_t pipes[2] = { 0x7365727631LL, 0xF0F0F0F0E3LL };
The repo for the RF24 lib is at https://github.com/stanleyseow/RF24/
Added TinyDebugSerial to the codes for TX only serial debugging
https://code.google.com/p/arduino-tiny/
#include <SPI85.h>
#include <Mirf.h>
#include <MirfHardwareSpi85Driver.h>
#include <TinyDebugSerial.h>
TinyDebugSerial mySerial = TinyDebugSerial(); // PB0 on attiny84
// This USI-SPI was defined in SPI85.h
//#define MOSI 5
//#define MISO 4
//#define SCK 6
#define CE 7
#define CSN 3
// ATMEL ATTINY84 / ARDUINO
// VCC 1| |14 GND
// SerialTx (D 0) PB0 2| |13 AREF (D 10)
// (D 1) PB1 3| |12 PA1 (D 9)
// RESET PB3 4| |11 PA2 (D 8)
// PWM INT0 (D 2) PB2 5| |10 PA3 (D 7) CE
// SS/CSN (D 3) PA7 6| |9 PA4 (D 6) SCK
// MISO (D 4) PA6 7| |8 PA5 (D 5) MOSI
int bufferSize = 0;
char buffer[32] = "";
unsigned int counter = 0;
uint8_t nodeID = 0;
void setup(){
mySerial.begin( 9600 ); // for tiny_debug_serial
Mirf.cePin = CE;
Mirf.csnPin = CSN;
Mirf.spi = &MirfHardwareSpi85;
Mirf.init();
// This address is compatible with my example of rpi-hub or nRF24_Arduino_as_hub
// at repo https://github.com/stanleyseow/RF24/examples/
byte RADDR[] = {0xe7, 0xde, 0xde, 0xde, 0xde};
byte TADDR[] = {0xe9, 0xde, 0xde, 0xde, 0xde};
// Get nodeID from TXADDR
nodeID = *TADDR & 0xff;
// Compatible with RF24
Mirf.baseConfig = _BV(EN_CRC) | _BV(CRCO);
// RF_DR_LOW, RF_DR_HIGH
// 00 - 1Mbps
// 01 - 2Mbps
// 10 - 250Kbps
// 11 - Reserved
// 1<<2 & 1<<1 is for Max RF Power
Mirf.configRegister( RF_SETUP,( 1<<RF_DR_LOW | 0<<RF_DR_HIGH ) | 1<<2 | 1<<1 );
Mirf.channel = 0x55; // Same as rpi-hub and sendto_hub ( channel 85 )
Mirf.setRADDR(RADDR);
Mirf.setTADDR(TADDR);
Mirf.config();
// Enable dynamic payload on the other side
Mirf.configRegister( FEATURE, 1<<EN_DPL );
Mirf.configRegister( DYNPD, 1<<DPL_P0 | 1<<DPL_P1 | 1<<DPL_P2 | 1<<DPL_P3 | 1<<DPL_P4 | 1<<DPL_P5 );
delay(100);
// Print out register readinds for important settings
uint8_t rf_ch, rf_setup = 0;
byte tx_addr[5];
byte rx_addr[5];
Mirf.readRegister(RF_CH, &rf_ch,sizeof(rf_ch));
Mirf.readRegister(RF_SETUP, &rf_setup, sizeof(rf_setup));
Mirf.readRegister(TX_ADDR, tx_addr, sizeof(tx_addr));
Mirf.readRegister(RX_ADDR_P1, rx_addr, sizeof(rx_addr));
mySerial.println();
mySerial.print("RF_CH :0x");
mySerial.println(rf_ch,HEX);
mySerial.print("RF_SETUP :0x");
mySerial.println(rf_setup,HEX);
mySerial.print("TX_ADDR :");
for ( int i=0;i<5;i++ ) { // Loop 5 times, print in HEX
mySerial.print( tx_addr[i], HEX);
mySerial.println();
mySerial.print("RX_ADDR :");
mySerial.print( rx_addr[i], HEX);
mySerial.println();
delay(1000); // For serial debug to read the init config output
void loop(){
uint8_t sent = false;
unsigned long timer1;
timer1 = millis();
counter++;
sprintf(buffer,"%2X,%u,%08lu",nodeID,counter,timer1);
Mirf.payload = strlen(buffer);
mySerial.print("Len :");
mySerial.print(strlen(buffer));
mySerial.print(" Buffer :");
mySerial.println(buffer);
Mirf.send((byte *) buffer);
while( Mirf.isSending() )
delay(1);
sent = true; // Sent success
if (sent) {
mySerial.print("Sent :");
} else { // <------- Else What?. Doc...
} // End loop()
I have the very same problems If I try to do it in the "normal" manner too.
I don't understand a "File Not Found" error when I can read the "file" in the IDE.
I've attached the complete Zip from Github to this post.
What have I done wrong?. Is it possible that it's an administrator permissions error in Windows 7 Ult 64 bit. I am administrator and I have no issues but I tried to modify one of the header files and got a permission error about write protected, save in another location.. I've done this before with no issues and I don't understand nor have a clue about where to even start with Mr Google, My good friend...
Doc
arduino-nrf24l01-master (2).zip (19.2 KB)
