here is a link to the project: Overview | Tiny Arduino Music Visualizer | Adafruit Learning System
when i try to verify the code an error occurred
Here is the error code and i add the code as a attachment:
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Users\jakob\Documents\Arduino\Piccolo\Piccolo.ino:1:0:
C:\Program Files\Arduino\libraries\Adafruit_LED_Backpack-master/Adafruit_LEDBackpack.h:32:26: fatal error: Adafruit_GFX.h: No such file or directory
#include "Adafruit_GFX.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Piccolo.ino (9.23 KB)
Do you have the file and if so where is it located ?
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\user\Desktop\MakeCall.ino\MakeCall.ino.ino:37:20: fatal error: SIM900.h: No such file or directory
#include "SIM900.h"
Multiple libraries were found for "GSM.h"
Used: C:\Program Files (x86)\Arduino\libraries\GSM
Not used: C:\Users\user\Documents\Arduino\libraries\arduino_55247
exit status 1
Do you have this file and if so where is it located ?
How many copies of this file do you have and where are they located ? How is it #included in your program ?
Did you include the libraries mentioned in the error into your sketch.
Add
#include <SIM900.h>
At the top of your sketch
Using double quotes around the 'file to include' will 'force' the compiler to first look in the directory where the sketch is.
//Edit:
It also seems to look in any subdirectory in the sketch directory.
//EndEdit
If it can't be found there, it will look elsewhere (the 'normal' directories).
If you use '<' and '>', the compiler will only look in the directories that it knows.
As you don't have the include file in the current directory, it will look elsewhere. And for the GSM it can find multiples and does not know which one to pick.
C:\Users\user\Desktop\MakeCall.ino\MakeCall.ino.ino:3:20: fatal error: SIM900.h: No such file or directory
#include "SIM900.h"
exit status 1
pYro_65:
Add
#include <SIM900.h>
afiqzty:
#include "SIM900.h"
exit status 1
please give me step by step to solve the problem
So, where exactly is the SIM900.h file on your system ?
Also I notice this
That is a very odd folder structure and filename
the file sim900 i don't know where it in my system
Change #include "SIM900.h"to#include <SIM900.h>in the code
#include <SIM900.h>
#include <SoftwareSerial.h>
#include "call.h"
#define ACTIVE LOW
const int ledPin = 13; // the number of the LED pin
//CallGSM call;
boolean started=false;
int buttonState = 1;
const int buttonPin = 7; // the number of the pushbutton pin
boolean calling = false;
pinMode(ledPin,OUTPUT);
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin,HIGH);
if (gsm.begin(9600))
Serial.println("\nstatus=READY");
started=true;
Serial.println("\nstatus=IDLE");
buttonState = digitalRead(buttonPin);
if (buttonState == ACTIVE) {
if(calling)
digitalWrite(ledPin,LOW);
calling = false;
call.HangUp();
}else
calling = true;
digitalWrite(ledPin, HIGH);
call.Call("+300000000000"); //Insert telephone number here
afiqzty:
#include <SIM900.h>
#include "call.h"
#define ACTIVE LOW
//CallGSM call;
started=true;
if(calling)
calling = false;
call.HangUp();
}else
calling = true;
when i change #include "SIM900.h" to #include <SIM900.h> it nothing happen .. it the same problem
Can you please list the files in C:\Program Files (x86)\Arduino\libraries\GSM
Ah, a picture on google drive
Thank god it does not work, might be a few meg big
Try the following. Open a command prompt and type what is marked in bold
C:\Users\sterretje>[b]cd "\Program Files (x86)\Arduino\libraries\GSM"[/b]
C:\Program Files (x86)\Arduino\libraries\GSM>[b]tree /f /a[/b]
The result will look like
Folder PATH listing
Volume serial number is 58CB-3E16
C:.
