Compilation Troubles
Arduino:1.8.6 Hourly Build 2018/03/02 12:12 (Mac OS X), Tarjeta:"Arduino/Genuino Uno"
/Users/nohorayolandarodriguezgomez/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: dlopen(/Users/nohorayolandarodriguezgomez/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../libexec/gcc/avr/4.9.2/liblto_plugin.so, 2): Symbol not found: _environ
Referenced from: /Users/nohorayolandarodriguezgomez/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../libexec/gcc/avr/4.9.2/liblto_plugin.so
Expected in: /usr/lib/libSystem.B.dylib
collect2: error: ld returned 1 exit status
exit status 1
Error compilando para la tarjeta Arduino/Genuino Uno.
Exception in thread "AWT-EventQueue-0" java.lang.IllegalStateException: Timer already cancelled.
at java.util.Timer.sched(Timer.java:397)
at java.util.Timer.schedule(Timer.java:193)
at cc.arduino.view.NotificationPopup.begin(NotificationPopup.java:153)
at cc.arduino.contributions.ContributionsSelfCheck$1.windowGainedFocus(ContributionsSelfCheck.java:119)
at java.awt.Window.processWindowFocusEvent(Window.java:2101)
at java.awt.Window.processEvent(Window.java:2017)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:995)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:450)
at java.awt.Component.dispatchEventImpl(Component.java:4760)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Hi, when I try to compilate a program for my Arduino Uno I get this, can someone help me ? Im working on a MacBook Pro Ver 10.7.5 .
The explanation of the problem is detailed here:
https://github.com/arduino/Arduino/issues/7074
The problem is that the minimum macOS version for the hardware package version you’re using is 10.8.
You can downgrade your package version to one that is compatible with 10.7.5 by doing this:
  • Tools > Board > Boards Manager
  • Wait for download to finish
  • Click on “Arduino AVR Boards”
  • Select 1.6.11 from the “select version” drop down menu
  • Click “Install”
  • Wait for the installation to finish
  • Click the “Close” button