| keywords.txt
| library.properties
| README.adoc
+---examples
| +---GsmWebClient
| | GsmWebClient.ino
| +---GsmWebServer
| | GsmWebServer.ino
| +---MakeVoiceCall
| | MakeVoiceCall.ino
| +---ReceiveSMS
| | ReceiveSMS.ino
| +---ReceiveVoiceCall
| | ReceiveVoiceCall.ino
| +---SendSMS
| | SendSMS.ino
| \---Tools
| +---BandManagement
| | BandManagement.ino
| +---GsmScanNetworks
| | GsmScanNetworks.ino
| +---PinManagement
| | PinManagement.ino
| +---TestGPRS
| | TestGPRS.ino
| +---TestModem
| | TestModem.ino
| \---TestWebServer
| TestWebServer.ino
+---extras
| License.txt
\---src
GSM.h
GSM3CircularBuffer.cpp
GSM3CircularBuffer.h
GSM3IO.h
GSM3MobileAccessProvider.cpp
GSM3MobileAccessProvider.h
GSM3MobileCellManagement.cpp
GSM3MobileCellManagement.h
GSM3MobileClientProvider.cpp
GSM3MobileClientProvider.h
GSM3MobileClientService.cpp
GSM3MobileClientService.h
GSM3MobileDataNetworkProvider.cpp
GSM3MobileDataNetworkProvider.h
GSM3MobileMockupProvider.cpp
GSM3MobileMockupProvider.h
GSM3MobileNetworkProvider.cpp
GSM3MobileNetworkProvider.h
GSM3MobileNetworkRegistry.cpp
GSM3MobileNetworkRegistry.h
GSM3MobileServerProvider.cpp
GSM3MobileServerProvider.h
GSM3MobileServerService.cpp
GSM3MobileServerService.h
GSM3MobileSMSProvider.cpp
GSM3MobileSMSProvider.h
GSM3MobileVoiceProvider.cpp
GSM3MobileVoiceProvider.h
GSM3ShieldV1.cpp
GSM3ShieldV1.h
GSM3ShieldV1AccessProvider.cpp
GSM3ShieldV1AccessProvider.h
GSM3ShieldV1BandManagement.cpp
GSM3ShieldV1BandManagement.h
GSM3ShieldV1BaseProvider.cpp
GSM3ShieldV1BaseProvider.h
GSM3ShieldV1CellManagement.cpp
GSM3ShieldV1CellManagement.h
GSM3ShieldV1ClientProvider.cpp
GSM3ShieldV1ClientProvider.h
GSM3ShieldV1DataNetworkProvider.cpp
GSM3ShieldV1DataNetworkProvider.h
GSM3ShieldV1DirectModemProvider.cpp
GSM3ShieldV1DirectModemProvider.h
GSM3ShieldV1ModemCore.cpp
GSM3ShieldV1ModemCore.h
GSM3ShieldV1ModemVerification.cpp
GSM3ShieldV1ModemVerification.h
GSM3ShieldV1MultiClientProvider.cpp
GSM3ShieldV1MultiClientProvider.h
GSM3ShieldV1MultiServerProvider.cpp
GSM3ShieldV1MultiServerProvider.h
GSM3ShieldV1PinManagement.cpp
GSM3ShieldV1PinManagement.h
GSM3ShieldV1ScanNetworks.cpp
GSM3ShieldV1ScanNetworks.h
GSM3ShieldV1ServerProvider.cpp
GSM3ShieldV1ServerProvider.h
GSM3ShieldV1SMSProvider.cpp
GSM3ShieldV1SMSProvider.h
GSM3ShieldV1VoiceProvider.cpp
GSM3ShieldV1VoiceProvider.h
GSM3SMSService.cpp
GSM3SMSService.h
GSM3SoftSerial.cpp
GSM3SoftSerial.h
GSM3VoiceCallService.cpp
GSM3VoiceCallService.h
Select all text and press enter to copy it. Next paste it here.
Note that SIM900 is missing on my system.
sterretje:
That I don't appear to be able to see.
Kids today ! What's wrong with a command prompt, dir then copy/pasting the list of files ?
I also don't see it; I just checked the source in the web page and found an img tag pointing to https://drive.google.com/drive/folders/0B6cDPvXCsXmOV2k0cW5pOEcwMUE
Go there and you still don't get much (login /signup request).
